[PATCH] rtems: Simplify _Signal_Action_handler()
Sebastian Huber
Tue Mar 2 09:56:23 UTC 2021
Use the invariant that a ASR is only processed if ASR processing is
enabled.
cpukit/rtems/src/signalsend.c | 11 +++--------
1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/cpukit/rtems/src/signalsend.c b/cpukit/rtems/src/signalsend.c
index 8c4ce10788..72407e2b01 100644
--- a/cpukit/rtems/src/signalsend.c
+++ b/cpukit/rtems/src/signalsend.c
@@ -41,7 +41,6 @@ static void _Signal_Action_handler(
bool normal_is_preemptible;
uint32_t normal_cpu_time_budget;
Thread_CPU_budget_algorithms normal_budget_algorithm;
- bool normal_asr_is_enabled;
uint32_t normal_isr_level;
uint32_t before_call_isr_level;
bool after_call_is_preemptible;
@@ -68,8 +67,8 @@ static void _Signal_Action_handler(
/* Save normal mode */
+ _Assert( asr->is_enabled );
normal_is_preemptible = executing->is_preemptible;
- normal_asr_is_enabled = asr->is_enabled;
normal_cpu_time_budget = executing->cpu_time_budget;
normal_budget_algorithm = executing->budget_algorithm;
@@ -133,13 +132,9 @@ static void _Signal_Action_handler(
after_call_asr_is_enabled = asr->is_enabled;
- asr->is_enabled = normal_asr_is_enabled;
+ asr->is_enabled = true;
- if (
- normal_asr_is_enabled &&
- !after_call_asr_is_enabled &&
- asr->signals_pending != 0
+ if ( !after_call_asr_is_enabled && asr->signals_pending != 0 ) {
_Thread_Append_post_switch_action( executing, action );
2.26.2
