[PATCH rtems-tools] tester: Add zu3eg test configs
Kinsey Moore kinsey.moore at oarcorp.com
Tue Jun 29 21:36:03 UTC 2021
Add tester configurations for ILP32 and LP64 on hardware.
 .../bsps/xilinx_zynqmp_ilp32_zu3eg.ini        | 41 +++++++++++++++++++
 .../testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini | 41 +++++++++++++++++++
 2 files changed, 82 insertions(+)
 create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
 create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
new file mode 100644
index 0000000..5fd2039
--- /dev/null
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
@@ -0,0 +1,41 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2021 Kinsey Moore(kinsey.moore at oarcorp.com)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) ILP32 ZU3EG BSP.
+[xilinx_zynqmp_ilp32_zu3eg]
+bsp                = xilinx_zynqmp_ilp32_zu3eg
+arch               = aarch64
+tester             = %{_rtscripts}/tftp.cfg
+jobs               = 1
+target_reset_regex = ^No ethernet found.*|^BOOTP broadcast 6.*|^.+complete\.+ TIMEOUT.*|^.*Retry count exceeded.*|^.*: No link\..*|^.*TFTP server died; starting again.*
+target_start_regex = ^.*Xilinx Zynq MP First Stage Boot Loader.*
+requires           = target_on_command, target_off_command, target_reset_command, bsp_tty_dev
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
index 0000000..c4d091f
--- /dev/null
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
@@ -0,0 +1,41 @@
+# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) LP64 ZU3EG BSP.
+[xilinx_zynqmp_lp64_zu3eg]
+bsp                = xilinx_zynqmp_lp64_zu3eg
+arch               = aarch64
+jobs               = 1
2.20.1
