[PATCH] bsps: Fix GICv3 support for AArch32
Sebastian Huber
Wed Jun 30 13:38:21 UTC 2021
The GICv3 support is shared between AArch32 and AArch64. For AArch32,
the new AARCH64_IS_NONSECURE is never defined. Use ARM_MULTILIB_ARCH_V4
instead.
This issue was introduced by 76c6caad52244ab9a14151620a80ff0f71035b6c.
There is still a change in bsp_interrupt_vector_enable() for AArch32
compared to the version before 76c6caad52244ab9a14151620a80ff0f71035b6c.
bsps/shared/dev/irq/arm-gicv3.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index d216f4f5f7..75b089b6b5 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -176,7 +176,7 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
volatile gic_sgi_ppi *sgi_ppi =
gicv3_get_sgi_ppi(_SMP_Get_current_processor());
/* Set interrupt group to 1 in the current security mode */
-#if defined(AARCH64_IS_NONSECURE)
+#if defined(ARM_MULTILIB_ARCH_V4) || defined(AARCH64_IS_NONSECURE)
sgi_ppi->icspigrpr[0] |= 1 << (vector % 32);
sgi_ppi->icspigrpmodr[0] &= ~(1 << (vector % 32));
#else
@@ -228,7 +228,7 @@ static void gicv3_init_cpu_interface(void)
volatile gic_sgi_ppi *sgi_ppi = gicv3_get_sgi_ppi(cpu_index);
sgi_ppi->icspigrpr[0] = 0xffffffff;
sgi_ppi->icspigrpmodr[0] = 0;
#else
@@ -262,7 +262,7 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
dist->icdicer[id / 32] = 0xffffffff;
dist->icdigr[id / 32] = 0xffffffff;
dist->icdigmr[id / 32] = 0;
#else
2.26.2
