Status for open projects for gsoc
Gedare Bloom
gedare at rtems.org
Tue Mar 2 19:50:11 UTC 2021
On Tue, Mar 2, 2021 at 12:37 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Mar 2, 2021 at 12:47 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Mar 2, 2021 at 11:25 AM Dev Agrawal <dev9893186747 at gmail.com> wrote:
>> > Hello everyone,
>> > I am interested in contributing to a few topics but I don't know what is the current status and future enhancements you are looking for so if you can guide me it would be a big help.
>> > 1. #3333 Automate Conversion of Newlib Markup to Sphinx : To begin with the sphinx-quickstart process, doI have to make a build directory under the source directory which I made during the hello world task or normal root directory?
>> This is done in a different repo: https://git.rtems.org/rtems-docs/
>> @Joel Sherrill Do you know what is status on this project?
> The script to do the conversion was finished by the student. I experimented
> with including the generated output in our POSIX guide. But we never figured
> out how to incorporate running it as part of rtems-docs in maintainer mode. We have
> a process issue there and defining when the output is regenerated.
OK, then I guess there isn't enough coding work to justify a GSoC
anymore? I will update that ticket. Where is the conversion script
located?
>> > 2. #3850 Modular Network Stacks :
>> This project is currently being worked on by a developer. @Vijay Kumar
>> Banerjee do you think there is anything that a student might be able
>> to contribute toward this effort under a GSoC Project?
> +1
>> > What would be a good start for these projects?
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
