[PATCH] user: Update ZynqMP QEMU BSP name
Fri Mar 5 15:22:46 UTC 2021
ok
On Thu, Mar 4, 2021 at 10:03 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> The ZynqMP QEMU BSPs have had _qemu added to their names to better
> identify them as QEMU BSPs similar to other BSPs which are meant to run
> exclusively on QEMU and not hardware.
>  user/bsps/aarch64/xilinx-zynqmp.rst | 11 ++++++-----
>  1 file changed, 6 insertions(+), 5 deletions(-)
> diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
> index 7c8ecdf..7401e84 100644
> --- a/user/bsps/aarch64/xilinx-zynqmp.rst
> +++ b/user/bsps/aarch64/xilinx-zynqmp.rst
> @@ -2,15 +2,16 @@
>  .. Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
> -.. _BSP_aarch64_qemu_xilinx_zynqmp_ilp32:
> -.. _BSP_aarch64_qemu_xilinx_zynqmp_lp64:
> +.. _BSP_aarch64_qemu_xilinx_zynqmp_ilp32_qemu:
> +.. _BSP_aarch64_qemu_xilinx_zynqmp_lp64_qemu:
>  Qemu Xilinx ZynqMP
> -This BSP supports two variants, `xilinx-zynqmp-ilp32` and `xilinx-zynqmp-lp64`.
> -The basic hardware initialization is performed by the BSP. These BSPs support
> -the GICv2 interrupt controller present in all ZynqMP systems.
> +This BSP supports two variants, `xilinx-zynqmp-ilp32-qemu` and
> +`xilinx-zynqmp-lp64-qemu`. The basic hardware initialization is performed by the
> +BSP. These BSPs support the GICv2 interrupt controller present in all ZynqMP
> +systems.
>  Boot via ELF
> 2.20.1
> devel mailing list
> devel at rtems.org
