[PATCH] grtc.c: Fix four Missing break in switch Coverity errors
Daniel Hellstrom
daniel at gaisler.com
Fri Mar 5 07:55:39 UTC 2021
Hi,
The patch looks good. The fall through is by design intended.
Thanks,
Daniel Hellstrom
Software Section Head
T : +46 (0) 31 775 8657
F : +46 (0) 31 421407
daniel at gaisler.com <mailto:daniel at gaisler.com>
To receive update notifications, please subscribe tohttps://gaisler.com/newsletter <https://gaisler.com/newsletter>
Cobham Gaisler AB, Kungsgatan 12, SE-411 19, GÖTEBORG, Sweden.
+46 (0) 31 775 8650, www.cobhamaes.com/gaisler
Please consider the environment before printing this email
On 2021-03-04 21:02, Ryan Long wrote:
> CID 1399761: Missing break in switch in process_dma().
> CID 1399765: Missing break in switch in process_dma().
> CID 1399766: Missing break in switch in process_dma().
> CID 1399777: Missing break in switch in process_dma().
> Closes #4277
> bsps/shared/grlib/tmtc/grtc.c | 4 ++++
> 1 file changed, 4 insertions(+)
> diff --git a/bsps/shared/grlib/tmtc/grtc.c b/bsps/shared/grlib/tmtc/grtc.c
> index e9acea4..f734f2e 100644
> --- a/bsps/shared/grlib/tmtc/grtc.c
> +++ b/bsps/shared/grlib/tmtc/grtc.c
> @@ -1365,6 +1365,7 @@ static int process_dma(struct grtc_priv *pDev)
> /* Start of frame found, Try to copy header */
> pDev->frm = NULL;
> pDev->frame_state = FRM_STATE_HDR;
> + /* Fall through */
> case FRM_STATE_HDR:
> DBG2("FRAME_STATE_HDR\n");
> @@ -1396,6 +1397,7 @@ static int process_dma(struct grtc_priv *pDev)
> return -1;
> pDev->frame_state = FRM_STATE_ALLOC;
> case FRM_STATE_ALLOC:
> DBG2("FRAME_STATE_ALLOC\n");
> @@ -1449,6 +1451,7 @@ static int process_dma(struct grtc_priv *pDev)
> pDev->frame_state = FRM_STATE_PAYLOAD;
> pDev->frm = frm;
> case FRM_STATE_PAYLOAD:
> DBG2("FRAME_STATE_PAYLOAD\n");
> @@ -1476,6 +1479,7 @@ static int process_dma(struct grtc_priv *pDev)
> frm->len += ret;
> pDev->frame_state = FRM_STATE_FILLER;
> case FRM_STATE_FILLER:
> DBG2("FRAME_STATE_FILLER\n");
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210305/ab2aa723/attachment.html>
