[PATCH v7] Update test smpstrongapa01
Richi Dubey
richidubey at gmail.com
Tue Jun 29 07:05:06 UTC 2021
Update smpstrongapa01 to account for task shifting.
testsuites/smptests/smpstrongapa01/init.c | 66 ++++++++++++++++-------
1 file changed, 47 insertions(+), 19 deletions(-)
diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
index bf8bc05231..8a02265615 100644
--- a/testsuites/smptests/smpstrongapa01/init.c
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -1,4 +1,5 @@
+ * Copyright (c) 2020 Richi Dubey ( richidubey at gmail.com )
* Copyright (c) 2016, 2017 embedded brains GmbH. All rights reserved.
* embedded brains GmbH
@@ -16,7 +17,7 @@
#include "config.h"
#endif
-#include "tmacros.h"
+#include <tmacros.h>
@@ -24,15 +25,22 @@ const char rtems_test_name[] = "SMPSTRONGAPA 1";
#define CPU_COUNT 4
-#define TASK_COUNT (3 * CPU_COUNT)
+#define TASK_COUNT 5
#define P(i) (UINT32_C(2) + i)
#define ALL ((UINT32_C(1) << CPU_COUNT) - 1)
-#define IDLE UINT8_C(255)
+#define A(cpu0, cpu1, cpu2, cpu3) ( (cpu3 << 3) | (cpu2 << 2) | (cpu1 << 1)| cpu0 )
-#define NAME rtems_build_name('S', 'A', 'P', 'A')
+typedef enum {
+ T0,
+ T1,
+ T2,
+ T3,
+ T4,
+ IDLE
+} task_index;
typedef struct {
enum {
@@ -43,7 +51,7 @@ typedef struct {
KIND_UNBLOCK
} kind;
- size_t index;
+ task_index index;
struct {
rtems_task_priority priority;
@@ -102,17 +110,34 @@ typedef struct {
static const test_action test_actions[] = {
RESET,
- UNBLOCK( 0, 0, IDLE, IDLE, IDLE),
- UNBLOCK( 1, 0, 1, IDLE, IDLE),
- UNBLOCK( 2, 0, 1, 2, IDLE),
- UNBLOCK( 3, 0, 1, 2, 3),
- UNBLOCK( 5, 0, 1, 2, 3),
- SET_PRIORITY( 3, P(4), 0, 1, 2, 3),
- SET_PRIORITY( 5, P(3), 0, 1, 2, 5),
- BLOCK( 5, 0, 1, 2, 3),
- SET_AFFINITY( 5, ALL, 0, 1, 2, 3),
- RESET,
+ UNBLOCK( T0, T0, IDLE, IDLE, IDLE),
+ UNBLOCK( T1, T0, T1, IDLE, IDLE),
+ UNBLOCK( T2, T0, T1, T2, IDLE),
+ UNBLOCK( T3, T0, T1, T2, T3),
+ UNBLOCK( T4, T0, T1, T2, T3),
+ SET_PRIORITY( T0, P(0), T0, T1, T2, T3),
+ SET_PRIORITY( T1, P(1), T0, T1, T2, T3),
+ SET_PRIORITY( T2, P(2), T0, T1, T2, T3),
+ SET_PRIORITY( T4, P(4), T0, T1, T2, T3),
+ * Introduce Task 3 intially with lowest priority to imitate late arrival
+ SET_PRIORITY( T3, P(8), T0, T1, T2, T4),
+ SET_AFFINITY( T0, ALL, T0, T1, T2, T4),
+ SET_AFFINITY( T1, A(0, 1, 0, 0), T0, T1, T2, T4),
+ SET_AFFINITY( T2, A(0, 0, 1, 0), T0, T1, T2, T4),
+ SET_AFFINITY( T4, A(0, 0, 0, 1), T0, T1, T2, T4),
+ *Set affinity of Task 4 only to CPU1, so that we can check shifting
+ SET_AFFINITY( T3, A(1, 0, 0, 0), T0, T1, T2, T4),
+ * Show that higher priority task gets dislodged from its processor
+ * by a lower priority task !
+ * and goes to the cpu that is executing the task with lowest priority
+ * (among all cpus).
+ SET_PRIORITY( T3, P(3), T3, T1, T2, T0),
RESET
@@ -182,7 +207,7 @@ static void check_cpu_allocations(test_context *ctx, const test_action *action)
size_t i;
for (i = 0; i < CPU_COUNT; ++i) {
- size_t e;
+ task_index e;
const Per_CPU_Control *c;
const Thread_Control *h;
@@ -279,7 +304,7 @@ static void test(void)
for (i = 0; i < TASK_COUNT; ++i) {
sc = rtems_task_create(
- NAME,
+ rtems_build_name(' ', ' ', 'T', '0' + i),
P(i),
RTEMS_MINIMUM_STACK_SIZE,
RTEMS_DEFAULT_MODES,
@@ -292,7 +317,10 @@ static void test(void)
rtems_test_assert(sc == RTEMS_SUCCESSFUL);
- sc = rtems_timer_create(NAME, &ctx->timer_id);
+ sc = rtems_timer_create(
+ rtems_build_name('A', 'C', 'T', 'N'),
+ &ctx->timer_id
sc = rtems_timer_fire_after(ctx->timer_id, 1, timer, ctx);
2.17.1
