[PATCH 00/22] tester: Update covoar for new build system
Gedare Bloom
gedare at rtems.org
Tue Mar 2 15:48:15 UTC 2021
On Mon, Mar 1, 2021 at 1:01 PM Alex White <alexanderjwhite at gmail.com> wrote:
> This patch set updates the covoar tool to allow it to work with the
> outputs of the current build system. It includes various fixes and
> improvements needed to successfully produce coverage reports for the
> following BSP configurations: griscv-sis, leon3-sis, pc-qemu,
> xilinx_zynqmp, and xilinx_zynq_a9_qemu.
> Here is a link to the final coverage reports that I got for the five
> configurations mentioned above:
> https://ftp.rtems.org/pub/rtems/people/joel/coverage/coverage-2021-02-28/
> Alex White (22):
> tester: Update to support new build system
> tester: Add coverage variants for a few BSPs
> covoar/TargetBase: Update branchInstructions variable name
> covoar/Target_i386: Add NOP patterns
> covoar/Target_arm: Add THUMB branch instructions
> covoar: Add aarch64 target
> covoar/CoverageReaderQEMU: Fix infinite loop
> covoar/TargetBase: Fix QEMU branch info
> covoar: Fix DWARF reading
> dwarf: Fix get_source
> covoar: Account for build path change
> covoar: Fix NOP execution marking
> covoar: Handle periods in symbols from objdump
> covoar/reports: Add new statistics to summary
> coverage/reports: Improve formatting and clarity
> coverage/reports: Share common JS and CSS in reports
> covoar: Fix null pointer dereference
> covoar: Add option to create named objdumps
> covoar: Catch exceptional case
> covoar: Allow symbols from objdump to be skipped
> covoar: Fix overflow of high PC address
> covoar/Reports: Fix empty branch report
Can you split this patch set up in some logical groups?
I see:
tester configuration changes
dwarf bug fixes
covoar bug fixes
covoar improvements/additions
coverage reports improvements
It will be easier to review and merge them in smaller chunks that are
logically organized together.
> rtemstoolkit/rld-dwarf.cpp | 13 +-
> rtemstoolkit/rld-dwarf.h | 5 +
> rtemstoolkit/rld-process.cpp | 12 +
> rtemstoolkit/rld-process.h | 9 +
> tester/covoar/CoverageMapBase.cc | 10 +
> tester/covoar/CoverageMapBase.h | 4 +
> tester/covoar/CoverageReaderQEMU.cc | 11 +-
> tester/covoar/DesiredSymbols.cc | 48 +++-
> tester/covoar/DesiredSymbols.h | 34 ++-
> tester/covoar/ExecutableInfo.cc | 95 ++++++-
> tester/covoar/ObjdumpProcessor.cc | 145 ++++++++---
> tester/covoar/ReportsBase.cc | 80 ++++--
> tester/covoar/ReportsHtml.cc | 243 +++++++++---------
> tester/covoar/ReportsText.cc | 76 +++---
> tester/covoar/SymbolTable.cc | 12 +-
> tester/covoar/TargetBase.cc | 14 +-
> tester/covoar/TargetBase.h | 4 +-
> tester/covoar/TargetFactory.cc | 2 +
> tester/covoar/Target_aarch64.cc | 100 +++++++
> tester/covoar/Target_aarch64.h | 77 ++++++
> tester/covoar/Target_arm.cc | 70 +++--
> tester/covoar/Target_i386.cc | 73 +++---
> tester/covoar/Target_lm32.cc | 12 +-
> tester/covoar/Target_m68k.cc | 98 +++----
> tester/covoar/Target_powerpc.cc | 56 ++--
> tester/covoar/Target_riscv.cc | 22 +-
> tester/covoar/Target_sparc.cc | 66 ++---
> tester/covoar/app_common.cc | 10 +
> tester/covoar/app_common.h | 1 +
> tester/covoar/covoar.cc | 135 +++++-----
> tester/covoar/wscript | 1 +
> tester/rt/coverage.py | 63 +++--
> tester/rtems/testing/bsps/a53_qemu-cov.ini | 41 +++
> tester/rtems/testing/bsps/griscv-sis-cov.ini | 4 +-
> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 4 +-
> tester/rtems/testing/bsps/leon3-sis-cov.ini | 4 +-
> tester/rtems/testing/bsps/pc-qemu-cov.ini | 42 +++
> .../testing/bsps/xilinx_zynq_a9_qemu-cov.ini | 41 +++
> .../rtems/testing/bsps/xilinx_zynqmp-cov.ini | 41 +++
> tester/rtems/testing/coverage/symbol-sets.ini | 91 +++----
> 40 files changed, 1327 insertions(+), 542 deletions(-)
> create mode 100644 tester/covoar/Target_aarch64.cc
> create mode 100644 tester/covoar/Target_aarch64.h
> create mode 100644 tester/rtems/testing/bsps/a53_qemu-cov.ini
> create mode 100644 tester/rtems/testing/bsps/pc-qemu-cov.ini
> create mode 100644 tester/rtems/testing/bsps/xilinx_zynq_a9_qemu-cov.ini
> create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp-cov.ini
> 2.27.0
> devel mailing list
> devel at rtems.org
