[PATCH] rtems: Simplify rtems_signal_catch()
Gedare Bloom
gedare at rtems.org
Tue Mar 2 16:52:53 UTC 2021
These two simplifications look ok
On Tue, Mar 2, 2021 at 6:11 AM Sebastian Huber
> In uniprocessor configurations, we can simplify rtems_signal_catch().
> Add a validation tests for the SMP special case.
> cpukit/rtems/src/signalcatch.c | 19 +-
> testsuites/validation/tc-signal-catch.c | 648 ++++++++++++++++++++----
> 2 files changed, 566 insertions(+), 101 deletions(-)
> diff --git a/cpukit/rtems/src/signalcatch.c b/cpukit/rtems/src/signalcatch.c
> index e80d2c082a..fffa6cc0e4 100644
> --- a/cpukit/rtems/src/signalcatch.c
> +++ b/cpukit/rtems/src/signalcatch.c
> @@ -58,17 +58,34 @@ rtems_status_code rtems_signal_catch(
> asr->handler = asr_handler;
> asr->mode_set = mode_set;
> +#if defined(RTEMS_SMP)
> if ( asr_handler == NULL ) {
> Chain_Node *node;
> - asr->signals_pending = 0;
> + * In SMP configurations, signals may be sent on other processors
> + * (interrupts or threads) in parallel. This will cause an inter-processor
> + * interrupt which may be blocked by the above interrupt disable.
> node = &api->Signal_action.Node;
> + _Assert( asr->signals_pending == 0 || !_Chain_Is_node_off_chain( node ) );
> if ( !_Chain_Is_node_off_chain( node ) ) {
> + asr->signals_pending = 0;
> _Chain_Extract_unprotected( node );
> _Chain_Set_off_chain( node );
> +#else
> + * In uniprocessor configurations, as soon as interrupts are disabled above
> + * nobody can send signals to the executing thread. So, pending signals at
> + * this point cannot appear.
> + _Assert( _Chain_Is_node_off_chain( node ) );
> + _Assert( asr->signals_pending == 0 );
> +#endif
> _Thread_State_release( executing, &lock_context );
> return RTEMS_SUCCESSFUL;
> diff --git a/testsuites/validation/tc-signal-catch.c b/testsuites/validation/tc-signal-catch.c
> index acca855ede..5cbb0e2eff 100644
> --- a/testsuites/validation/tc-signal-catch.c
> +++ b/testsuites/validation/tc-signal-catch.c
> @@ -53,6 +53,8 @@
> #endif
> #include <rtems.h>
> +#include <string.h>
> +#include <rtems/score/smpbarrier.h>
> #include <rtems/test.h>
> @@ -65,6 +67,12 @@
> +typedef enum {
> + RtemsSignalReqCatch_Pre_Pending_Yes,
> + RtemsSignalReqCatch_Pre_Pending_No,
> + RtemsSignalReqCatch_Pre_Pending_NA
> +} RtemsSignalReqCatch_Pre_Pending;
> typedef enum {
> RtemsSignalReqCatch_Pre_Handler_Invalid,
> RtemsSignalReqCatch_Pre_Handler_Valid,
> @@ -136,6 +144,16 @@ typedef enum {
> * @brief Test context for spec:/rtems/signal/req/catch test case.
> typedef struct {
> + rtems_id runner_id;
> + rtems_id worker_id;
> + uint32_t pending_signals;
> + SMP_barrier_Control barrier;
> + SMP_barrier_State runner_barrier_state;
> uint32_t default_handler_calls;
> uint32_t handler_calls;
> @@ -155,7 +173,7 @@ typedef struct {
> * @brief This member defines the pre-condition states for the next action.
> - size_t pcs[ 5 ];
> + size_t pcs[ 6 ];
> * @brief This member indicates if the test action loop is currently
> @@ -167,6 +185,12 @@ typedef struct {
> static RtemsSignalReqCatch_Context
> RtemsSignalReqCatch_Instance;
> +static const char * const RtemsSignalReqCatch_PreDesc_Pending[] = {
> + "Yes",
> + "No",
> + "NA"
> static const char * const RtemsSignalReqCatch_PreDesc_Handler[] = {
> "Invalid",
> "Valid",
> @@ -198,6 +222,7 @@ static const char * const RtemsSignalReqCatch_PreDesc_IntLvl[] = {
> static const char * const * const RtemsSignalReqCatch_PreDesc[] = {
> + RtemsSignalReqCatch_PreDesc_Pending,
> RtemsSignalReqCatch_PreDesc_Handler,
> RtemsSignalReqCatch_PreDesc_Preempt,
> RtemsSignalReqCatch_PreDesc_Timeslice,
> @@ -215,7 +240,11 @@ static void DefaultHandler( rtems_signal_set signal_set )
> ctx = T_fixture_context();
> ++ctx->default_handler_calls;
> - T_eq_u32( signal_set, 0xdeadbeef );
> + if ( ctx->pending_signals != 0 && ctx->default_handler_calls == 1 ) {
> + T_eq_u32( signal_set, 0x600df00d );
> + } else {
> + T_eq_u32( signal_set, 0xdeadbeef );
> static void SignalHandler( rtems_signal_set signal_set )
> @@ -233,7 +262,11 @@ static void SignalHandler( rtems_signal_set signal_set )
> T_rsc_success( sc );
> + if ( ctx->pending_signals != 0 && ctx->handler_calls == 1 ) {
> + } else {
> static void CheckHandlerMode( Context *ctx, rtems_mode mask, rtems_mode mode )
> @@ -244,6 +277,55 @@ static void CheckHandlerMode( Context *ctx, rtems_mode mask, rtems_mode mode )
> +static void Worker( rtems_task_argument arg )
> + Context *ctx;
> + SMP_barrier_State barrier_state;
> + ctx = (Context *) arg;
> + _SMP_barrier_State_initialize( &barrier_state );
> + while ( true ) {
> + rtems_status_code sc;
> + _SMP_barrier_Wait( &ctx->barrier, &barrier_state, 2 );
> + sc = rtems_signal_send( ctx->runner_id, 0x600df00d );
> + T_rsc_success( sc );
> +static void RtemsSignalReqCatch_Pre_Pending_Prepare(
> + RtemsSignalReqCatch_Context *ctx,
> + RtemsSignalReqCatch_Pre_Pending state
> + switch ( state ) {
> + case RtemsSignalReqCatch_Pre_Pending_Yes: {
> + * Where the system has more than one processor, when
> + * rtems_signal_catch() is called, the calling task shall have pending
> + * signals.
> + ctx->pending_signals = ( rtems_scheduler_get_processor_maximum() > 1 ) ? 1 : 0;
> + break;
> + case RtemsSignalReqCatch_Pre_Pending_No: {
> + * The calling task shall have no pending signals.
> + ctx->pending_signals = 0;
> + break;
> + case RtemsSignalReqCatch_Pre_Pending_NA:
> + break;
> static void RtemsSignalReqCatch_Pre_Handler_Prepare(
> RtemsSignalReqCatch_Pre_Handler state
> @@ -466,10 +548,10 @@ static void RtemsSignalReqCatch_Post_Send_Check(
> if ( ctx->catch_status == RTEMS_SUCCESSFUL ) {
> T_eq_u32( ctx->default_handler_calls, 0 );
> - T_eq_u32( ctx->handler_calls, 1 );
> + T_eq_u32( ctx->handler_calls, 1 + ctx->pending_signals );
> T_ne_u32( ctx->handler_mode, 0xffffffff );
> } else {
> - T_eq_u32( ctx->default_handler_calls, 1 );
> + T_eq_u32( ctx->default_handler_calls, 1 + ctx->pending_signals );
> T_eq_u32( ctx->handler_calls, 0 );
> T_eq_u32( ctx->handler_mode, 0xffffffff );
> @@ -490,7 +572,7 @@ static void RtemsSignalReqCatch_Post_Send_Check(
> } else {
> T_rsc_success( ctx->send_status );
> @@ -627,10 +709,60 @@ static void RtemsSignalReqCatch_Post_IntLvl_Check(
> +static void RtemsSignalReqCatch_Setup( RtemsSignalReqCatch_Context *ctx )
> + memset( ctx, 0, sizeof( *ctx ) );
> + ctx->runner_id = rtems_task_self();
> + _SMP_barrier_Control_initialize( &ctx->barrier );
> + _SMP_barrier_State_initialize( &ctx->runner_barrier_state );
> + if ( rtems_scheduler_get_processor_maximum() > 1 ) {
> + rtems_id scheduler_id;
> + sc = rtems_task_create(
> + rtems_build_name( 'W', 'O', 'R', 'K' ),
> + 1,
> + RTEMS_MINIMUM_STACK_SIZE,
> + RTEMS_DEFAULT_MODES,
> + RTEMS_DEFAULT_ATTRIBUTES,
> + &ctx->worker_id
> + T_assert_rsc_success( sc );
> + sc = rtems_scheduler_ident_by_processor( 1, &scheduler_id );
> + sc = rtems_task_set_scheduler( ctx->worker_id, scheduler_id, 1 );
> + sc = rtems_task_start(
> + ctx->worker_id,
> + Worker,
> + (rtems_task_argument) ctx
> +static void RtemsSignalReqCatch_Setup_Wrap( void *arg )
> + RtemsSignalReqCatch_Context *ctx;
> + ctx = arg;
> + ctx->in_action_loop = false;
> + RtemsSignalReqCatch_Setup( ctx );
> static void RtemsSignalReqCatch_Teardown( RtemsSignalReqCatch_Context *ctx )
> + if ( ctx->worker_id != 0 ) {
> + sc = rtems_task_delete( ctx->worker_id );
> sc = rtems_signal_catch( NULL, RTEMS_DEFAULT_MODES );
> @@ -658,7 +790,7 @@ static size_t RtemsSignalReqCatch_Scope( void *arg, char *buf, size_t n )
> static T_fixture RtemsSignalReqCatch_Fixture = {
> - .setup = NULL,
> + .setup = RtemsSignalReqCatch_Setup_Wrap,
> .stop = NULL,
> .teardown = RtemsSignalReqCatch_Teardown_Wrap,
> .scope = RtemsSignalReqCatch_Scope,
> @@ -890,11 +1022,236 @@ static const uint8_t RtemsSignalReqCatch_TransitionMap[][ 6 ] = {
> RtemsSignalReqCatch_Post_Timeslice_No,
> RtemsSignalReqCatch_Post_ASR_No,
> RtemsSignalReqCatch_Post_IntLvl_Positive
> + RtemsSignalReqCatch_Post_Status_Ok,
> + RtemsSignalReqCatch_Post_Send_NotDef,
> + RtemsSignalReqCatch_Post_Preempt_Yes,
> + RtemsSignalReqCatch_Post_Timeslice_Yes,
> + RtemsSignalReqCatch_Post_ASR_Yes,
> + RtemsSignalReqCatch_Post_IntLvl_Zero
> + RtemsSignalReqCatch_Post_Status_NotImplIntLvl,
> + RtemsSignalReqCatch_Post_IntLvl_Positive
> + RtemsSignalReqCatch_Post_ASR_No,
> + RtemsSignalReqCatch_Post_Timeslice_No,
> + RtemsSignalReqCatch_Post_Status_NotImplNoPreempt,
> + RtemsSignalReqCatch_Post_Preempt_No,
> + RtemsSignalReqCatch_Post_Send_New,
> static const struct {
> uint8_t Skip : 1;
> + uint8_t Pre_Pending_NA : 1;
> uint8_t Pre_Handler_NA : 1;
> uint8_t Pre_Preempt_NA : 1;
> uint8_t Pre_Timeslice_NA : 1;
> @@ -902,69 +1259,133 @@ static const struct {
> uint8_t Pre_IntLvl_NA : 1;
> } RtemsSignalReqCatch_TransitionInfo[] = {
> - 0, 0, 0, 0, 0, 0
> + 0, 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> - 0, 0, 0, 0, 0, 0
> @@ -988,7 +1409,17 @@ static void RtemsSignalReqCatch_Action( RtemsSignalReqCatch_Context *ctx )
> rtems_mode mode;
> - ctx->catch_status = rtems_signal_catch( ctx->handler, ctx->mode );
> + if ( ctx->pending_signals != 0 ) {
> + rtems_interrupt_level level;
> + rtems_interrupt_local_disable(level);
> + _SMP_barrier_Wait( &ctx->barrier, &ctx->runner_barrier_state, 2 );
> + ctx->catch_status = rtems_signal_catch( ctx->handler, ctx->mode );
> + rtems_interrupt_local_enable(level);
> + } else {
> sc = rtems_task_mode( ctx->normal_mode, RTEMS_ALL_MODE_MASKS, &mode );
> @@ -1012,13 +1443,14 @@ T_TEST_CASE_FIXTURE( RtemsSignalReqCatch, &RtemsSignalReqCatch_Fixture )
> index = 0;
> for (
> - ctx->pcs[ 0 ] = RtemsSignalReqCatch_Pre_Handler_Invalid;
> - ctx->pcs[ 0 ] < RtemsSignalReqCatch_Pre_Handler_NA;
> + ctx->pcs[ 0 ] = RtemsSignalReqCatch_Pre_Pending_Yes;
> + ctx->pcs[ 0 ] < RtemsSignalReqCatch_Pre_Pending_NA;
> ++ctx->pcs[ 0 ]
> - if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_Handler_NA ) {
> - ctx->pcs[ 0 ] = RtemsSignalReqCatch_Pre_Handler_NA;
> - index += ( RtemsSignalReqCatch_Pre_Handler_NA - 1 )
> + if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_Pending_NA ) {
> + ctx->pcs[ 0 ] = RtemsSignalReqCatch_Pre_Pending_NA;
> + index += ( RtemsSignalReqCatch_Pre_Pending_NA - 1 )
> + * RtemsSignalReqCatch_Pre_Handler_NA
> * RtemsSignalReqCatch_Pre_Preempt_NA
> * RtemsSignalReqCatch_Pre_Timeslice_NA
> * RtemsSignalReqCatch_Pre_ASR_NA
> @@ -1026,88 +1458,104 @@ T_TEST_CASE_FIXTURE( RtemsSignalReqCatch, &RtemsSignalReqCatch_Fixture )
> for (
> - ctx->pcs[ 1 ] = RtemsSignalReqCatch_Pre_Preempt_Yes;
> - ctx->pcs[ 1 ] < RtemsSignalReqCatch_Pre_Preempt_NA;
> + ctx->pcs[ 1 ] = RtemsSignalReqCatch_Pre_Handler_Invalid;
> + ctx->pcs[ 1 ] < RtemsSignalReqCatch_Pre_Handler_NA;
> ++ctx->pcs[ 1 ]
> - if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_Preempt_NA ) {
> - ctx->pcs[ 1 ] = RtemsSignalReqCatch_Pre_Preempt_NA;
> - index += ( RtemsSignalReqCatch_Pre_Preempt_NA - 1 )
> + if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_Handler_NA ) {
> + ctx->pcs[ 1 ] = RtemsSignalReqCatch_Pre_Handler_NA;
> + index += ( RtemsSignalReqCatch_Pre_Handler_NA - 1 )
> + * RtemsSignalReqCatch_Pre_Preempt_NA
> * RtemsSignalReqCatch_Pre_IntLvl_NA;
> for (
> - ctx->pcs[ 2 ] = RtemsSignalReqCatch_Pre_Timeslice_Yes;
> - ctx->pcs[ 2 ] < RtemsSignalReqCatch_Pre_Timeslice_NA;
> + ctx->pcs[ 2 ] = RtemsSignalReqCatch_Pre_Preempt_Yes;
> + ctx->pcs[ 2 ] < RtemsSignalReqCatch_Pre_Preempt_NA;
> ++ctx->pcs[ 2 ]
> - if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_Timeslice_NA ) {
> - ctx->pcs[ 2 ] = RtemsSignalReqCatch_Pre_Timeslice_NA;
> - index += ( RtemsSignalReqCatch_Pre_Timeslice_NA - 1 )
> + if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_Preempt_NA ) {
> + ctx->pcs[ 2 ] = RtemsSignalReqCatch_Pre_Preempt_NA;
> + index += ( RtemsSignalReqCatch_Pre_Preempt_NA - 1 )
> + * RtemsSignalReqCatch_Pre_Timeslice_NA
> for (
> - ctx->pcs[ 3 ] = RtemsSignalReqCatch_Pre_ASR_Yes;
> - ctx->pcs[ 3 ] < RtemsSignalReqCatch_Pre_ASR_NA;
> + ctx->pcs[ 3 ] = RtemsSignalReqCatch_Pre_Timeslice_Yes;
> + ctx->pcs[ 3 ] < RtemsSignalReqCatch_Pre_Timeslice_NA;
> ++ctx->pcs[ 3 ]
> - if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_ASR_NA ) {
> - ctx->pcs[ 3 ] = RtemsSignalReqCatch_Pre_ASR_NA;
> - index += ( RtemsSignalReqCatch_Pre_ASR_NA - 1 )
> + if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_Timeslice_NA ) {
> + ctx->pcs[ 3 ] = RtemsSignalReqCatch_Pre_Timeslice_NA;
> + index += ( RtemsSignalReqCatch_Pre_Timeslice_NA - 1 )
> + * RtemsSignalReqCatch_Pre_ASR_NA
> for (
> - ctx->pcs[ 4 ] = RtemsSignalReqCatch_Pre_IntLvl_Zero;
> - ctx->pcs[ 4 ] < RtemsSignalReqCatch_Pre_IntLvl_NA;
> + ctx->pcs[ 4 ] = RtemsSignalReqCatch_Pre_ASR_Yes;
> + ctx->pcs[ 4 ] < RtemsSignalReqCatch_Pre_ASR_NA;
> ++ctx->pcs[ 4 ]
> - if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_IntLvl_NA ) {
> - ctx->pcs[ 4 ] = RtemsSignalReqCatch_Pre_IntLvl_NA;
> - index += ( RtemsSignalReqCatch_Pre_IntLvl_NA - 1 );
> + if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_ASR_NA ) {
> + ctx->pcs[ 4 ] = RtemsSignalReqCatch_Pre_ASR_NA;
> + index += ( RtemsSignalReqCatch_Pre_ASR_NA - 1 )
> + * RtemsSignalReqCatch_Pre_IntLvl_NA;
> - if ( RtemsSignalReqCatch_TransitionInfo[ index ].Skip ) {
> + for (
> + ctx->pcs[ 5 ] = RtemsSignalReqCatch_Pre_IntLvl_Zero;
> + ctx->pcs[ 5 ] < RtemsSignalReqCatch_Pre_IntLvl_NA;
> + ++ctx->pcs[ 5 ]
> + if ( RtemsSignalReqCatch_TransitionInfo[ index ].Pre_IntLvl_NA ) {
> + ctx->pcs[ 5 ] = RtemsSignalReqCatch_Pre_IntLvl_NA;
> + index += ( RtemsSignalReqCatch_Pre_IntLvl_NA - 1 );
> + if ( RtemsSignalReqCatch_TransitionInfo[ index ].Skip ) {
> + ++index;
> + continue;
> + RtemsSignalReqCatch_Prepare( ctx );
> + RtemsSignalReqCatch_Pre_Pending_Prepare( ctx, ctx->pcs[ 0 ] );
> + RtemsSignalReqCatch_Pre_Handler_Prepare( ctx, ctx->pcs[ 1 ] );
> + RtemsSignalReqCatch_Pre_Preempt_Prepare( ctx, ctx->pcs[ 2 ] );
> + RtemsSignalReqCatch_Pre_Timeslice_Prepare( ctx, ctx->pcs[ 3 ] );
> + RtemsSignalReqCatch_Pre_ASR_Prepare( ctx, ctx->pcs[ 4 ] );
> + RtemsSignalReqCatch_Pre_IntLvl_Prepare( ctx, ctx->pcs[ 5 ] );
> + RtemsSignalReqCatch_Action( ctx );
> + RtemsSignalReqCatch_Post_Status_Check(
> + ctx,
> + RtemsSignalReqCatch_TransitionMap[ index ][ 0 ]
> + RtemsSignalReqCatch_Post_Send_Check(
> + ctx,
> + RtemsSignalReqCatch_TransitionMap[ index ][ 1 ]
> + RtemsSignalReqCatch_Post_Preempt_Check(
> + ctx,
> + RtemsSignalReqCatch_TransitionMap[ index ][ 2 ]
> + RtemsSignalReqCatch_Post_Timeslice_Check(
> + ctx,
> + RtemsSignalReqCatch_TransitionMap[ index ][ 3 ]
> + RtemsSignalReqCatch_Post_ASR_Check(
> + ctx,
> + RtemsSignalReqCatch_TransitionMap[ index ][ 4 ]
> + RtemsSignalReqCatch_Post_IntLvl_Check(
> + ctx,
> + RtemsSignalReqCatch_TransitionMap[ index ][ 5 ]
> ++index;
> - continue;
> - RtemsSignalReqCatch_Prepare( ctx );
> - RtemsSignalReqCatch_Pre_Handler_Prepare( ctx, ctx->pcs[ 0 ] );
> - RtemsSignalReqCatch_Pre_Preempt_Prepare( ctx, ctx->pcs[ 1 ] );
> - RtemsSignalReqCatch_Pre_Timeslice_Prepare( ctx, ctx->pcs[ 2 ] );
> - RtemsSignalReqCatch_Pre_ASR_Prepare( ctx, ctx->pcs[ 3 ] );
> - RtemsSignalReqCatch_Pre_IntLvl_Prepare( ctx, ctx->pcs[ 4 ] );
> - RtemsSignalReqCatch_Action( ctx );
> - RtemsSignalReqCatch_Post_Status_Check(
> - ctx,
> - RtemsSignalReqCatch_TransitionMap[ index ][ 0 ]
> - RtemsSignalReqCatch_Post_Send_Check(
> - ctx,
> - RtemsSignalReqCatch_TransitionMap[ index ][ 1 ]
> - RtemsSignalReqCatch_Post_Preempt_Check(
> - ctx,
> - RtemsSignalReqCatch_TransitionMap[ index ][ 2 ]
> - RtemsSignalReqCatch_Post_Timeslice_Check(
> - ctx,
> - RtemsSignalReqCatch_TransitionMap[ index ][ 3 ]
> - RtemsSignalReqCatch_Post_ASR_Check(
> - ctx,
> - RtemsSignalReqCatch_TransitionMap[ index ][ 4 ]
> - RtemsSignalReqCatch_Post_IntLvl_Check(
> - ctx,
> - RtemsSignalReqCatch_TransitionMap[ index ][ 5 ]
> - ++index;
> 2.26.2
> devel mailing list
> devel at rtems.org
