[PATCH 0/3] tester: Fix RLD classes for covoar
Chris Johns
chrisj at rtems.org
Thu Mar 4 02:42:36 UTC 2021
On 4/3/21 4:01 am, Alex White wrote:
> This patch set contains changes to RLD classes necessary for covoar.
> Alex White (3):
> rld-dwarf: Add function::has_entry_pc
> rld-dwarf: Fix file::get_source
> rld-process: Add named tempfile constructor
> rtemstoolkit/rld-dwarf.cpp | 13 +++++++++----
> rtemstoolkit/rld-dwarf.h | 5 +++++
> rtemstoolkit/rld-process.cpp | 11 +++++++++++
> rtemstoolkit/rld-process.h | 7 +++++++
> 4 files changed, 32 insertions(+), 4 deletions(-)
Thank you for splitting this out, it helps.
All ok to push once you know they compile on Windows.
