source builder fails on master
Tue Jun 29 16:15:58 UTC 2021
Run with --no-clean option and see if you can find the config.log for
the expat package. Otherwise, you might try to build that expat
package by hand to see what is failing.
On Tue, Jun 29, 2021 at 1:43 AM Richi Dubey <richidubey at gmail.com> wrote:
> These are the last few lines of the report:
> bindir=/home/richi/quick-start/LatestMaster/rtems/6/bin --exec-prefix=/home/richi/quick-start/LatestMaster/rtems/6 --includedir=/home/richi/quick-start/LatestMaster/rtems/6/include --libdir=/home/richi/quick-start/LatestMaster/rtems/6/lib --mandir=/home/richi/quick-start/LatestMaster/rtems/6/share/man --infodir=/home/richi/quick-start/LatestMaster/rtems/6/share/info --disable-shared
> checking build system type... x86_64-pc-linux-gnu
> checking host system type... x86_64-pc-linux-gnu
> checking how to print strings... printf
> checking for x86_64-linux-gnu-gcc... gcc -O2 -g -pipe -I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
> checking whether the C compiler works... no
> configure: error: in `/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1/expat-2.1.0':
> configure: error: C compiler cannot create executables
> See `config.log' for more details
> shell cmd failed: /bin/sh -ex  /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1/do-build
> error: building expat-2.1.0-x86_64-linux-gnu-1
> On Tue, Jun 29, 2021 at 1:11 PM Richi Dubey <richidubey at gmail.com> wrote:
>> Hi,
>> I ran the following commands
>> mkdir -p $HOME/quick-start/LatestMaster/src
>> cd $HOME/quick-start/LatestMaster/src
>> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
>> git clone https://github.com/RTEMS/rtems.git
>> cd $HOME/quick-start/LatestMaster/src/rsb/rtems
>> ../source-builder/sb-set-builder --prefix=$HOME/quick-start/LatestMaster/rtems/6 6/rtems-arm
>> but it fails.:
>> package: expat-2.1.0-x86_64-linux-gnu-1
>> building: expat-2.1.0-x86_64-linux-gnu-1
>> Build FAILED
>>   See error report: rsb-report-expat-2.1.0-x86_64-linux-gnu-1.txt
>> Build Set: Time 0:00:15.413288
>> Build FAILED
>> I have attached the report. I think it has something to do with my GCC? I update it to 11 as well, but I still get the error.
>> Gcc details:
>> sudo update-alternatives --config gcc
>> There are 5 choices for the alternative gcc (providing /usr/bin/gcc).
>>   Selection    Path             Priority   Status
>> * 0            /usr/bin/gcc-11   110       auto mode
>>   1            /usr/bin/gcc-10   100       manual mode
>>   2            /usr/bin/gcc-11   110       manual mode
>>   3            /usr/bin/gcc-7    70        manual mode
>>   4            /usr/bin/gcc-8    80        manual mode
>>   5            /usr/bin/gcc-9    70        manual mode
>> Press <enter> to keep the current choice[*], or type selection number:
>> richi at YouAreAmazing:~$ gcc -v
>> Using built-in specs.
>> COLLECT_GCC=gcc
>> COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/11/lto-wrapper
>> OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa
>> OFFLOAD_TARGET_DEFAULT=1
>> Target: x86_64-linux-gnu
>> Configured with: ../src/configure -v --with-pkgversion='Ubuntu 11.1.0-1ubuntu1~18.04.1' --with-bugurl=file:///usr/share/doc/gcc-11/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-11 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --disable-cet --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-11-YRKbe7/gcc-11-11.1.0/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-11-YRKbe7/gcc-11-11.1.0/debian/tmp-gcn/usr --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
>> Thread model: posix
>> Supported LTO compression algorithms: zlib zstd
>> gcc version 11.1.0 (Ubuntu 11.1.0-1ubuntu1~18.04.1)
>> Can someone please help me out with this?
>> Thanks.
> devel mailing list
> devel at rtems.org
