[PATCH 00/12] Fix Unchecked return value from library errors
Ryan Long
thisisryanlong at gmail.com
Thu Mar 4 14:05:01 UTC 2021
Hi,
Here are the fixes for the "Unchecked return value from library"
Coverity errors. For most of these, I added a status code variable,
returned the value, and used the _Assert_Unused_variable_equal/unequal
macros. For main_help.c, a (void) was just added because we don't care
about the value that is returned.
Ryan
Ryan Long (12):
gen_uuid.c: Fix two Unchecked return value from library errors
main_chmod.c: Fix Unchecked return value from library (CID #1063856)
pwdgrp.c: Fix Unchecked return value from library (CID #1255518)
gr_rasta_spw_router.c: Fix Unchecked return value from library (CID
#1399760)
gr_rasta_io.c: Fix Unchecked return value from library (CID #1399763)
gr_leon4_n2x.c: Fix Unchecked return value from library (CID #1399767)
gr_rasta_tmtc.c: Fix Unchecked return value from library (CID
#1399771)
#1399780)
gr_701.c: Unchecked return value from library (CID #1399783)
gr_tmtc_1553.c: Unchecked return value from library (CID #1399785)
gr_cpci_gr740.c: Unchecked return value from library (CID #1437630)
main_help.c: Unchecked return value from library (CID #1437650)
bsps/shared/grlib/pci/gr_701.c | 4 +++-
bsps/shared/grlib/pci/gr_rasta_adcdac.c | 4 +++-
bsps/shared/grlib/pci/gr_rasta_io.c | 4 +++-
bsps/shared/grlib/pci/gr_rasta_spw_router.c | 4 +++-
bsps/shared/grlib/pci/gr_rasta_tmtc.c | 4 +++-
bsps/shared/grlib/pci/gr_tmtc_1553.c | 4 +++-
bsps/sparc/shared/pci/gr_cpci_gr740.c | 4 +++-
bsps/sparc/shared/pci/gr_leon4_n2x.c | 4 +++-
cpukit/libcsupport/src/pwdgrp.c | 6 +++++-
cpukit/libmisc/shell/main_chmod.c | 5 ++++-
cpukit/libmisc/shell/main_help.c | 3 ++-
cpukit/libmisc/uuid/gen_uuid.c | 12 ++++++++++--
12 files changed, 45 insertions(+), 13 deletions(-)
1.8.3.1
