[PATCH 01/12] gen_uuid.c: Fix two Unchecked return value from library errors
Ryan Long
thisisryanlong at gmail.com
Thu Mar 4 14:05:02 UTC 2021
CID 1049146: Unchecked return value from library in get_clock().
CID 1049147: Unchecked return value from library in get_random_fd().
Closes #4280
cpukit/libmisc/uuid/gen_uuid.c | 12 ++++++++++--
1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/cpukit/libmisc/uuid/gen_uuid.c b/cpukit/libmisc/uuid/gen_uuid.c
index 3ca75a0..0f2aba0 100644
--- a/cpukit/libmisc/uuid/gen_uuid.c
+++ b/cpukit/libmisc/uuid/gen_uuid.c
@@ -155,6 +155,7 @@ static int get_random_fd(void)
struct timeval tv;
static int fd = -2;
int i;
+ int sc;
if (fd == -2) {
gettimeofday(&tv, 0);
@@ -165,7 +166,12 @@ static int get_random_fd(void)
if (fd >= 0) {
i = fcntl(fd, F_GETFD);
if (i >= 0)
- fcntl(fd, F_SETFD, i | FD_CLOEXEC);
+ #ifdef __rtems__
+ sc = fcntl(fd, F_SETFD, i | FD_CLOEXEC);
+ _Assert_Unused_variable_unequal(sc, -1);
+ #else
+ fcntl(fd, F_SETFD, i | FD_CLOEXEC);
+ #endif
#endif
srand((getpid() << ((sizeof(pid_t)*CHAR_BIT)>>1)) ^ getuid() ^ tv.tv_sec ^ tv.tv_usec);
@@ -334,6 +340,7 @@ static int get_clock(uint32_t *clock_high, uint32_t *clock_low,
uint64_t clock_reg;
mode_t save_umask;
int len;
+ int sc;
if (state_fd == -2) {
save_umask = umask(0);
@@ -426,7 +433,8 @@ try_again:
rewind(state_f);
fl.l_type = F_UNLCK;
- fcntl(state_fd, F_SETLK, &fl);
+ sc = fcntl(state_fd, F_SETLK, &fl);
*clock_high = clock_reg >> 32;
1.8.3.1
