[PATCH rtems-tools] tester: Add zu3eg test configs
Tue Jun 29 21:42:01 UTC 2021
looks good
On Tue, Jun 29, 2021 at 3:36 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Add tester configurations for ILP32 and LP64 on hardware.
>  .../bsps/xilinx_zynqmp_ilp32_zu3eg.ini        | 41 +++++++++++++++++++
>  .../testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini | 41 +++++++++++++++++++
>  2 files changed, 82 insertions(+)
>  create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
>  create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
> new file mode 100644
> index 0000000..5fd2039
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_zu3eg.ini
> @@ -0,0 +1,41 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2021 Kinsey Moore(kinsey.moore at oarcorp.com)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) ILP32 ZU3EG BSP.
> +[xilinx_zynqmp_ilp32_zu3eg]
> +bsp                = xilinx_zynqmp_ilp32_zu3eg
> +arch               = aarch64
> +tester             = %{_rtscripts}/tftp.cfg
> +jobs               = 1
> +target_reset_regex = ^No ethernet found.*|^BOOTP broadcast 6.*|^.+complete\.+ TIMEOUT.*|^.*Retry count exceeded.*|^.*: No link\..*|^.*TFTP server died; starting again.*
> +target_start_regex = ^.*Xilinx Zynq MP First Stage Boot Loader.*
> +requires           = target_on_command, target_off_command, target_reset_command, bsp_tty_dev
> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
> index 0000000..c4d091f
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
> @@ -0,0 +1,41 @@
> +# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) LP64 ZU3EG BSP.
> +[xilinx_zynqmp_lp64_zu3eg]
> +bsp                = xilinx_zynqmp_lp64_zu3eg
> +arch               = aarch64
> +jobs               = 1
> 2.20.1
> devel mailing list
> devel at rtems.org
