[PATCH 01/22] tester: Update to support new build system
Chris Johns
chrisj at rtems.org
Wed Mar 3 00:57:42 UTC 2021
On 3/3/21 10:06 am, Joel Sherrill wrote:
> On Tue, Mar 2, 2021 at 4:48 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 3/3/21 3:54 am, Gedare Bloom wrote:
> > On Tue, Mar 2, 2021 at 8:52 AM Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
> >> On Tue, Mar 2, 2021 at 9:46 AM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> >>> On Mon, Mar 1, 2021 at 1:01 PM Alex White <alexanderjwhite at gmail.com
> <mailto:alexanderjwhite at gmail.com>> wrote:
> >>>> The tester configurations had not been updated to match the paths and
> >>>> conventions used by the new build system. These have been updated,
> >>>> and a few more libraries have been enabled in symbol-sets.ini.
> >>>> tester/rtems/testing/bsps/griscv-sis-cov.ini | 4 +-
> >>>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 4 +-
> >>>> tester/rtems/testing/bsps/leon3-sis-cov.ini | 4 +-
> >>>> tester/rtems/testing/coverage/symbol-sets.ini | 91 ++++++++++---------
> >>>> 4 files changed, 52 insertions(+), 51 deletions(-)
> >>>> diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> >>>> index 7249af6..e8de95f 100644
> >>>> --- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> >>>> +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> >>>> @@ -35,7 +35,7 @@
> >>>> bsp = griscv-sis
> >>>> arch = riscv
> >>>> tester = %{_rtscripts}/run.cfg
> >>>> -target = riscv-rtems5
> >>>> +target = riscv
> What is this being used for? I can only it present in the cov scripts.
> See below.
> >>> These are the only ini files that define this target? With this
> >>> change, target is same as arch. Is target needed? I can't immediately
> >>> tell where it gets used later? 'target' is usually understood as the
> >>> binutil/gcc target triplet, so if the triplet is not being used, the
> >>> variable should be less misleading. covoar_target might be better if
> >>> this variable is needed in covar? I don't see it in any other
> >>> non-coverage ini files though, so maybe it is not needed at all?
> >> covoar originally used nm, addr2line, and objdump. This has been reduced to
> >> objdump but it needs the target name to be able to invoke that. At this
> point,
> >> the target has to be provided or covoar has to have rtems6 hard-coded and
> >> add rtems6 to the architecture.
> >> Is there a variable in the tester to set this to?
> >>>> bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> >>>> bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
> >>>> -bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
> >>>> +bsp_covoar_cmd = -T riscv-rtems6 -S %{bsp_symbol_path} -E
> >>> what about:
> >>> -T %{arch}-rtems%{rtems_version}
> >>> We should be limiting hard-coding version numbers.
> >> If that works, I would be happy.
> > I t hink it might be %{bsp_arch} --- see bsp_run_cmd above ;)
> Do you need the option? There are other tools in rtems-tool that determine the
> exec-prefix. Could the toolkit's support in `rtemstoolkit/rld-cc.h` help?
> We knows the arch from the machine type in the ELF file and the toolkit should
> know the version. The nice thing about covoar is it keyed into the version.
> Can you get the GNU target? Knowing the architecture is only a bit of the problem?
> I didn't spot anything in rtemstoolkit which would give you CPU-rtems[567]...
> If you have an example, great.
There is no generic support for tools other than cc and ld at the moment but it
could be added to rld-cc.[h,cpp]. I suggest adding a call:
void
make_tool_command(const std::string tool_name,
rld::process::arg_container& args)
std::string cmd = tool_name;
if (!exec_prefix.empty ())
cmd = exec_prefix + "-rtems" + rld::rtems::version () + '-' + cmd;
args.push_back (cmd);
... and then updating `make_cc_command` and `make_ld_command` to use this call.
An example of using the support with suitable command line options is ...
https://git.rtems.org/rtems-tools/tree/linkers/rtems-ld.cpp#n413
https://git.rtems.org/rtems-tools/tree/linkers/rtems-ld.cpp#n278
Then exec'ing a tool ...
https://git.rtems.org/rtems-tools/tree/linkers/rtems-syms.cpp#n307
Does help and make sense?
