[PATCH v2] bsps/arm: Move optfdt* files to shared parent directory
Christian Mauderer oss at c-mauderer.de
Tue Jun 29 18:27:04 UTC 2021
PS: Wouldn't it make sense to move these even further up? There is for
example ./spec/build/bsps/riscv/riscv/optfdtcpyro.yml too. A short md5
shows that it's the same file again.
Best regards
Christian
On 29/06/2021 20:23, Christian Mauderer wrote:
> arm/imx7, arm/altcycv_devkit, arm/raspberrypi and arm/beagleboneblack
> compile with the patch. I tried libbsd media01 on beagleboneblack and it
> works.
> Best regards
> Christian
> On 29/06/2021 18:56, Gedare Bloom wrote:
>> I don't have an arm toolchain, if someone can pick this up and test
>> compile the affected BSPs, it looks ok to me.
>> On Sun, Jun 27, 2021 at 2:46 PM pranav <dangipranav at gmail.com> wrote:
>>>   .../arm/altera-cyclone-v/bspalteracyclonev.yml   |  8 ++++----
>>>   spec/build/bsps/arm/beagle/grp.yml               |  8 ++++----
>>>   spec/build/bsps/arm/beagle/optfdtcpyro.yml       | 15 ---------------
>>>   spec/build/bsps/arm/beagle/optfdtmxsz.yml        | 16 ----------------
>>>   spec/build/bsps/arm/beagle/optfdtro.yml          | 15 ---------------
>>>   spec/build/bsps/arm/beagle/optfdtuboot.yml       | 15 ---------------
>>>   spec/build/bsps/arm/imx/bspimx.yml               |  8 ++++----
>>>   spec/build/bsps/arm/imx/optfdtcpyro.yml          | 15 ---------------
>>>   spec/build/bsps/arm/imx/optfdtmxsz.yml           | 16 ----------------
>>>   spec/build/bsps/arm/imx/optfdtro.yml             | 15 ---------------
>>>   spec/build/bsps/arm/imx/optfdtuboot.yml          | 15 ---------------
>>>   .../arm/{altera-cyclone-v => }/optfdtcpyro.yml   |  0
>>>   .../arm/{altera-cyclone-v => }/optfdtmxsz.yml    |  0
>>>   .../bsps/arm/{altera-cyclone-v => }/optfdtro.yml |  0
>>>   .../arm/{altera-cyclone-v => }/optfdtuboot.yml   |  0
>>>   spec/build/bsps/arm/raspberrypi/grp.yml          |  8 ++++++++
>>>   16 files changed, 20 insertions(+), 134 deletions(-)
>>>   delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>>   delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>>   delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
>>>   delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
>>>   delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
>>>   delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
>>>   delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
>>>   delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
>>>   rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtcpyro.yml
>>> (100%)
>>>   rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtmxsz.yml
>>> (100%)
>>>   rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtro.yml (100%)
>>>   rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtuboot.yml
>>> (100%)
>>> diff --git
>>> a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>> b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>> index da567ddd79..faf7203cd4 100644
>>> --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>> +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>> @@ -73,15 +73,15 @@ links:
>>>   - role: build-dependency
>>>     uid: optconuart1
>>> -  uid: optfdtcpyro
>>> +  uid: ../optfdtcpyro
>>>     uid: optfdten
>>> -  uid: optfdtmxsz
>>> +  uid: ../optfdtmxsz
>>> -  uid: optfdtro
>>> +  uid: ../optfdtro
>>> -  uid: optfdtuboot
>>> +  uid: ../optfdtuboot
>>>     uid: opti2cspeed
>>> diff --git a/spec/build/bsps/arm/beagle/grp.yml
>>> b/spec/build/bsps/arm/beagle/grp.yml
>>> index 1375913fd0..20fafa79a0 100644
>>> --- a/spec/build/bsps/arm/beagle/grp.yml
>>> +++ b/spec/build/bsps/arm/beagle/grp.yml
>>> @@ -22,13 +22,13 @@ links:
>>>     uid: optdm3730
>>> -  uid: optfdtcpyro
>>> -  uid: optfdtmxsz
>>> -  uid: optfdtro
>>> +  uid: ../optfdtro
>>> -  uid: optfdtuboot
>>>     uid: ../grp
>>> diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>> b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>> deleted file mode 100644
>>> index c26b1ae051..0000000000
>>> --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>> +++ /dev/null
>>> @@ -1,15 +0,0 @@
>>> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>> -actions:
>>> -- get-boolean: null
>>> -- define-condition: null
>>> -build-type: option
>>> -copyrights:
>>> -- Copyright (C) 2020 embedded brains GmbH
>>> (http://www.embedded-brains.de)
>>> -default: true
>>> -default-by-variant: []
>>> -description: |
>>> -  copy the FDT blob into the read-only load area via bsp_fdt_copy()
>>> -enabled-by: true
>>> -links: []
>>> -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
>>> -type: build
>>> diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>> b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>> index 14af766230..0000000000
>>> --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>> +++ /dev/null
>>> @@ -1,16 +0,0 @@
>>> -actions:
>>> -- get-integer: null
>>> -- define: null
>>> -build-type: option
>>> -copyrights:
>>> -default: 262144
>>> -description: |
>>> -  maximum size of the FDT blob in bytes
>>> -enabled-by: true
>>> -format: '{}'
>>> -links: []
>>> -name: BSP_FDT_BLOB_SIZE_MAX
>>> -type: build
>>> diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml
>>> b/spec/build/bsps/arm/beagle/optfdtro.yml
>>> index a61bb2924b..0000000000
>>> --- a/spec/build/bsps/arm/beagle/optfdtro.yml
>>> +++ /dev/null
>>> @@ -1,15 +0,0 @@
>>> -actions:
>>> -build-type: option
>>> -copyrights:
>>> -default: true
>>> -description: |
>>> -  place the FDT blob into the read-only data area
>>> -enabled-by: true
>>> -links: []
>>> -name: BSP_FDT_BLOB_READ_ONLY
>>> -type: build
>>> diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml
>>> b/spec/build/bsps/arm/beagle/optfdtuboot.yml
>>> index 5805e912ff..0000000000
>>> --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
>>> +++ /dev/null
>>> @@ -1,15 +0,0 @@
>>> -actions:
>>> -build-type: option
>>> -copyrights:
>>> -default: true
>>> -description: |
>>> -  copy the U-Boot provided FDT to an internal storage
>>> -enabled-by: true
>>> -links: []
>>> -name: BSP_START_COPY_FDT_FROM_U_BOOT
>>> -type: build
>>> diff --git a/spec/build/bsps/arm/imx/bspimx.yml
>>> b/spec/build/bsps/arm/imx/bspimx.yml
>>> index c65e02db2b..faaca77e63 100644
>>> --- a/spec/build/bsps/arm/imx/bspimx.yml
>>> +++ b/spec/build/bsps/arm/imx/bspimx.yml
>>> @@ -61,13 +61,13 @@ links:
>>>     uid: optconirq
>>> -  uid: optfdtcpyro
>>> -  uid: optfdtmxsz
>>> -  uid: optfdtro
>>> +  uid: ../optfdtro
>>> -  uid: optfdtuboot
>>>     uid: optresetvec
>>> diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml
>>> b/spec/build/bsps/arm/imx/optfdtcpyro.yml
>>> --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
>>> +++ /dev/null
>>> @@ -1,15 +0,0 @@
>>> -actions:
>>> -build-type: option
>>> -copyrights:
>>> -default: true
>>> -description: |
>>> -enabled-by: true
>>> -links: []
>>> -type: build
>>> diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml
>>> b/spec/build/bsps/arm/imx/optfdtmxsz.yml
>>> --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
>>> +++ /dev/null
>>> @@ -1,16 +0,0 @@
>>> -actions:
>>> -- define: null
>>> -build-type: option
>>> -copyrights:
>>> -default: 262144
>>> -description: |
>>> -enabled-by: true
>>> -format: '{}'
>>> -links: []
>>> -type: build
>>> diff --git a/spec/build/bsps/arm/imx/optfdtro.yml
>>> b/spec/build/bsps/arm/imx/optfdtro.yml
>>> --- a/spec/build/bsps/arm/imx/optfdtro.yml
>>> +++ /dev/null
>>> @@ -1,15 +0,0 @@
>>> -actions:
>>> -build-type: option
>>> -copyrights:
>>> -default: true
>>> -description: |
>>> -enabled-by: true
>>> -links: []
>>> -type: build
>>> diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml
>>> b/spec/build/bsps/arm/imx/optfdtuboot.yml
>>> --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
>>> +++ /dev/null
>>> @@ -1,15 +0,0 @@
>>> -actions:
>>> -build-type: option
>>> -copyrights:
>>> -default: true
>>> -description: |
>>> -enabled-by: true
>>> -links: []
>>> -type: build
>>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
>>> b/spec/build/bsps/arm/optfdtcpyro.yml
>>> similarity index 100%
>>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
>>> rename to spec/build/bsps/arm/optfdtcpyro.yml
>>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
>>> b/spec/build/bsps/arm/optfdtmxsz.yml
>>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
>>> rename to spec/build/bsps/arm/optfdtmxsz.yml
>>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
>>> b/spec/build/bsps/arm/optfdtro.yml
>>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
>>> rename to spec/build/bsps/arm/optfdtro.yml
>>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
>>> b/spec/build/bsps/arm/optfdtuboot.yml
>>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
>>> rename to spec/build/bsps/arm/optfdtuboot.yml
>>> diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml
>>> b/spec/build/bsps/arm/raspberrypi/grp.yml
>>> index 7291e8b178..e6b0a1cf75 100644
>>> --- a/spec/build/bsps/arm/raspberrypi/grp.yml
>>> +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
>>> @@ -31,6 +31,14 @@ links:
>>>     uid: optrpi2
>>>     uid: optspiiomode
>>> +- role: build-dependency
>>> +  uid: ../optfdtro
>>>     uid: ../start
>>> 2.27.0
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
