[PATCH 0/3] tester: Fix RLD classes for covoar
Alexander White
alexanderjwhite at gmail.com
Tue Mar 9 20:47:42 UTC 2021
I can confirm that they do compile on Windows.
Alex
On Wed, Mar 3, 2021 at 8:42 PM Chris Johns <chrisj at rtems.org> wrote:
> On 4/3/21 4:01 am, Alex White wrote:
> > This patch set contains changes to RLD classes necessary for covoar.
> > Alex White (3):
> > rld-dwarf: Add function::has_entry_pc
> > rld-dwarf: Fix file::get_source
> > rld-process: Add named tempfile constructor
> > rtemstoolkit/rld-dwarf.cpp | 13 +++++++++----
> > rtemstoolkit/rld-dwarf.h | 5 +++++
> > rtemstoolkit/rld-process.cpp | 11 +++++++++++
> > rtemstoolkit/rld-process.h | 7 +++++++
> > 4 files changed, 32 insertions(+), 4 deletions(-)
> Thank you for splitting this out, it helps.
> All ok to push once you know they compile on Windows.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210309/1733d2ce/attachment-0001.html>
