source builder fails on master
Richi Dubey richidubey at gmail.com
Tue Jun 29 07:43:09 UTC 2021
These are the last few lines of the report:
bindir=/home/richi/quick-start/LatestMaster/rtems/6/bin
--exec-prefix=/home/richi/quick-start/LatestMaster/rtems/6
--includedir=/home/richi/quick-start/LatestMaster/rtems/6/include
--libdir=/home/richi/quick-start/LatestMaster/rtems/6/lib
--mandir=/home/richi/quick-start/LatestMaster/rtems/6/share/man
--infodir=/home/richi/quick-start/LatestMaster/rtems/6/share/info
--disable-shared
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking how to print strings... printf
checking for x86_64-linux-gnu-gcc... gcc -O2 -g -pipe
-I/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/tmp/sb-1000/6/rtems-arm/home/richi/quick-start/LatestMaster/rtems/6/include
checking whether the C compiler works... no
configure: error: in
`/home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1/expat-2.1.0':
configure: error: C compiler cannot create executables
See `config.log' for more details
shell cmd failed: /bin/sh -ex
 /home/richi/quick-start/LatestMaster/src/rsb/rtems/build/expat-2.1.0-x86_64-linux-gnu-1/do-build
error: building expat-2.1.0-x86_64-linux-gnu-1
On Tue, Jun 29, 2021 at 1:11 PM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> I ran the following commands
> mkdir -p $HOME/quick-start/LatestMaster/src
> cd $HOME/quick-start/LatestMaster/src
> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> git clone https://github.com/RTEMS/rtems.git
> cd $HOME/quick-start/LatestMaster/src/rsb/rtems
> ../source-builder/sb-set-builder
> --prefix=$HOME/quick-start/LatestMaster/rtems/6 6/rtems-arm
> but it fails.:
> package: expat-2.1.0-x86_64-linux-gnu-1
> building: expat-2.1.0-x86_64-linux-gnu-1
> Build FAILED
>   See error report: rsb-report-expat-2.1.0-x86_64-linux-gnu-1.txt
> Build Set: Time 0:00:15.413288
> Build FAILED
> I have attached the report. I think it has something to do with my GCC? I
> update it to 11 as well, but I still get the error.
> Gcc details:
> sudo update-alternatives --config gcc
> There are 5 choices for the alternative gcc (providing /usr/bin/gcc).
>   Selection    Path             Priority   Status
> * 0            /usr/bin/gcc-11   110       auto mode
>   1            /usr/bin/gcc-10   100       manual mode
>   2            /usr/bin/gcc-11   110       manual mode
>   3            /usr/bin/gcc-7    70        manual mode
>   4            /usr/bin/gcc-8    80        manual mode
>   5            /usr/bin/gcc-9    70        manual mode
> Press <enter> to keep the current choice[*], or type selection number:
> richi at YouAreAmazing:~$ gcc -v
> Using built-in specs.
> COLLECT_GCC=gcc
> COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/11/lto-wrapper
> OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa
> OFFLOAD_TARGET_DEFAULT=1
> Target: x86_64-linux-gnu
> Configured with: ../src/configure -v --with-pkgversion='Ubuntu
> 11.1.0-1ubuntu1~18.04.1'
> --with-bugurl=file:///usr/share/doc/gcc-11/README.Bugs
> --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,m2
> --prefix=/usr --with-gcc-major-version-only --program-suffix=-11
> --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id
> --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix
> --libdir=/usr/lib --enable-nls --enable-clocale=gnu
> --enable-libstdcxx-debug --enable-libstdcxx-time=yes
> --with-default-libstdcxx-abi=new --enable-gnu-unique-object
> --disable-vtable-verify --enable-plugin --enable-default-pie
> --with-system-zlib --enable-libphobos-checking=release
> --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch
> --disable-werror --disable-cet --with-arch-32=i686 --with-abi=m64
> --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic
> --enable-offload-targets=nvptx-none=/build/gcc-11-YRKbe7/gcc-11-11.1.0/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-11-YRKbe7/gcc-11-11.1.0/debian/tmp-gcn/usr
> --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu
> --host=x86_64-linux-gnu --target=x86_64-linux-gnu
> Thread model: posix
> Supported LTO compression algorithms: zlib zstd
> gcc version 11.1.0 (Ubuntu 11.1.0-1ubuntu1~18.04.1)
> Can someone please help me out with this?
> Thanks.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210629/eec097a2/attachment.html>
