[PATCH 01/22] tester: Update to support new build system
Chris Johns
chrisj at rtems.org
Tue Mar 2 22:47:58 UTC 2021
On 3/3/21 3:54 am, Gedare Bloom wrote:
> On Tue, Mar 2, 2021 at 8:52 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Mar 2, 2021 at 9:46 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Mon, Mar 1, 2021 at 1:01 PM Alex White <alexanderjwhite at gmail.com> wrote:
>>>> The tester configurations had not been updated to match the paths and
>>>> conventions used by the new build system. These have been updated,
>>>> and a few more libraries have been enabled in symbol-sets.ini.
>>>> tester/rtems/testing/bsps/griscv-sis-cov.ini | 4 +-
>>>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 4 +-
>>>> tester/rtems/testing/bsps/leon3-sis-cov.ini | 4 +-
>>>> tester/rtems/testing/coverage/symbol-sets.ini | 91 ++++++++++---------
>>>> 4 files changed, 52 insertions(+), 51 deletions(-)
>>>> diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini b/tester/rtems/testing/bsps/griscv-sis-cov.ini
>>>> index 7249af6..e8de95f 100644
>>>> --- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
>>>> +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
>>>> @@ -35,7 +35,7 @@
>>>> bsp = griscv-sis
>>>> arch = riscv
>>>> tester = %{_rtscripts}/run.cfg
>>>> -target = riscv-rtems5
>>>> +target = riscv
What is this being used for? I can only it present in the cov scripts.
>>> These are the only ini files that define this target? With this
>>> change, target is same as arch. Is target needed? I can't immediately
>>> tell where it gets used later? 'target' is usually understood as the
>>> binutil/gcc target triplet, so if the triplet is not being used, the
>>> variable should be less misleading. covoar_target might be better if
>>> this variable is needed in covar? I don't see it in any other
>>> non-coverage ini files though, so maybe it is not needed at all?
>> covoar originally used nm, addr2line, and objdump. This has been reduced to
>> objdump but it needs the target name to be able to invoke that. At this point,
>> the target has to be provided or covoar has to have rtems6 hard-coded and
>> add rtems6 to the architecture.
>> Is there a variable in the tester to set this to?
>>>> bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
>>>> bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
>>>> -bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
>>>> +bsp_covoar_cmd = -T riscv-rtems6 -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
>>> what about:
>>> -T %{arch}-rtems%{rtems_version}
>>> We should be limiting hard-coding version numbers.
>> If that works, I would be happy.
> I t hink it might be %{bsp_arch} --- see bsp_run_cmd above ;)
Do you need the option? There are other tools in rtems-tool that determine the
exec-prefix. Could the toolkit's support in `rtemstoolkit/rld-cc.h` help?
We knows the arch from the machine type in the ELF file and the toolkit should
know the version. The nice thing about covoar is it keyed into the version.
