Need help in deciding GSoC project also want to know project Scope
    Prateek Pardeshi
    prateekp99 at zoho.com
    Tue Mar  2 23:36:11 UTC 2021
Hi Gedare,
---- On Tue, 02 Mar 2021 22:19:26 +0530 Gedare Bloom <gedare at rtems.org> wrote ----
 > Hi Prateek,
 > On Mon, Mar 1, 2021 at 10:31 PM Prateek Pardeshi <prateekp99 at zoho.com> wrote:
 > > Hi everyone,
 > > I have decided following projects to work on this Summer. Please let me know about the scope of the project, whether it's feasible to work during GSoC.
 > > 1. https://devel.rtems.org/wiki/Developer/Projects/Open/UsingClang
 > > 2. Ticket 4182: https://devel.rtems.org/ticket/4182
 > > Reason for choosing projects with LLVM:
 > > I worked as a fellow under Dr.Michael Kruse, maintainer of LLVM Compiler(Polly), also I am contributor at LLVM Compiler, specifically Polly, which is a loop optimiser written in C language. I'm familiar with the LLVM community and the working/debugging/building/issues of LLVM compiler.
 > > Recently I worked on refabricating reference-counting used for memory management to C++ binding.
 > > This project will provide me an opportunity to work on something new while contributing to the Open Source.
 > Super, and welcome. We now have a much-revised build system that
 > should be better able to work with llvm. There are scattered efforts
 > that have shown how to compile RTEMS with clang for a couple of
 > targets (sparc, riscv), and it would be a great effort to try to unify
 > the support and integrate to our development tools.
 > We have a Python-based tool (RTEMS Source Builder (RSB)) for building
 > host/cross compiler toolchains (and orchestrating other builds):
 > https://git.rtems.org/rtems-source-builder/
 > Our documentation on the build system and RSB are fairly robust, and
 > may be a good place for you to start building some knowledge:
 > https://docs.rtems.org/branches/master/user/rsb/index.html
 > https://docs.rtems.org/branches/master/user/bld/index.html
 > We can probably get input from people who have managed to build a
 > clang toolchain. I have run clang-analyzer over RTEMS as well in the
 > past. It should be a good time now to get the llvm/clang
 > infrastructure well-integrated to our development ecosystem.
Thanks for your response. Is this idea appropriate enough to work during GSoC or should I start exploring other Projects?
 > > Looking forward to hear!
 > > Thanks & Regards,
 > > Prateek Pardeshi
 > > devel mailing list
 > > devel at rtems.org
