[PATCH v2] bsps/arm: Move optfdt* files to shared parent directory
Gedare Bloom
gedare at rtems.org
Tue Jun 29 16:56:05 UTC 2021
I don't have an arm toolchain, if someone can pick this up and test
compile the affected BSPs, it looks ok to me.
On Sun, Jun 27, 2021 at 2:46 PM pranav <dangipranav at gmail.com> wrote:
> .../arm/altera-cyclone-v/bspalteracyclonev.yml | 8 ++++----
> spec/build/bsps/arm/beagle/grp.yml | 8 ++++----
> spec/build/bsps/arm/beagle/optfdtcpyro.yml | 15 ---------------
> spec/build/bsps/arm/beagle/optfdtmxsz.yml | 16 ----------------
> spec/build/bsps/arm/beagle/optfdtro.yml | 15 ---------------
> spec/build/bsps/arm/beagle/optfdtuboot.yml | 15 ---------------
> spec/build/bsps/arm/imx/bspimx.yml | 8 ++++----
> spec/build/bsps/arm/imx/optfdtcpyro.yml | 15 ---------------
> spec/build/bsps/arm/imx/optfdtmxsz.yml | 16 ----------------
> spec/build/bsps/arm/imx/optfdtro.yml | 15 ---------------
> spec/build/bsps/arm/imx/optfdtuboot.yml | 15 ---------------
> .../arm/{altera-cyclone-v => }/optfdtcpyro.yml | 0
> .../arm/{altera-cyclone-v => }/optfdtmxsz.yml | 0
> .../bsps/arm/{altera-cyclone-v => }/optfdtro.yml | 0
> .../arm/{altera-cyclone-v => }/optfdtuboot.yml | 0
> spec/build/bsps/arm/raspberrypi/grp.yml | 8 ++++++++
> 16 files changed, 20 insertions(+), 134 deletions(-)
> delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
> delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
> delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
> delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
> delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
> delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
> delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
> delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
> rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtcpyro.yml (100%)
> rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtmxsz.yml (100%)
> rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtro.yml (100%)
> rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtuboot.yml (100%)
> diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> index da567ddd79..faf7203cd4 100644
> --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> @@ -73,15 +73,15 @@ links:
> - role: build-dependency
> uid: optconuart1
> - uid: optfdtcpyro
> + uid: ../optfdtcpyro
> uid: optfdten
> - uid: optfdtmxsz
> + uid: ../optfdtmxsz
> - uid: optfdtro
> + uid: ../optfdtro
> - uid: optfdtuboot
> + uid: ../optfdtuboot
> uid: opti2cspeed
> diff --git a/spec/build/bsps/arm/beagle/grp.yml b/spec/build/bsps/arm/beagle/grp.yml
> index 1375913fd0..20fafa79a0 100644
> --- a/spec/build/bsps/arm/beagle/grp.yml
> +++ b/spec/build/bsps/arm/beagle/grp.yml
> @@ -22,13 +22,13 @@ links:
> uid: optdm3730
> - uid: optfdtcpyro
> - uid: optfdtmxsz
> - uid: optfdtro
> + uid: ../optfdtro
> - uid: optfdtuboot
> uid: ../grp
> diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> deleted file mode 100644
> index c26b1ae051..0000000000
> --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> +++ /dev/null
> @@ -1,15 +0,0 @@
> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> -actions:
> -- get-boolean: null
> -- define-condition: null
> -build-type: option
> -copyrights:
> -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> -default: true
> -default-by-variant: []
> -description: |
> - copy the FDT blob into the read-only load area via bsp_fdt_copy()
> -enabled-by: true
> -links: []
> -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
> -type: build
> diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> index 14af766230..0000000000
> --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> +++ /dev/null
> @@ -1,16 +0,0 @@
> -actions:
> -- get-integer: null
> -- define: null
> -build-type: option
> -copyrights:
> -default: 262144
> -description: |
> - maximum size of the FDT blob in bytes
> -enabled-by: true
> -format: '{}'
> -links: []
> -name: BSP_FDT_BLOB_SIZE_MAX
> -type: build
> diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml b/spec/build/bsps/arm/beagle/optfdtro.yml
> index a61bb2924b..0000000000
> --- a/spec/build/bsps/arm/beagle/optfdtro.yml
> +++ /dev/null
> @@ -1,15 +0,0 @@
> -actions:
> -build-type: option
> -copyrights:
> -default: true
> -description: |
> - place the FDT blob into the read-only data area
> -enabled-by: true
> -links: []
> -name: BSP_FDT_BLOB_READ_ONLY
> -type: build
> diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml b/spec/build/bsps/arm/beagle/optfdtuboot.yml
> index 5805e912ff..0000000000
> --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
> +++ /dev/null
> @@ -1,15 +0,0 @@
> -actions:
> -build-type: option
> -copyrights:
> -default: true
> -description: |
> - copy the U-Boot provided FDT to an internal storage
> -enabled-by: true
> -links: []
> -name: BSP_START_COPY_FDT_FROM_U_BOOT
> -type: build
> diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
> index c65e02db2b..faaca77e63 100644
> --- a/spec/build/bsps/arm/imx/bspimx.yml
> +++ b/spec/build/bsps/arm/imx/bspimx.yml
> @@ -61,13 +61,13 @@ links:
> uid: optconirq
> - uid: optfdtcpyro
> - uid: optfdtmxsz
> - uid: optfdtro
> + uid: ../optfdtro
> - uid: optfdtuboot
> uid: optresetvec
> diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml b/spec/build/bsps/arm/imx/optfdtcpyro.yml
> --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
> +++ /dev/null
> @@ -1,15 +0,0 @@
> -actions:
> -build-type: option
> -copyrights:
> -default: true
> -description: |
> -enabled-by: true
> -links: []
> -type: build
> diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml b/spec/build/bsps/arm/imx/optfdtmxsz.yml
> --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
> +++ /dev/null
> @@ -1,16 +0,0 @@
> -actions:
> -- define: null
> -build-type: option
> -copyrights:
> -default: 262144
> -description: |
> -enabled-by: true
> -format: '{}'
> -links: []
> -type: build
> diff --git a/spec/build/bsps/arm/imx/optfdtro.yml b/spec/build/bsps/arm/imx/optfdtro.yml
> --- a/spec/build/bsps/arm/imx/optfdtro.yml
> +++ /dev/null
> @@ -1,15 +0,0 @@
> -actions:
> -build-type: option
> -copyrights:
> -default: true
> -description: |
> -enabled-by: true
> -links: []
> -type: build
> diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml b/spec/build/bsps/arm/imx/optfdtuboot.yml
> --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
> +++ /dev/null
> @@ -1,15 +0,0 @@
> -actions:
> -build-type: option
> -copyrights:
> -default: true
> -description: |
> -enabled-by: true
> -links: []
> -type: build
> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml b/spec/build/bsps/arm/optfdtcpyro.yml
> similarity index 100%
> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
> rename to spec/build/bsps/arm/optfdtcpyro.yml
> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml b/spec/build/bsps/arm/optfdtmxsz.yml
> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
> rename to spec/build/bsps/arm/optfdtmxsz.yml
> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml b/spec/build/bsps/arm/optfdtro.yml
> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
> rename to spec/build/bsps/arm/optfdtro.yml
> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml b/spec/build/bsps/arm/optfdtuboot.yml
> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
> rename to spec/build/bsps/arm/optfdtuboot.yml
> diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
> index 7291e8b178..e6b0a1cf75 100644
> --- a/spec/build/bsps/arm/raspberrypi/grp.yml
> +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
> @@ -31,6 +31,14 @@ links:
> uid: optrpi2
> uid: optspiiomode
> +- role: build-dependency
> + uid: ../optfdtro
> uid: ../start
> 2.27.0
> devel mailing list
> devel at rtems.org
