Need help in deciding GSoC project also want to know project Scope
Gedare Bloom
gedare at rtems.org
Wed Mar 3 15:43:09 UTC 2021
On Tue, Mar 2, 2021 at 4:36 PM Prateek Pardeshi <prateekp99 at zoho.com> wrote:
> Hi Gedare,
> ---- On Tue, 02 Mar 2021 22:19:26 +0530 Gedare Bloom <gedare at rtems.org> wrote ----
> > Hi Prateek,
> > On Mon, Mar 1, 2021 at 10:31 PM Prateek Pardeshi <prateekp99 at zoho.com> wrote:
> > > Hi everyone,
> > > I have decided following projects to work on this Summer. Please let me know about the scope of the project, whether it's feasible to work during GSoC.
> > > 1. https://devel.rtems.org/wiki/Developer/Projects/Open/UsingClang
> > > 2. Ticket 4182: https://devel.rtems.org/ticket/4182
> > > Reason for choosing projects with LLVM:
> > > I worked as a fellow under Dr.Michael Kruse, maintainer of LLVM Compiler(Polly), also I am contributor at LLVM Compiler, specifically Polly, which is a loop optimiser written in C language. I'm familiar with the LLVM community and the working/debugging/building/issues of LLVM compiler.
> > > Recently I worked on refabricating reference-counting used for memory management to C++ binding.
> > > This project will provide me an opportunity to work on something new while contributing to the Open Source.
> > Super, and welcome. We now have a much-revised build system that
> > should be better able to work with llvm. There are scattered efforts
> > that have shown how to compile RTEMS with clang for a couple of
> > targets (sparc, riscv), and it would be a great effort to try to unify
> > the support and integrate to our development tools.
> > We have a Python-based tool (RTEMS Source Builder (RSB)) for building
> > host/cross compiler toolchains (and orchestrating other builds):
> > https://git.rtems.org/rtems-source-builder/
> > Our documentation on the build system and RSB are fairly robust, and
> > may be a good place for you to start building some knowledge:
> > https://docs.rtems.org/branches/master/user/rsb/index.html
> > https://docs.rtems.org/branches/master/user/bld/index.html
> > We can probably get input from people who have managed to build a
> > clang toolchain. I have run clang-analyzer over RTEMS as well in the
> > past. It should be a good time now to get the llvm/clang
> > infrastructure well-integrated to our development ecosystem.
> Thanks for your response. Is this idea appropriate enough to work during GSoC or should I start exploring other Projects?
I think it is appropriate. The actual work and scope may need to be
refined a little more, based on what you find is already supported vs
what does not work. But, to get a suite of llvm/clang "recipes" in RSB
to build targets is a good first step, and then adding some of the
sanitizer/fuzzer on top is a great extension.
> > > Looking forward to hear!
> > > Thanks & Regards,
> > > Prateek Pardeshi
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
