source builder fails on master
Richi Dubey
richidubey at gmail.com
Tue Jun 29 07:41:45 UTC 2021
Hi,
I ran the following commands
mkdir -p $HOME/quick-start/LatestMaster/src
cd $HOME/quick-start/LatestMaster/src
git clone https://github.com/RTEMS/rtems-source-builder.git rsb
git clone https://github.com/RTEMS/rtems.git
cd $HOME/quick-start/LatestMaster/src/rsb/rtems
../source-builder/sb-set-builder
--prefix=$HOME/quick-start/LatestMaster/rtems/6 6/rtems-arm
but it fails.:
package: expat-2.1.0-x86_64-linux-gnu-1
building: expat-2.1.0-x86_64-linux-gnu-1
error: building expat-2.1.0-x86_64-linux-gnu-1
Build FAILED
See error report: rsb-report-expat-2.1.0-x86_64-linux-gnu-1.txt
Build Set: Time 0:00:15.413288
Build FAILED
I have attached the report. I think it has something to do with my GCC? I
update it to 11 as well, but I still get the error.
Gcc details:
sudo update-alternatives --config gcc
There are 5 choices for the alternative gcc (providing /usr/bin/gcc).
Selection Path Priority Status
* 0 /usr/bin/gcc-11 110 auto mode
1 /usr/bin/gcc-10 100 manual mode
2 /usr/bin/gcc-11 110 manual mode
3 /usr/bin/gcc-7 70 manual mode
4 /usr/bin/gcc-8 80 manual mode
5 /usr/bin/gcc-9 70 manual mode
Press <enter> to keep the current choice[*], or type selection number:
richi at YouAreAmazing:~$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/11/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu
11.1.0-1ubuntu1~18.04.1'
--with-bugurl=file:///usr/share/doc/gcc-11/README.Bugs
--enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,m2
--prefix=/usr --with-gcc-major-version-only --program-suffix=-11
--program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id
--libexecdir=/usr/lib --without-included-gettext --enable-threads=posix
--libdir=/usr/lib --enable-nls --enable-clocale=gnu
--enable-libstdcxx-debug --enable-libstdcxx-time=yes
--with-default-libstdcxx-abi=new --enable-gnu-unique-object
--disable-vtable-verify --enable-plugin --enable-default-pie
--with-system-zlib --enable-libphobos-checking=release
--with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch
--disable-werror --disable-cet --with-arch-32=i686 --with-abi=m64
--with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic
--enable-offload-targets=nvptx-none=/build/gcc-11-YRKbe7/gcc-11-11.1.0/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-11-YRKbe7/gcc-11-11.1.0/debian/tmp-gcn/usr
--without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu
--host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.1.0 (Ubuntu 11.1.0-1ubuntu1~18.04.1)
Can someone please help me out with this?
Thanks.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210629/dad0a55e/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: building expat-2.1.0-x86_64-linux-gnu-1
Command Line: ../source-builder/sb-set-builder --prefix=/home/richi/quick-start/LatestMaster/rtems/6 6/rtems-arm
Python: 3.6.9 (default, Jan 26 2021, 15:33:00) [GCC 8.4.0]
https://github.com/RTEMS/rtems-source-builder.git/origin/4e6dc6431435821a534da6307e72ecbd7e42b82a
Linux YouAreAmazing 4.15.0-88-generic #88-Ubuntu SMP Tue Feb 11 20:11:34 UTC 2020 x86_64
Tail of the build log:
script:114: CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
script:115: CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
script:116: LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
script:117: LDLIBS_FOR_HOST="${SB_HOST_LIBS}"
script:118: LIBS_FOR_HOST="${SB_HOST_LIBS}"
script:119: CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
script:120: CC_FOR_HOST=$(echo "gcc ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
script:121: CXX_FOR_HOST=$(echo "g++ ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
script:122: # Build
script:123: CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
script:124: CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
script:125: LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
script:126: LDLIBS_FOR_BUILD="${SB_BUILD_LIBS}"
script:127: LIBS_FOR_BUILD="${SB_BUILD_LIBS}"
script:128: CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
script:129: CC_FOR_BUILD=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
script:130: CXX_FOR_BUILD=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
script:131: else
script:132: LDFLAGS="${SB_BUILD_LDFLAGS}"
script:133: LDLIBS="${SB_BUILD_LIBS}"
script:134: LIBS="${SB_BUILD_LIBS}"
script:135: CC=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
script:136: CXX=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
script:137: CC_FOR_BUILD=${CC}
script:138: CXX_FOR_BUILD=${CXX}
script:139: fi
script:140: export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
script:141: export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
script:142: export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
script:143: ./configure --build=x86_64-linux-gnu --host=x86_64-linux-gnu --verbose --prefix=/home/richi/quick-start/LatestMaster/rtems/6 --bindir=/home/richi/quick-start/LatestMaster/rtems/6/bin --exec-prefix=/home/richi/quick-start/LatestMaster/rtems/6 --includedir=/home/richi/quick-start/LatestMaster/rtems/6/include --libdir=/home/richi/quick-start/LatestMaster/rtems/6/lib --mandir=/home/richi/quick-start/LatestMaster/rtems/6/share/man --infodir=/home/richi/quick-start/LatestMaster/rtems/6/share/info --disable-shared
script:144: make -j 4 all
script:145: cd ${build_top}
script:146: echo "==> %install:"
script:147: build_top=$(pwd)
script:148: rm -rf $SB_BUILD_ROOT
script:149: cd expat-2.1.0
script:150: make DESTDIR=$SB_BUILD_ROOT install
script:151: cd ${build_top}
script: 1: #!/bin/sh
script: 2: # ___build_pre as set up in defaults.py
script: 3: # Save the original path away.
script: 4: export SB_ORIG_PATH=${PATH}
script: 5: # Directories
script: 6: SB_PREFIX="/home/richi/quick-start/LatestMaster/rtems/6"
script: 7: SB_PREFIX_CLEAN=$(echo "/home/richi/quick-start/LatestMaster/rtems/6" | /bin/sed -e 's/^\///')
script: 8: SB_SOURCE_DIR="/home/richi/quick-start/LatestMaster/src/rsb/rtems/sources"
script: 9: SB_BUILD_DIR="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1"
script: 10: # host == build, use build; host != build, host uses host and build uses build
script: 11: SB_HOST_CPPFLAGS=""
script: 12: # Optionally do not add includes to c/cxx flags as newer configure's complain
script: 13: SB_HOST_CFLAGS="-O2 -g -pipe "
script: 14: SB_HOST_CXXFLAGS="-O2 -g -pipe "
script: 15: SB_HOST_LDFLAGS=" -L/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/${SB_PREFIX_CLEAN}/lib"
script: 16: SB_HOST_LIBS=""
script: 17: SB_BUILD_CFLAGS="-O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/${SB_PREFIX_CLEAN}/include"
script: 18: SB_BUILD_CXXFLAGS="-O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/${SB_PREFIX_CLEAN}/include"
script: 19: SB_BUILD_LDFLAGS=" -L/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/${SB_PREFIX_CLEAN}/lib"
script: 20: SB_BUILD_LBS=""
script: 21: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 22: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 23: SB_ARCH="x86_64"
script: 24: SB_OS="linux"
script: 25: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 26: export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS SB_HOST_LIBS
script: 27: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
script: 28: export SB_CFLAGS SB_CXXFLAGS
script: 29: # Documentation
script: 30: SB_DOC_DIR="/home/richi/quick-start/LatestMaster/rtems/6/share/doc"
script: 31: export SB_DOC_DIR
script: 32: # Packages
script: 33: SB_PACKAGE_NAME="expat-2.1.0-x86_64-linux-gnu-1"
script: 34: SB_PACKAGE_BUILDNAME="expat-2.1.0-x86_64-linux-gnu-1"
script: 35: SB_PACKAGE_VERSION="2.1.0"
script: 36: SB_PACKAGE_RELEASE="1"
script: 37: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 38: # Build directories
script: 39: export SB_PREFIX
script: 40: SB_BUILD_DIR="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1"
script: 41: SB_BUILD_ROOT="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000"
script: 42: SB_BUILD_ROOT_BINDIR="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000/${SB_PREFIX_CLEAN}/bin"
script: 43: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 44: SB_BUILD_CXC_DIR="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1-cxc"
script: 45: SB_BUILD_CXC_ROOT="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000-cxc"
script: 46: SB_BUILD_CXC_ROOT_BINDIR="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000-cxc/${SB_PREFIX_CLEAN}/bin"
script: 47: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 48: SB_TMPROOT="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm"
script: 49: SB_TMPPREFIX="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/${SB_PREFIX_CLEAN}"
script: 50: SB_TMPBINDIR="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/${SB_PREFIX_CLEAN}/bin"
script: 51: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 52: SB_TMPCXCROOT="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm"
script: 53: SB_TMPCXCPREFIX="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-cxc/6/rtems-arm/${SB_PREFIX_CLEAN}"
script: 54: SB_TMPCXCBINDIR="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-cxc/6/rtems-arm/${SB_PREFIX_CLEAN}/bin"
script: 55: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 56: # Extra path support
script: 57: SB_EXTRAPATH="/home/richi/quick-start/LatestMaster/src/rsb/source-builder"
script: 58: # The compiler flags
script: 59:
script: 60:
script: 61: export CFLAGS_FOR_TARGET
script: 62: export CXXFLAGS_FOR_TARGET
script: 63: # Set up the path. Put the CXC path first.
script: 64: if test -n "${SB_TMPBINDIR}" ; then
script: 65: PATH="${SB_TMPBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 68: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 69: fi
script: 70: if test -n "${SB_EXTRAPATH}" ; then
script: 71: PATH="${SB_EXTRAPATH}:$PATH"
script: 72: fi
script: 73: PATH="/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-staging/bin:$PATH"
script: 74:
script: 75: export PATH
script: 76: # Default environment set up.
script: 77: LANG=C
script: 78: export LANG
script: 79: unset DISPLAY || :
script: 80: umask 022
script: 81: cd "/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1"
script: 82: echo "=> expat-2.1.0-x86_64-linux-gnu-1: CLEAN"
script: 83: echo "==> %clean:"
removing: /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1
making dir: /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1
write script: /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1/do-build
write script: /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1/do-clean
run: /bin/sh -ex /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1/do-build
+ export SB_ORIG_PATH=/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/media/richi/14E2A0B1E2A0988E/Users/richi/quick-start/rtems/5/bin:/home/richi/bin:/home/richi/quick-start/rtems/6/bin:/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/home/richi/quick-start/rtems/5/bin:/home/richi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/lib/jvm/java-14-oracle/bin:/usr/lib/jvm/java-14-oracle/db/bin:/usr/local/go/bin
+ SB_PREFIX=/home/richi/quick-start/LatestMaster/rtems/6
+ echo /home/richi/quick-start/LatestMaster/rtems/6
+ /bin/sed -e s/^\///
+ SB_PREFIX_CLEAN=home/richi/quick-start/LatestMaster/rtems/6
+ SB_SOURCE_DIR=/home/richi/quick-start/LatestMaster/src/rsb/rtems/sources
+ SB_BUILD_DIR=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1
+ SB_HOST_CPPFLAGS=
+ SB_HOST_CFLAGS=-O2 -g -pipe
+ SB_HOST_CXXFLAGS=-O2 -g -pipe
+ SB_HOST_LDFLAGS= -L/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/lib
+ SB_HOST_LIBS=
+ SB_BUILD_CFLAGS=-O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ SB_BUILD_CXXFLAGS=-O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ SB_BUILD_LDFLAGS= -L/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/lib
+ SB_BUILD_LBS=
+ SB_CFLAGS=-O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ SB_CXXFLAGS=-O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ SB_ARCH=x86_64
+ SB_OS=linux
+ export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
+ export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS SB_HOST_LIBS
+ export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
+ export SB_CFLAGS SB_CXXFLAGS
+ SB_DOC_DIR=/home/richi/quick-start/LatestMaster/rtems/6/share/doc
+ export SB_DOC_DIR
+ SB_PACKAGE_NAME=expat-2.1.0-x86_64-linux-gnu-1
+ SB_PACKAGE_BUILDNAME=expat-2.1.0-x86_64-linux-gnu-1
+ SB_PACKAGE_VERSION=2.1.0
+ SB_PACKAGE_RELEASE=1
+ export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
+ export SB_PREFIX
+ SB_BUILD_ROOT=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000
=> expat-2.1.0-x86_64-linux-gnu-1: BUILD
+ SB_BUILD_ROOT_BINDIR=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000/home/richi/quick-start/LatestMaster/rtems/6/bin
==> %prep:
+ export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
+ SB_BUILD_CXC_DIR=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1-cxc
+ SB_BUILD_CXC_ROOT=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000-cxc
+ SB_BUILD_CXC_ROOT_BINDIR=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000-cxc/home/richi/quick-start/LatestMaster/rtems/6/bin
+ export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
+ SB_TMPROOT=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm
+ SB_TMPPREFIX=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6
+ SB_TMPBINDIR=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin
+ export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
+ SB_TMPCXCROOT=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm
+ SB_TMPCXCPREFIX=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-cxc/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6
+ SB_TMPCXCBINDIR=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-cxc/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin
+ export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
+ SB_EXTRAPATH=/home/richi/quick-start/LatestMaster/src/rsb/source-builder
+ export CFLAGS_FOR_TARGET
+ export CXXFLAGS_FOR_TARGET
+ test -n /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin
+ PATH=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin:/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/media/richi/14E2A0B1E2A0988E/Users/richi/quick-start/rtems/5/bin:/home/richi/bin:/home/richi/quick-start/rtems/6/bin:/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/home/richi/quick-start/rtems/5/bin:/home/richi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/lib/jvm/java-14-oracle/bin:/usr/lib/jvm/java-14-oracle/db/bin:/usr/local/go/bin
+ test -n /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-cxc/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin
+ PATH=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-cxc/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin:/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin:/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/media/richi/14E2A0B1E2A0988E/Users/richi/quick-start/rtems/5/bin:/home/richi/bin:/home/richi/quick-start/rtems/6/bin:/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/home/richi/quick-start/rtems/5/bin:/home/richi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/lib/jvm/java-14-oracle/bin:/usr/lib/jvm/java-14-oracle/db/bin:/usr/local/go/bin
+ test -n /home/richi/quick-start/LatestMaster/src/rsb/source-builder
+ PATH=/home/richi/quick-start/LatestMaster/src/rsb/source-builder:/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-cxc/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin:/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin:/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/media/richi/14E2A0B1E2A0988E/Users/richi/quick-start/rtems/5/bin:/home/richi/bin:/home/richi/quick-start/rtems/6/bin:/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/home/richi/quick-start/rtems/5/bin:/home/richi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/lib/jvm/java-14-oracle/bin:/usr/lib/jvm/java-14-oracle/db/bin:/usr/local/go/bin
+ PATH=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-staging/bin:/home/richi/quick-start/LatestMaster/src/rsb/source-builder:/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000-cxc/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin:/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/bin:/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/media/richi/14E2A0B1E2A0988E/Users/richi/quick-start/rtems/5/bin:/home/richi/bin:/home/richi/quick-start/rtems/6/bin:/home/richi/Downloads/node-v14.15.4-linux-x64/bin$:/home/richi/quick-start/rtems/5/bin:/home/richi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/lib/jvm/java-14-oracle/bin:/usr/lib/jvm/java-14-oracle/db/bin:/usr/local/go/bin
+ export PATH
+ LANG=C
+ export LANG
+ unset DISPLAY
+ umask 022
+ cd /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1
+ echo => expat-2.1.0-x86_64-linux-gnu-1: BUILD
+ echo ==> %prep:
+ pwd
+ build_top=/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1
+ /bin/rm -rf expat-2.1.0
+ /bin/gzip -dc /home/richi/quick-start/LatestMaster/src/rsb/rtems/sources/expat-2.1.0.tar.gz
+ /bin/tar -xvv -f -
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/
-rw-rw-r-- karl/karl 1208 2005-12-29 10:43 expat-2.1.0/COPYING
-rwxrwxr-x karl/karl 3299 2012-03-05 20:08 expat-2.1.0/CMakeLists.txt
-rwxrwxr-x karl/karl 1990 2004-09-30 08:17 expat-2.1.0/expat.dsw
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/conftools/
-rwxrwxr-x karl/karl 2480 2006-04-08 01:59 expat-2.1.0/conftools/PrintPath
-rwxrwxr-x karl/karl 726 2000-09-18 21:56 expat-2.1.0/conftools/mkinstalldirs
-rw-rw-r-- karl/karl 1442 2009-01-19 02:56 expat-2.1.0/conftools/expat.m4
-rwxr-xr-x karl/karl 35206 2012-03-25 00:42 expat-2.1.0/conftools/config.sub
-rwxr-xr-x karl/karl 13663 2012-03-25 00:42 expat-2.1.0/conftools/install-sh
-rwxr-xr-x karl/karl 282967 2012-03-25 00:42 expat-2.1.0/conftools/ltmain.sh
-rw-rw-r-- karl/karl 2964 2001-10-02 01:33 expat-2.1.0/conftools/ac_c_bigendian_cross.m4
-rwxr-xr-x karl/karl 44504 2012-03-25 00:42 expat-2.1.0/conftools/config.guess
-rwxrwxr-x karl/karl 1266 2002-05-18 05:56 expat-2.1.0/conftools/get-version.sh
-rw-rw-r-- karl/karl 5790 2012-03-11 11:24 expat-2.1.0/README
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/examples/
-rw-rw-r-- karl/karl 2415 2007-06-03 20:30 expat-2.1.0/examples/outline.c
-rw-rw-r-- karl/karl 1617 2007-06-03 20:30 expat-2.1.0/examples/elements.c
-rw-rw-r-- karl/karl 3556 2012-02-21 08:13 expat-2.1.0/examples/elements.dsp
-rw-rw-r-- karl/karl 3504 2012-02-21 08:13 expat-2.1.0/examples/outline.dsp
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/bcb5/
-rw-rw-r-- karl/karl 4822 2002-12-07 14:29 expat-2.1.0/bcb5/expat_static.mak
-rw-rw-r-- karl/karl 5044 2002-12-07 14:29 expat-2.1.0/bcb5/outline.mak
-rw-rw-r-- karl/karl 247 2002-12-07 14:29 expat-2.1.0/bcb5/xmlwf.bpf
-rw-rw-r-- karl/karl 1606 2002-12-07 14:29 expat-2.1.0/bcb5/all_projects.bpg
-rw-rw-r-- karl/karl 5173 2003-10-24 06:09 expat-2.1.0/bcb5/expatw.mak
-rw-rw-r-- karl/karl 5140 2003-10-24 06:09 expat-2.1.0/bcb5/expat.mak
-rw-rw-r-- karl/karl 3783 2002-12-07 14:29 expat-2.1.0/bcb5/xmlwf.bpr
-rw-rw-r-- karl/karl 5495 2004-01-07 22:42 expat-2.1.0/bcb5/libexpatw_mtd.def
-rw-rw-r-- karl/karl 216 2002-12-08 09:07 expat-2.1.0/bcb5/expatw.bpf
-rw-rw-r-- karl/karl 534 2003-01-17 03:37 expat-2.1.0/bcb5/makefile.mak
-rw-rw-r-- karl/karl 3463 2002-12-07 14:29 expat-2.1.0/bcb5/outline.bpr
-rw-rw-r-- karl/karl 4427 2002-12-09 22:53 expat-2.1.0/bcb5/expatw.bpr
-rw-rw-r-- karl/karl 215 2002-12-08 09:07 expat-2.1.0/bcb5/expat.bpf
-rw-rw-r-- karl/karl 553 2002-12-09 22:53 expat-2.1.0/bcb5/setup.bat
-rw-rw-r-- karl/karl 153 2002-12-07 14:29 expat-2.1.0/bcb5/outline.bpf
-rw-rw-r-- karl/karl 4576 2002-12-07 14:29 expat-2.1.0/bcb5/elements.bpr
-rw-rw-r-- karl/karl 5078 2002-12-07 14:29 expat-2.1.0/bcb5/elements.mak
-rw-rw-r-- karl/karl 155 2002-12-07 14:29 expat-2.1.0/bcb5/elements.bpf
-rw-rw-r-- karl/karl 4301 2003-10-24 06:09 expat-2.1.0/bcb5/README.txt
-rw-rw-r-- karl/karl 181 2002-12-07 14:29 expat-2.1.0/bcb5/expat_static.bpf
-rw-rw-r-- karl/karl 4855 2002-12-09 22:53 expat-2.1.0/bcb5/expatw_static.mak
-rw-rw-r-- karl/karl 181 2002-12-07 14:29 expat-2.1.0/bcb5/expatw_static.bpf
-rw-rw-r-- karl/karl 5495 2004-01-07 22:42 expat-2.1.0/bcb5/libexpat_mtd.def
-rw-rw-r-- karl/karl 3601 2002-12-07 14:29 expat-2.1.0/bcb5/expat_static.bpr
-rw-rw-r-- karl/karl 4535 2002-12-09 22:53 expat-2.1.0/bcb5/expatw_static.bpr
-rw-rw-r-- karl/karl 4039 2002-12-08 09:07 expat-2.1.0/bcb5/expat.bpr
-rw-rw-r-- karl/karl 5145 2002-12-07 14:29 expat-2.1.0/bcb5/xmlwf.mak
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/m4/
-rw-r--r-- karl/karl 11950 2012-03-25 00:42 expat-2.1.0/m4/ltoptions.m4
-rw-r--r-- karl/karl 6126 2012-03-25 00:42 expat-2.1.0/m4/lt~obsolete.m4
-rw-r--r-- karl/karl 281744 2012-03-25 00:42 expat-2.1.0/m4/libtool.m4
-rw-r--r-- karl/karl 4372 2012-03-25 00:42 expat-2.1.0/m4/ltsugar.m4
-rw-r--r-- karl/karl 686 2012-03-25 00:42 expat-2.1.0/m4/ltversion.m4
-rwxrwxr-x karl/karl 1512 2012-03-05 20:08 expat-2.1.0/ConfigureChecks.cmake
-rw-rw-r-- karl/karl 11379 2012-03-25 00:36 expat-2.1.0/Changes
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/
-rwxrwxr-x karl/karl 6737 2009-08-08 09:18 expat-2.1.0/amiga/expat_68k_handler_stubs.c
-rw-rw-r-- karl/karl 1395 2009-08-08 09:18 expat-2.1.0/amiga/expat_base.h
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/libraries/
-rw-rw-r-- karl/karl 16516 2007-06-03 20:23 expat-2.1.0/amiga/include/libraries/expat.h
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/interfaces/
-rw-rw-r-- karl/karl 7930 2005-12-24 12:15 expat-2.1.0/amiga/include/interfaces/expat.h
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/proto/
-rw-rw-r-- karl/karl 1335 2007-06-03 20:21 expat-2.1.0/amiga/include/proto/expat.h
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/inline4/
-rw-rw-r-- karl/karl 6557 2005-12-24 12:15 expat-2.1.0/amiga/include/inline4/expat.h
-rw-rw-r-- karl/karl 42000 2009-08-08 09:18 expat-2.1.0/amiga/expat_68k.c
-rw-rw-r-- karl/karl 21979 2009-02-01 02:27 expat-2.1.0/amiga/expat_vectors.c
-rwxrwxr-x karl/karl 4133 2009-08-08 09:18 expat-2.1.0/amiga/expat_68k.h
-rw-rw-r-- karl/karl 10427 2009-08-08 09:18 expat-2.1.0/amiga/Makefile
-rw-rw-r-- karl/karl 3136 2009-08-08 09:18 expat-2.1.0/amiga/README.txt
-rwxrwxr-x karl/karl 1744 2009-08-08 09:18 expat-2.1.0/amiga/launch.c
-rw-rw-r-- karl/karl 10742 2005-12-24 12:09 expat-2.1.0/amiga/expat.xml
-rwxrwxr-x karl/karl 5839 2009-08-08 09:18 expat-2.1.0/amiga/expat_lib.c
-rwxrwxr-x karl/karl 565580 2012-03-25 00:42 expat-2.1.0/configure
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/doc/
-rw-rw-r-- karl/karl 94947 2012-03-10 23:57 expat-2.1.0/doc/reference.html
-rw-rw-r-- karl/karl 2368 2007-06-05 20:35 expat-2.1.0/doc/valid-xhtml10.png
-rw-rw-r-- karl/karl 1027 2007-06-05 20:35 expat-2.1.0/doc/expat.png
-rw-rw-r-- karl/karl 1340 2004-07-23 08:58 expat-2.1.0/doc/style.css
-rw-rw-r-- karl/karl 7895 2007-04-30 06:23 expat-2.1.0/doc/xmlwf.1
-rw-rw-r-- karl/karl 13690 2009-01-19 03:25 expat-2.1.0/doc/xmlwf.sgml
-rw-rw-r-- karl/karl 231 2009-01-19 09:05 expat-2.1.0/expat.pc.in
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/win32/
-rw-rw-r-- karl/karl 1195 2007-05-03 07:45 expat-2.1.0/win32/MANIFEST.txt
-rw-rw-r-- karl/karl 2804 2012-03-04 21:23 expat-2.1.0/win32/README.txt
-rw-rw-r-- karl/karl 4337 2012-03-04 21:23 expat-2.1.0/win32/expat.iss
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/tests/
-rw-rw-r-- karl/karl 49164 2012-03-04 05:15 expat-2.1.0/tests/runtests.c
-rw-rw-r-- karl/karl 3038 2004-04-30 08:48 expat-2.1.0/tests/chardata.c
-rwxrwxr-x karl/karl 3557 2008-08-03 23:49 expat-2.1.0/tests/xmltest.sh
-rw-rw-r-- karl/karl 2336 2012-02-21 09:19 expat-2.1.0/tests/minicheck.h
-rw-rw-r-- karl/karl 185 2005-01-28 10:49 expat-2.1.0/tests/runtestspp.cpp
-rw-rw-r-- karl/karl 570 2012-02-26 20:06 expat-2.1.0/tests/README.txt
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/tests/benchmark/
-rw-rw-r-- karl/karl 820 2004-09-30 08:17 expat-2.1.0/tests/benchmark/benchmark.dsw
-rw-rw-r-- karl/karl 2999 2012-02-21 09:15 expat-2.1.0/tests/benchmark/benchmark.dsp
-rw-rw-r-- karl/karl 546 2006-01-02 00:23 expat-2.1.0/tests/benchmark/README.txt
-rw-rw-r-- karl/karl 2798 2007-06-03 20:30 expat-2.1.0/tests/benchmark/benchmark.c
-rw-rw-r-- karl/karl 791 2004-09-30 10:28 expat-2.1.0/tests/chardata.h
-rw-rw-r-- karl/karl 4219 2006-07-01 20:24 expat-2.1.0/tests/minicheck.c
-rwxrwxr-x karl/karl 2735 2012-03-05 20:08 expat-2.1.0/expat_config.h.cmake
-rwxrwxr-x karl/karl 1768 2012-03-05 20:08 expat-2.1.0/CMake.README
-rw-rw-r-- karl/karl 2518 2012-03-05 20:08 expat-2.1.0/MANIFEST
-rw-rw-r-- karl/karl 2728 2012-03-25 00:42 expat-2.1.0/expat_config.h.in
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/vms/
-rw-rw-r-- karl/karl 2080 2004-01-29 05:41 expat-2.1.0/vms/descrip.mms
-rw-rw-r-- karl/karl 1199 2003-11-02 23:43 expat-2.1.0/vms/expat_config.h
-rw-rw-r-- karl/karl 576 2002-06-05 09:43 expat-2.1.0/vms/README.vms
-rw-rw-r-- karl/karl 7036 2012-03-19 03:48 expat-2.1.0/Makefile.in
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/xmlwf/
-rwxrwxr-x karl/karl 509 2005-12-25 22:24 expat-2.1.0/xmlwf/xmlfile.h
-rwxrwxr-x karl/karl 224 2002-07-01 20:48 expat-2.1.0/xmlwf/xmlurl.h
-rwxrwxr-x karl/karl 1790 2009-11-12 22:21 expat-2.1.0/xmlwf/readfilemap.c
-rwxrwxr-x karl/karl 2143 2002-07-01 20:43 expat-2.1.0/xmlwf/win32filemap.c
-rwxrwxr-x karl/karl 1274 2006-06-28 08:25 expat-2.1.0/xmlwf/unixfilemap.c
-rwxrwxr-x karl/karl 493 2002-07-01 20:43 expat-2.1.0/xmlwf/xmlmime.h
-rwxrwxr-x karl/karl 2912 2002-07-01 20:43 expat-2.1.0/xmlwf/ct.c
-rwxrwxr-x karl/karl 4130 2012-02-21 07:46 expat-2.1.0/xmlwf/xmlwf.dsp
-rwxrwxr-x karl/karl 500 2002-07-01 20:43 expat-2.1.0/xmlwf/filemap.h
-rwxrwxr-x karl/karl 1355 2006-08-05 22:30 expat-2.1.0/xmlwf/codepage.c
-rwxrwxr-x karl/karl 6082 2007-06-03 20:30 expat-2.1.0/xmlwf/xmlfile.c
-rwxrwxr-x karl/karl 3218 2002-07-01 20:43 expat-2.1.0/xmlwf/xmlmime.c
-rwxrwxr-x karl/karl 21212 2009-01-19 05:49 expat-2.1.0/xmlwf/xmlwf.c
-rwxrwxr-x karl/karl 8813 2002-08-24 03:17 expat-2.1.0/xmlwf/xmlwin32url.cxx
-rwxrwxr-x karl/karl 825 2000-04-21 09:50 expat-2.1.0/xmlwf/xmltchar.h
-rwxrwxr-x karl/karl 196 2002-07-01 20:43 expat-2.1.0/xmlwf/codepage.h
-rw-rw-r-- karl/karl 4652 2012-03-04 05:15 expat-2.1.0/configure.in
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/lib/
-rw-rw-r-- karl/karl 3144 2006-11-26 23:04 expat-2.1.0/lib/xmltok_ns.c
-rw-rw-r-- karl/karl 797 2007-06-03 20:27 expat-2.1.0/lib/amigaconfig.h
-rw-rw-r-- karl/karl 11184 2005-12-23 20:15 expat-2.1.0/lib/xmltok.h
-rw-rw-r-- karl/karl 3364 2006-06-02 17:47 expat-2.1.0/lib/expat_external.h
-rw-rw-r-- karl/karl 1830 2002-07-02 02:14 expat-2.1.0/lib/iasciitab.h
-rw-rw-r-- karl/karl 4599 2002-07-08 22:36 expat-2.1.0/lib/Makefile.MPW
-rw-rw-r-- karl/karl 2028 2007-05-11 22:50 expat-2.1.0/lib/libexpat.def
-rw-rw-r-- karl/karl 709 2005-12-16 23:11 expat-2.1.0/lib/winconfig.h
-rw-rw-r-- karl/karl 7050 2000-09-18 21:56 expat-2.1.0/lib/nametab.h
-rw-rw-r-- karl/karl 2028 2006-11-26 23:05 expat-2.1.0/lib/internal.h
-rw-rw-r-- karl/karl 32475 2009-01-31 11:51 expat-2.1.0/lib/xmlrole.c
-rw-rw-r-- karl/karl 4971 2012-02-21 08:15 expat-2.1.0/lib/expatw.dsp
-rw-rw-r-- karl/karl 1760 2002-07-02 02:14 expat-2.1.0/lib/asciitab.h
-rw-rw-r-- karl/karl 1763 2002-07-02 02:14 expat-2.1.0/lib/utf8tab.h
-rw-rw-r-- karl/karl 2028 2007-05-11 22:50 expat-2.1.0/lib/libexpatw.def
-rw-rw-r-- karl/karl 197613 2012-03-11 10:43 expat-2.1.0/lib/xmlparse.c
-rw-rw-r-- karl/karl 41405 2009-01-31 11:51 expat-2.1.0/lib/xmltok.c
-rw-rw-r-- karl/karl 1985 2007-05-08 07:55 expat-2.1.0/lib/ascii.h
-rw-rw-r-- karl/karl 661 2000-09-22 02:50 expat-2.1.0/lib/xmltok_impl.h
-rw-rw-r-- karl/karl 1813 2002-07-02 02:14 expat-2.1.0/lib/latin1tab.h
-rw-rw-r-- karl/karl 4325 2007-05-03 07:43 expat-2.1.0/lib/expatw_static.dsp
-rw-rw-r-- karl/karl 1325 2003-11-02 23:44 expat-2.1.0/lib/macconfig.h
-rw-rw-r-- karl/karl 4901 2012-02-21 08:15 expat-2.1.0/lib/expat.dsp
-rw-rw-r-- karl/karl 3023 2002-11-13 03:15 expat-2.1.0/lib/xmlrole.h
-rw-rw-r-- karl/karl 44554 2012-02-21 08:29 expat-2.1.0/lib/xmltok_impl.c
-rw-rw-r-- karl/karl 4254 2012-02-21 08:15 expat-2.1.0/lib/expat_static.dsp
-rw-rw-r-- karl/karl 41752 2012-03-04 00:38 expat-2.1.0/lib/expat.h
-rw-rw-r-- karl/karl 304569 2012-03-25 00:42 expat-2.1.0/aclocal.m4
+ tar_exit=0
+ cd expat-2.1.0
+ /bin/chmod -R a+rX,g-w,o-w .
==> clean %{buildroot}: /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000
+ SB_CXC=no
+ echo ==> clean %{buildroot}: /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000
+ /bin/rm -rf /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000
+ /bin/mkdir -p /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/expat-2.1.0-x86_64-linux-gnu-1-1000
==> %build:
+ echo ==> %build:
+ pwd
+ cd expat-2.1.0
+ test x86_64-linux-gnu != x86_64-linux-gnu
+ LDFLAGS= -L/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/lib
+ LDLIBS=
+ LIBS=
+ echo gcc -O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ sed -e s,-std=gnu99 ,,
+ CC=gcc -O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ echo g++ -O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ CXX=g++ -O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ CC_FOR_BUILD=gcc -O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ CXX_FOR_BUILD=g++ -O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
+ export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
+ export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
+ export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
+ ./configure --build=x86_64-linux-gnu --host=x86_64-linux-gnu --verbose --prefix=/home/richi/quick-start/LatestMaster/rtems/6 --bindir=/home/richi/quick-start/LatestMaster/rtems/6/bin --exec-prefix=/home/richi/quick-start/LatestMaster/rtems/6 --includedir=/home/richi/quick-start/LatestMaster/rtems/6/include --libdir=/home/richi/quick-start/LatestMaster/rtems/6/lib --mandir=/home/richi/quick-start/LatestMaster/rtems/6/share/man --infodir=/home/richi/quick-start/LatestMaster/rtems/6/share/info --disable-shared
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking how to print strings... printf
checking for x86_64-linux-gnu-gcc... gcc -O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
checking whether the C compiler works... no
configure: error: in `/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1/expat-2.1.0':
configure: error: C compiler cannot create executables
See `config.log' for more details
shell cmd failed: /bin/sh -ex /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1/do-build
