[PATCH 01/22] tester: Update to support new build system
Tue Mar 2 16:54:40 UTC 2021
On Tue, Mar 2, 2021 at 8:52 AM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Mar 2, 2021 at 9:46 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Mar 1, 2021 at 1:01 PM Alex White <alexanderjwhite at gmail.com> wrote:
>> > The tester configurations had not been updated to match the paths and
>> > conventions used by the new build system. These have been updated,
>> > and a few more libraries have been enabled in symbol-sets.ini.
>> >  tester/rtems/testing/bsps/griscv-sis-cov.ini  |  4 +-
>> >  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |  4 +-
>> >  tester/rtems/testing/bsps/leon3-sis-cov.ini   |  4 +-
>> >  tester/rtems/testing/coverage/symbol-sets.ini | 91 ++++++++++---------
>> >  4 files changed, 52 insertions(+), 51 deletions(-)
>> > diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini b/tester/rtems/testing/bsps/griscv-sis-cov.ini
>> > index 7249af6..e8de95f 100644
>> > --- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
>> > +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
>> > @@ -35,7 +35,7 @@
>> >  bsp            = griscv-sis
>> >  arch           = riscv
>> >  tester         = %{_rtscripts}/run.cfg
>> > -target         = riscv-rtems5
>> > +target         = riscv
>> These are the only ini files that define this target? With this
>> change, target is same as arch. Is target needed? I can't immediately
>> tell where it gets used later?  'target' is usually understood as the
>> binutil/gcc target triplet, so if the triplet is not being used, the
>> variable should be less misleading. covoar_target might be better if
>> this variable is needed in covar? I don't see it in any other
>> non-coverage ini files though, so maybe it is not needed at all?
> covoar originally used nm, addr2line, and objdump. This has been reduced to
> objdump but it needs the target name to be able to invoke that. At this point,
> the target has to be provided or covoar has to have rtems6 hard-coded and
> add rtems6 to the architecture.
> Is there a variable in the tester to set this to?
>> >  bsp_run_cmd    = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
>> >  bsp_run_opts   = -nouartrx -r -tlim 300 s -m 4 -cov
>> > -bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
>> > +bsp_covoar_cmd = -T riscv-rtems6 -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
>> what about:
>> -T %{arch}-rtems%{rtems_version}
>> We should be limiting hard-coding version numbers.
> If that works, I would be happy.
I t hink it might be %{bsp_arch} --- see bsp_run_cmd above ;)
>> > diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> > index 3b183e6..3d558db 100644
>> > --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> > +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> > @@ -34,8 +34,8 @@
>> >  [leon3-qemu-cov]
>> >  bsp               = leon3-qemu
>> >  arch              = sparc
>> > -target            = sparc-rtems5
>> > +target            = sparc
>> >  tester            = %{_rtscripts}/qemu.cfg
>> >  bsp_qemu_opts     = %{qemu_opts_base} %{qemu_opts_serial} -M leon3_generic
>> >  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>> > +bsp_covoar_cmd    = -T sparc-rtems6 -S %{bsp_symbol_path} -E %{cov_explanations}
>> > diff --git a/tester/rtems/testing/bsps/leon3-sis-cov.ini b/tester/rtems/testing/bsps/leon3-sis-cov.ini
>> > index 626d314..66dae87 100644
>> > --- a/tester/rtems/testing/bsps/leon3-sis-cov.ini
>> > +++ b/tester/rtems/testing/bsps/leon3-sis-cov.ini
>> > @@ -35,7 +35,7 @@
>> >  bsp            = leon3-sis
>> >  arch           = sparc
>> > +target         = sparc
>> >  bsp_run_opts   = -leon3 -nouartrx -r -tlim 200 s -cov
>> > +bsp_covoar_cmd = -T sparc-rtems6 -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
>> > diff --git a/tester/rtems/testing/coverage/symbol-sets.ini b/tester/rtems/testing/coverage/symbol-sets.ini
>> > index 8f85533..9617dd8 100644
>> > --- a/tester/rtems/testing/coverage/symbol-sets.ini
>> > +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>> > @@ -29,50 +29,51 @@
>> >  [symbol-sets]
>> > -sets = score,rtems,sapi,libdl,posix,librfs,libdosfs,libdevfs,libimfs,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>> > +sets = score,rtems,sapi,posix,librfs,libpipe,libdosfs,libimfs,libjffs2,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libuntar,libblock,libcrypt,libmd,libstdthreads
>> >  [libraries]
>> > -score         = @BUILD-TARGET@/c/@BSP@/cpukit/score/src
>> > -rtems         = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/src
>> > -sapi          = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/src
>> > -libdl         = @BUILD-TARGET@/c/@BSP@/cpukit/libdl
>> > -posix         = @BUILD-TARGET@/c/@BSP@/cpukit/posix/src
>> > -librfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/rfs
>> > -libdosfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/dosfs
>> > -libdevfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/devfs
>> > -libimfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/imfs
>> > -#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs
>> > -#libjffs2      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs
>> > -#dtc           = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt
>> > -#libdrvmgr     = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr
>> > -#libi2c        = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c
>> > -#libcsupport   = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/src
>> > -libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/bspcmdline
>> > -libcpuuse     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/cpuuse
>> > -libstackchk   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stackchk
>> > -libfsmount    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/fsmount
>> > -libstringto   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stringto
>> > -libdevnull    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/devnull
>> > -libdumpbuf    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/dumpbuf
>> > -#libcapture    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libdummy      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libmonitor    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libmouse      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libmw-fb      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#librtemsfdt   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libserdbg     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libshell      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libuntar      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libutf8proc   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libuuid       = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -#libxz         = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> > -libblock      = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/src
>> > -#libpci        = @BUILD-TARGET@/c/@BSP@/cpukit/libpci
>> > -#librpc        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
>> > -#libxdr        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
>> > -#libcrypt      = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt
>> > -#libmd         = @BUILD-TARGET@/c/@BSP@/cpukit/libmd
>> > -#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/libstdthreads
>> > -#zlib          = @BUILD-TARGET@/c/@BSP@/cpukit/zlib
>> > +score         = @BUILD-TARGET@/@BSP@/cpukit/score/src
>> > +rtems         = @BUILD-TARGET@/@BSP@/cpukit/rtems/src
>> > +sapi          = @BUILD-TARGET@/@BSP@/cpukit/sapi/src
>> > +libdl         = @BUILD-TARGET@/@BSP@/cpukit/libdl
>> > +posix         = @BUILD-TARGET@/@BSP@/cpukit/posix/src
>> > +librfs        = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/rfs
>> > +libpipe       = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/pipe
>> > +libdosfs      = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/dosfs
>> > +#libdevfs      = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/devfs
>> > +libimfs       = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/imfs
>> > +#libdefaultsfs = @BUiLD-TARGET@/@BSP@/cpukit/libfs
>> > +libjffs2      = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/jffs2/src
>> > +#dtc           = @BUILD-TARGET@/@BSP@/cpukit/libfdt
>> > +#libdrvmgr     = @BUILD-TARGET@/@BSP@/cpukit/libdrvmgr
>> > +#libi2c        = @BUILD-TARGET@/@BSP@/cpukit/libi2c
>> > +libcsupport   = @BUILD-TARGET@/@BSP@/cpukit/libcsupport/src
>> > +libbspcmdline = @BUILD-TARGET@/@BSP@/cpukit/libmisc/bspcmdline
>> > +libcpuuse     = @BUILD-TARGET@/@BSP@/cpukit/libmisc/cpuuse
>> > +libstackchk   = @BUILD-TARGET@/@BSP@/cpukit/libmisc/stackchk
>> > +libfsmount    = @BUILD-TARGET@/@BSP@/cpukit/libmisc/fsmount
>> > +libstringto   = @BUILD-TARGET@/@BSP@/cpukit/libmisc/stringto
>> > +libdevnull    = @BUILD-TARGET@/@BSP@/cpukit/libmisc/devnull
>> > +libdumpbuf    = @BUILD-TARGET@/@BSP@/cpukit/libmisc/dumpbuf
>> > +#libcapture    = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libdummy      = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libmonitor    = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libmouse      = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libmw-fb      = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libredirector = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#librtemsfdt   = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libserdbg     = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libshell      = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libtestsupport= @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +libuntar      = @BUILD-TARGET@/@BSP@/cpukit/libmisc/untar
>> > +#libutf8proc   = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libuuid       = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +#libxz         = @BUILD-TARGET@/@BSP@/cpukit/libmisc
>> > +libblock      = @BUILD-TARGET@/@BSP@/cpukit/libblock/src
>> > +#libpci        = @BUILD-TARGET@/@BSP@/cpukit/libpci
>> > +#librpc        = @BUILD-TARGET@/@BSP@/cpukit/librpc
>> > +#libxdr        = @BUILD-TARGET@/@BSP@/cpukit/librpc
>> > +libcrypt      = @BUILD-TARGET@/@BSP@/cpukit/libcrypt
>> > +libmd         = @BUILD-TARGET@/@BSP@/cpukit/libmd
>> > +libstdthreads = @BUILD-TARGET@/@BSP@/cpukit/libstdthreads
>> > +#zlib          = @BUILD-TARGET@/@BSP@/cpukit/zlib
>> > 2.27.0
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
