[PATCH 2/3] cpuusagetop.c: Fix three Missing break in switch Coverity errors
Ryan Long
thisisryanlong at gmail.com
Wed Mar 3 21:26:00 UTC 2021
CID 1399726: Missing break in switch in task_usage().
CID 1399728: Missing break in switch in task_usage().
CID 1399742: Missing break in switch in task_usage().
Closes #4278
cpukit/libmisc/cpuuse/cpuusagetop.c | 3 +++
1 file changed, 3 insertions(+)
diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
index 9f19b27..dad11ad 100644
--- a/cpukit/libmisc/cpuuse/cpuusagetop.c
+++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
@@ -228,9 +228,11 @@ task_usage(Thread_Control* thread, void* arg)
if (CPU_usage_Equal_to(&usage, &data->zero) ||
CPU_usage_Less_than(&usage, &data->usage[j]))
continue;
+ /* Fall through */
case RTEMS_TOP_SORT_REAL_PRI:
if (thread->Real_priority.priority > data->tasks[j]->Real_priority.priority)
continue;
case RTEMS_TOP_SORT_CURRENT_PRI:
if (
_Thread_Get_priority( thread )
@@ -238,6 +240,7 @@ task_usage(Thread_Control* thread, void* arg)
continue;
case RTEMS_TOP_SORT_ID:
if (thread->Object.id < data->tasks[j]->Object.id)
continue;
1.8.3.1
