[PATCH 01/22] tester: Update to support new build system
Joel Sherrill
joel at rtems.org
Tue Mar 2 23:06:51 UTC 2021
On Tue, Mar 2, 2021 at 4:48 PM Chris Johns <chrisj at rtems.org> wrote:
> On 3/3/21 3:54 am, Gedare Bloom wrote:
> > On Tue, Mar 2, 2021 at 8:52 AM Joel Sherrill <joel at rtems.org> wrote:
> >> On Tue, Mar 2, 2021 at 9:46 AM Gedare Bloom <gedare at rtems.org> wrote:
> >>> On Mon, Mar 1, 2021 at 1:01 PM Alex White <alexanderjwhite at gmail.com>
> wrote:
> >>>> The tester configurations had not been updated to match the paths and
> >>>> conventions used by the new build system. These have been updated,
> >>>> and a few more libraries have been enabled in symbol-sets.ini.
> >>>> tester/rtems/testing/bsps/griscv-sis-cov.ini | 4 +-
> >>>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 4 +-
> >>>> tester/rtems/testing/bsps/leon3-sis-cov.ini | 4 +-
> >>>> tester/rtems/testing/coverage/symbol-sets.ini | 91
> >>>> 4 files changed, 52 insertions(+), 51 deletions(-)
> >>>> diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> >>>> index 7249af6..e8de95f 100644
> >>>> --- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> >>>> +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> >>>> @@ -35,7 +35,7 @@
> >>>> bsp = griscv-sis
> >>>> arch = riscv
> >>>> tester = %{_rtscripts}/run.cfg
> >>>> -target = riscv-rtems5
> >>>> +target = riscv
> What is this being used for? I can only it present in the cov scripts.
See below.
> >>> These are the only ini files that define this target? With this
> >>> change, target is same as arch. Is target needed? I can't immediately
> >>> tell where it gets used later? 'target' is usually understood as the
> >>> binutil/gcc target triplet, so if the triplet is not being used, the
> >>> variable should be less misleading. covoar_target might be better if
> >>> this variable is needed in covar? I don't see it in any other
> >>> non-coverage ini files though, so maybe it is not needed at all?
> >> covoar originally used nm, addr2line, and objdump. This has been
> reduced to
> >> objdump but it needs the target name to be able to invoke that. At this
> point,
> >> the target has to be provided or covoar has to have rtems6 hard-coded
> and
> >> add rtems6 to the architecture.
> >> Is there a variable in the tester to set this to?
> >>>> bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> >>>> bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
> >>>> -bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
> >>>> +bsp_covoar_cmd = -T riscv-rtems6 -S %{bsp_symbol_path} -E
> >>> what about:
> >>> -T %{arch}-rtems%{rtems_version}
> >>> We should be limiting hard-coding version numbers.
> >> If that works, I would be happy.
> > I t hink it might be %{bsp_arch} --- see bsp_run_cmd above ;)
> Do you need the option? There are other tools in rtems-tool that determine
> the
> exec-prefix. Could the toolkit's support in `rtemstoolkit/rld-cc.h` help?
> We knows the arch from the machine type in the ELF file and the toolkit
> should
> know the version. The nice thing about covoar is it keyed into the version.
Can you get the GNU target? Knowing the architecture is only a bit of the
problem?
I didn't spot anything in rtemstoolkit which would give you
CPU-rtems[567]...
If you have an example, great.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210302/2ff8cad0/attachment-0001.html>
