[PATCH v2] bsps/arm: Move optfdt* files to shared parent directory
Gedare Bloom
gedare at rtems.org
Tue Jun 29 20:37:34 UTC 2021
On Tue, Jun 29, 2021 at 12:27 PM Christian Mauderer <oss at c-mauderer.de> wrote:
> PS: Wouldn't it make sense to move these even further up? There is for
> example ./spec/build/bsps/riscv/riscv/optfdtcpyro.yml too. A short md5
> shows that it's the same file again.
Yes. Pranav, can you prepare a patch to move these into spec/build/bsps?
I see....
cd spec/build/bsps
grep -r FDT_BLOB
powerpc/qoriq
pops up too.
> Best regards
> Christian
> On 29/06/2021 20:23, Christian Mauderer wrote:
> > arm/imx7, arm/altcycv_devkit, arm/raspberrypi and arm/beagleboneblack
> > compile with the patch. I tried libbsd media01 on beagleboneblack and it
> > works.
> > Best regards
> > Christian
> > On 29/06/2021 18:56, Gedare Bloom wrote:
> >> I don't have an arm toolchain, if someone can pick this up and test
> >> compile the affected BSPs, it looks ok to me.
> >> On Sun, Jun 27, 2021 at 2:46 PM pranav <dangipranav at gmail.com> wrote:
> >>> .../arm/altera-cyclone-v/bspalteracyclonev.yml | 8 ++++----
> >>> spec/build/bsps/arm/beagle/grp.yml | 8 ++++----
> >>> spec/build/bsps/arm/beagle/optfdtcpyro.yml | 15 ---------------
> >>> spec/build/bsps/arm/beagle/optfdtmxsz.yml | 16 ----------------
> >>> spec/build/bsps/arm/beagle/optfdtro.yml | 15 ---------------
> >>> spec/build/bsps/arm/beagle/optfdtuboot.yml | 15 ---------------
> >>> spec/build/bsps/arm/imx/bspimx.yml | 8 ++++----
> >>> spec/build/bsps/arm/imx/optfdtcpyro.yml | 15 ---------------
> >>> spec/build/bsps/arm/imx/optfdtmxsz.yml | 16 ----------------
> >>> spec/build/bsps/arm/imx/optfdtro.yml | 15 ---------------
> >>> spec/build/bsps/arm/imx/optfdtuboot.yml | 15 ---------------
> >>> .../arm/{altera-cyclone-v => }/optfdtcpyro.yml | 0
> >>> .../arm/{altera-cyclone-v => }/optfdtmxsz.yml | 0
> >>> .../bsps/arm/{altera-cyclone-v => }/optfdtro.yml | 0
> >>> .../arm/{altera-cyclone-v => }/optfdtuboot.yml | 0
> >>> spec/build/bsps/arm/raspberrypi/grp.yml | 8 ++++++++
> >>> 16 files changed, 20 insertions(+), 134 deletions(-)
> >>> delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
> >>> delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
> >>> delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
> >>> delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
> >>> delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
> >>> delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
> >>> delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
> >>> delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
> >>> rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtcpyro.yml
> >>> (100%)
> >>> rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtmxsz.yml
> >>> (100%)
> >>> rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtro.yml (100%)
> >>> rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtuboot.yml
> >>> (100%)
> >>> diff --git
> >>> a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> >>> b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> >>> index da567ddd79..faf7203cd4 100644
> >>> --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> >>> +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> >>> @@ -73,15 +73,15 @@ links:
> >>> - role: build-dependency
> >>> uid: optconuart1
> >>> - uid: optfdtcpyro
> >>> + uid: ../optfdtcpyro
> >>> uid: optfdten
> >>> - uid: optfdtmxsz
> >>> + uid: ../optfdtmxsz
> >>> - uid: optfdtro
> >>> + uid: ../optfdtro
> >>> - uid: optfdtuboot
> >>> + uid: ../optfdtuboot
> >>> uid: opti2cspeed
> >>> diff --git a/spec/build/bsps/arm/beagle/grp.yml
> >>> b/spec/build/bsps/arm/beagle/grp.yml
> >>> index 1375913fd0..20fafa79a0 100644
> >>> --- a/spec/build/bsps/arm/beagle/grp.yml
> >>> +++ b/spec/build/bsps/arm/beagle/grp.yml
> >>> @@ -22,13 +22,13 @@ links:
> >>> uid: optdm3730
> >>> - uid: optfdtcpyro
> >>> - uid: optfdtmxsz
> >>> - uid: optfdtro
> >>> + uid: ../optfdtro
> >>> - uid: optfdtuboot
> >>> uid: ../grp
> >>> diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> >>> b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> >>> deleted file mode 100644
> >>> index c26b1ae051..0000000000
> >>> --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> >>> +++ /dev/null
> >>> @@ -1,15 +0,0 @@
> >>> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> >>> -actions:
> >>> -- get-boolean: null
> >>> -- define-condition: null
> >>> -build-type: option
> >>> -copyrights:
> >>> -- Copyright (C) 2020 embedded brains GmbH
> >>> (http://www.embedded-brains.de)
> >>> -default: true
> >>> -default-by-variant: []
> >>> -description: |
> >>> - copy the FDT blob into the read-only load area via bsp_fdt_copy()
> >>> -enabled-by: true
> >>> -links: []
> >>> -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
> >>> -type: build
> >>> diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> >>> b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> >>> index 14af766230..0000000000
> >>> --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> >>> +++ /dev/null
> >>> @@ -1,16 +0,0 @@
> >>> -actions:
> >>> -- get-integer: null
> >>> -- define: null
> >>> -build-type: option
> >>> -copyrights:
> >>> -default: 262144
> >>> -description: |
> >>> - maximum size of the FDT blob in bytes
> >>> -enabled-by: true
> >>> -format: '{}'
> >>> -links: []
> >>> -name: BSP_FDT_BLOB_SIZE_MAX
> >>> -type: build
> >>> diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml
> >>> b/spec/build/bsps/arm/beagle/optfdtro.yml
> >>> index a61bb2924b..0000000000
> >>> --- a/spec/build/bsps/arm/beagle/optfdtro.yml
> >>> +++ /dev/null
> >>> @@ -1,15 +0,0 @@
> >>> -actions:
> >>> -build-type: option
> >>> -copyrights:
> >>> -default: true
> >>> -description: |
> >>> - place the FDT blob into the read-only data area
> >>> -enabled-by: true
> >>> -links: []
> >>> -name: BSP_FDT_BLOB_READ_ONLY
> >>> -type: build
> >>> diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml
> >>> b/spec/build/bsps/arm/beagle/optfdtuboot.yml
> >>> index 5805e912ff..0000000000
> >>> --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
> >>> +++ /dev/null
> >>> @@ -1,15 +0,0 @@
> >>> -actions:
> >>> -build-type: option
> >>> -copyrights:
> >>> -default: true
> >>> -description: |
> >>> - copy the U-Boot provided FDT to an internal storage
> >>> -enabled-by: true
> >>> -links: []
> >>> -name: BSP_START_COPY_FDT_FROM_U_BOOT
> >>> -type: build
> >>> diff --git a/spec/build/bsps/arm/imx/bspimx.yml
> >>> b/spec/build/bsps/arm/imx/bspimx.yml
> >>> index c65e02db2b..faaca77e63 100644
> >>> --- a/spec/build/bsps/arm/imx/bspimx.yml
> >>> +++ b/spec/build/bsps/arm/imx/bspimx.yml
> >>> @@ -61,13 +61,13 @@ links:
> >>> uid: optconirq
> >>> - uid: optfdtcpyro
> >>> - uid: optfdtmxsz
> >>> - uid: optfdtro
> >>> + uid: ../optfdtro
> >>> - uid: optfdtuboot
> >>> uid: optresetvec
> >>> diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml
> >>> b/spec/build/bsps/arm/imx/optfdtcpyro.yml
> >>> --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
> >>> +++ /dev/null
> >>> @@ -1,15 +0,0 @@
> >>> -actions:
> >>> -build-type: option
> >>> -copyrights:
> >>> -default: true
> >>> -description: |
> >>> -enabled-by: true
> >>> -links: []
> >>> -type: build
> >>> diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml
> >>> b/spec/build/bsps/arm/imx/optfdtmxsz.yml
> >>> --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
> >>> +++ /dev/null
> >>> @@ -1,16 +0,0 @@
> >>> -actions:
> >>> -- define: null
> >>> -build-type: option
> >>> -copyrights:
> >>> -default: 262144
> >>> -description: |
> >>> -enabled-by: true
> >>> -format: '{}'
> >>> -links: []
> >>> -type: build
> >>> diff --git a/spec/build/bsps/arm/imx/optfdtro.yml
> >>> b/spec/build/bsps/arm/imx/optfdtro.yml
> >>> --- a/spec/build/bsps/arm/imx/optfdtro.yml
> >>> +++ /dev/null
> >>> @@ -1,15 +0,0 @@
> >>> -actions:
> >>> -build-type: option
> >>> -copyrights:
> >>> -default: true
> >>> -description: |
> >>> -enabled-by: true
> >>> -links: []
> >>> -type: build
> >>> diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml
> >>> b/spec/build/bsps/arm/imx/optfdtuboot.yml
> >>> --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
> >>> +++ /dev/null
> >>> @@ -1,15 +0,0 @@
> >>> -actions:
> >>> -build-type: option
> >>> -copyrights:
> >>> -default: true
> >>> -description: |
> >>> -enabled-by: true
> >>> -links: []
> >>> -type: build
> >>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
> >>> b/spec/build/bsps/arm/optfdtcpyro.yml
> >>> similarity index 100%
> >>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
> >>> rename to spec/build/bsps/arm/optfdtcpyro.yml
> >>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
> >>> b/spec/build/bsps/arm/optfdtmxsz.yml
> >>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
> >>> rename to spec/build/bsps/arm/optfdtmxsz.yml
> >>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
> >>> b/spec/build/bsps/arm/optfdtro.yml
> >>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
> >>> rename to spec/build/bsps/arm/optfdtro.yml
> >>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
> >>> b/spec/build/bsps/arm/optfdtuboot.yml
> >>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
> >>> rename to spec/build/bsps/arm/optfdtuboot.yml
> >>> diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml
> >>> b/spec/build/bsps/arm/raspberrypi/grp.yml
> >>> index 7291e8b178..e6b0a1cf75 100644
> >>> --- a/spec/build/bsps/arm/raspberrypi/grp.yml
> >>> +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
> >>> @@ -31,6 +31,14 @@ links:
> >>> uid: optrpi2
> >>> uid: optspiiomode
> >>> +- role: build-dependency
> >>> + uid: ../optfdtro
> >>> uid: ../start
> >>> 2.27.0
> >>> _______________________________________________
> >>> devel mailing list
> >>> devel at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/devel
> >> devel mailing list
> >> devel at rtems.org
> > devel mailing list
> > devel at rtems.org
