[PATCH] bsps: Fix GICv3 support for AArch32
Wed Jun 30 14:05:23 UTC 2021
Thanks, that makes sense.
On Wed, Jun 30, 2021 at 7:38 AM Sebastian Huber
> The GICv3 support is shared between AArch32 and AArch64.  For AArch32,
> the new AARCH64_IS_NONSECURE is never defined.  Use ARM_MULTILIB_ARCH_V4
> instead.
> This issue was introduced by 76c6caad52244ab9a14151620a80ff0f71035b6c.
> There is still a change in bsp_interrupt_vector_enable() for AArch32
> compared to the version before 76c6caad52244ab9a14151620a80ff0f71035b6c.
>  bsps/shared/dev/irq/arm-gicv3.c | 6 +++---
>  1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
> index d216f4f5f7..75b089b6b5 100644
> --- a/bsps/shared/dev/irq/arm-gicv3.c
> +++ b/bsps/shared/dev/irq/arm-gicv3.c
> @@ -176,7 +176,7 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
>      volatile gic_sgi_ppi *sgi_ppi =
>        gicv3_get_sgi_ppi(_SMP_Get_current_processor());
>      /* Set interrupt group to 1 in the current security mode */
> -#if defined(AARCH64_IS_NONSECURE)
> +#if defined(ARM_MULTILIB_ARCH_V4) || defined(AARCH64_IS_NONSECURE)
>      sgi_ppi->icspigrpr[0] |= 1 << (vector % 32);
>      sgi_ppi->icspigrpmodr[0] &= ~(1 << (vector % 32));
>  #else
> @@ -228,7 +228,7 @@ static void gicv3_init_cpu_interface(void)
>    volatile gic_sgi_ppi *sgi_ppi = gicv3_get_sgi_ppi(cpu_index);
>    sgi_ppi->icspigrpr[0] = 0xffffffff;
>    sgi_ppi->icspigrpmodr[0] = 0;
>  #else
> @@ -262,7 +262,7 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>      dist->icdicer[id / 32] = 0xffffffff;
>      dist->icdigr[id / 32] = 0xffffffff;
>      dist->icdigmr[id / 32] = 0;
>  #else
> 2.26.2
