[PATCH 1/4] score: Enforce CPU_STACK_ALIGNMENT requirements
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Mar 3 19:53:15 UTC 2021
Looks good.
Kinsey
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Sebastian Huber
Sent: Wednesday, March 3, 2021 02:40
To: devel at rtems.org
Subject: [PATCH 1/4] score: Enforce CPU_STACK_ALIGNMENT requirements
Clarify CPU_STACK_ALIGNMENT requirements in no_cpu port. Add static
assertion to enforce CPU_STACK_ALIGNMENT requirements.
.../score/cpu/bfin/include/rtems/score/cpu.h | 13 --------
.../score/cpu/lm32/include/rtems/score/cpu.h | 10 -------
.../score/cpu/m68k/include/rtems/score/cpu.h | 2 +-
.../score/cpu/mips/include/rtems/score/cpu.h | 9 ------
.../score/cpu/moxie/include/rtems/score/cpu.h | 14 +--------
.../cpu/no_cpu/include/rtems/score/cpu.h | 9 +++---
.../score/cpu/or1k/include/rtems/score/cpu.h | 12 +-------
.../cpu/powerpc/include/rtems/score/cpu.h | 9 ------
cpukit/score/cpu/sh/include/rtems/score/cpu.h | 9 ------
.../cpu/sparc64/include/rtems/score/cpu.h | 7 -----
.../score/cpu/v850/include/rtems/score/cpu.h | 12 +-------
cpukit/score/src/percpuasm.c | 30 +++++++++----------
12 files changed, 22 insertions(+), 114 deletions(-)
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
index 44be6d7d54..d17dfbd30a 100644
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
@@ -292,19 +292,6 @@ typedef struct {
#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
- * This number corresponds to the byte alignment requirement for the
- * stack. This alignment requirement may be stricter than that for the
- * data types alignment specified by @ref CPU_ALIGNMENT. If the
- * @ref CPU_ALIGNMENT is strict enough for the stack, then this should be
- * set to 0.
- * @note This must be a power of 2 either 0 or greater than @ref CPU_ALIGNMENT.
- * Port Specific Information:
- * XXX document implementation including references if appropriate
#define CPU_STACK_ALIGNMENT 8
#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
index 7cf6359419..5c890de53e 100644
--- a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
@@ -401,16 +401,6 @@ extern Context_Control_fp _CPU_Null_fp_context;
- * Stack is software-managed
#define CPU_STACK_ALIGNMENT CPU_ALIGNMENT
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
index 5c1df94fc5..de7f8215bb 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
@@ -338,7 +338,7 @@ extern void* _VBR;
* from the Workspace.
-#define CPU_STACK_ALIGNMENT 0
+#define CPU_STACK_ALIGNMENT CPU_ALIGNMENT
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpu.h b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
index 04d33f5658..cdb0e64013 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
@@ -525,15 +525,6 @@ extern Context_Control_fp _CPU_Null_fp_context;
- * data types alignment specified by CPU_ALIGNMENT. If the CPU_ALIGNMENT
- * is strict enough for the stack, then this should be set to 0.
- * NOTE: This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
index c0a41c9db6..c857734a2e 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
@@ -247,19 +247,7 @@ typedef struct {
- * MOXIE Specific Information:
- * XXX
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index ea69a5b972..c067501502 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -592,17 +592,16 @@ extern Context_Control_fp _CPU_Null_fp_context;
- * set to 0.
+ * data types alignment specified by @ref CPU_ALIGNMENT.
- * NOTE: This must be a power of 2 either 0 or greater than @ref CPU_ALIGNMENT.
+ * NOTE: This must be a power of two and greater than or equal to
+ * @ref CPU_HEAP_ALIGNMENT.
+#define CPU_STACK_ALIGNMENT CPU_HEAP_ALIGNMENT
* The alignment of the interrupt stack in bytes.
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
index c1f94a71af..22acfd590e 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
@@ -237,17 +237,7 @@ typedef Context_Control CPU_Interrupt_frame;
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
index a40b378b6d..996b6f8e60 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
@@ -661,15 +661,6 @@ void ppc_set_interrupt_level( uint32_t level );
#define CPU_HEAP_ALIGNMENT (PPC_ALIGNMENT)
#define CPU_STACK_ALIGNMENT (PPC_STACK_ALIGNMENT)
diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpu.h b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
index 0782021b2f..0df6aa3f83 100644
--- a/cpukit/score/cpu/sh/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
@@ -358,15 +358,6 @@ void CPU_delay( uint32_t microseconds );
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
index 2701298733..e0f56b8e89 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
@@ -635,13 +635,6 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
* The alignment restrictions for the SPARC are not that strict but this
* should unsure that the stack is always sufficiently alignment that the
* window overflow, underflow, and flush routines can use double word loads
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpu.h b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
index a648931fb9..1921216e2d 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
@@ -255,20 +255,10 @@ typedef struct {
- * set to 0.
* The v850 has enough RAM where alignment to 16 may be desirable depending
* on the cache properties. But this remains to be demonstrated.
-#define CPU_STACK_ALIGNMENT 4
+#define CPU_STACK_ALIGNMENT 8
diff --git a/cpukit/score/src/percpuasm.c b/cpukit/score/src/percpuasm.c
index 9b0ce86c26..8414d3a7b4 100644
--- a/cpukit/score/src/percpuasm.c
+++ b/cpukit/score/src/percpuasm.c
@@ -30,29 +30,21 @@
#define _RTEMS_PERCPU_DEFINE_OFFSETS
+#define PER_CPU_IS_POWER_OF_TWO( value ) \
+ ( ( ( ( value ) - 1 ) & ( value ) ) == 0 )
- * In case a CPU port needs another alignment, then add this here and make sure
- * it is a power of two greater than or equal to two.
+ * The minimum alignment of two is due to the Heap Handler which uses the
+ * HEAP_PREV_BLOCK_USED flag to indicate that the previous block is used.
RTEMS_STATIC_ASSERT(
- CPU_ALIGNMENT == 2
- || CPU_ALIGNMENT == 4
- || CPU_ALIGNMENT == 8
- || CPU_ALIGNMENT == 16
- || CPU_ALIGNMENT == 32,
+ CPU_ALIGNMENT >= 2 && PER_CPU_IS_POWER_OF_TWO( CPU_ALIGNMENT ),
CPU_ALIGNMENT
- * In case a CPU port needs another heap alignment, then add this here and make
- * sure it is a power of two greater than or equal to two.
- CPU_HEAP_ALIGNMENT == 2
- || CPU_HEAP_ALIGNMENT == 4
- || CPU_HEAP_ALIGNMENT == 8
- || CPU_HEAP_ALIGNMENT == 16
- || CPU_HEAP_ALIGNMENT == 32,
+ CPU_HEAP_ALIGNMENT >= 2 && PER_CPU_IS_POWER_OF_TWO( CPU_HEAP_ALIGNMENT ),
CPU_HEAP_ALIGNMENT_0
@@ -61,6 +53,12 @@ RTEMS_STATIC_ASSERT(
CPU_HEAP_ALIGNMENT_1
+RTEMS_STATIC_ASSERT(
+ CPU_STACK_ALIGNMENT >= CPU_HEAP_ALIGNMENT &&
+ PER_CPU_IS_POWER_OF_TWO( CPU_STACK_ALIGNMENT ),
sizeof(void *) == CPU_SIZEOF_POINTER,
CPU_SIZEOF_POINTER
2.26.2
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
