Status for open projects for gsoc
Tue Mar 2 20:46:43 UTC 2021
On Tue, Mar 2, 2021 at 1:50 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Mar 2, 2021 at 12:37 PM Joel Sherrill <joel at rtems.org> wrote:
> > On Tue, Mar 2, 2021 at 12:47 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Tue, Mar 2, 2021 at 11:25 AM Dev Agrawal <dev9893186747 at gmail.com>
> wrote:
> >> > Hello everyone,
> >> > I am interested in contributing to a few topics but I don't know what
> is the current status and future enhancements you are looking for so if you
> can guide me it would be a big help.
> >> > 1. #3333  Automate Conversion of Newlib Markup to Sphinx : To begin
> with the sphinx-quickstart process, doI have to make a build directory
> under the source directory which I made during the hello world task or
> normal root directory?
> >> This is done in a different repo: https://git.rtems.org/rtems-docs/
> >> @Joel Sherrill Do you know what is status on this project?
> > The script to do the conversion was finished by the student. I
> experimented
> > with including the generated output in our POSIX guide. But we never
> figured
> > out how to incorporate running it as part of rtems-docs in maintainer
> mode. We have
> > a process issue there and defining when the output is regenerated.
> OK, then I guess there isn't enough coding work to justify a GSoC
> anymore? I will update that ticket. Where is the conversion script
> located?
https://github.com/dh0072/NewlibMarkup2SphinxConverter
I wrote a simple script to driverunning that over newlib and generating
rst files for each service documented in newlib.
We need an accepted technical solution for regenerating them and
organizing the output in our manual. This shouldn't be hard.
We got wrapped around the axle discussing could we automatically
trigger regeneration on updates to newlib. When would it happen?
I'm prone to think that newlib's documentation changes so infrequently,
that picking it up sporadically and as part of going slushy before branching
is probably sufficient.
Technically, the waf could have a maintainer mode where is passed
a source directory for newlib and triggers regeneration if a source file
has changed. When maintainer mode is run is the question. But we need
the maintainer mode settled first.
> >> > 2. #3850 Modular Network Stacks :
> >> This project is currently being worked on by a developer. @Vijay Kumar
> >> Banerjee do you think there is anything that a student might be able
> >> to contribute toward this effort under a GSoC Project?
> > +1
Answering myself. This project has a lot of pieces and I'm sure Vijay could
use help on the drivers that we know can be tested on simulators and cheap
hardware. I think Vijay would have to have a repo and lwip building at
least to
be able to leverage help on the list of drivers we have collected.
I'd want to be sure that enough were testable on a simulator to be a good
project. Getting things to compile isn't enough for GSoC. But I think
we might have 3-4 NICs identified for LWIP with BSPs that run on Qemu.
--joel
> >> > What would be a good start for these projects?
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210302/4fd1004f/attachment-0001.html>
