[PATCH v2 1/1] bsps/shared: Allow setting baud rate for zynq uart
Gedare Bloom
gedare at rtems.org
Fri Mar 5 15:38:18 UTC 2021
On Thu, Mar 4, 2021 at 1:11 AM <Jan.Sommer at dlr.de> wrote:
> Could someone please have a look a this patch and approve it?
> Should I then still add a new section to the docs regarding the console behavior for the zynq?
Please do prepare an addition for the docs, that would be great.
> With this patch applied it would be that the baud rate of the fsbl is overwritten by default to 115200, but can be changed using the termios API (compared to the currently unchangeable baud rate).
> I am not sure if that information is that useful or if people will figure that out in 2 min anyways.
It is always best to be explicit when we can. This is most useful for
junior engineers, but even experts can get confused by some hidden
details.
> Best regards,
> Jan
> > -----Original Message-----
> > From: Sommer, Jan
> > Sent: Monday, February 22, 2021 5:23 PM
> > To: devel at rtems.org
> > Cc: Sommer, Jan <Jan.Sommer at dlr.de>
> > Subject: [PATCH v2 1/1] bsps/shared: Allow setting baud rate for zynq uart
> > bsps/shared/dev/serial/zynq-uart.c | 14 +++++++++++---
> > 1 file changed, 11 insertions(+), 3 deletions(-)
> > diff --git a/bsps/shared/dev/serial/zynq-uart.c
> > b/bsps/shared/dev/serial/zynq-uart.c
> > index 8f17d3ca65..dd5a6e1cb8 100644
> > --- a/bsps/shared/dev/serial/zynq-uart.c
> > +++ b/bsps/shared/dev/serial/zynq-uart.c
> > @@ -144,14 +144,22 @@ static bool zynq_uart_set_attributes( {
> > zynq_uart_context *ctx = (zynq_uart_context *) context;
> > volatile zynq_uart *regs = ctx->regs;
> > + int32_t baud;
> > uint32_t brgr = 0;
> > uint32_t bauddiv = 0;
> > uint32_t mode = 0;
> > int rc;
> > - rc = zynq_cal_baud_rate(115200, &brgr, &bauddiv, regs->mode);
> > - if (rc != 0)
> > - return rc;
> > + * Determine the baud rate
> > + baud = rtems_termios_baud_to_number(term->c_ospeed);
> > + if (baud > 0) {
> > + rc = zynq_cal_baud_rate(baud, &brgr, &bauddiv, regs->mode);
> > + if (rc != 0)
> > + return rc;
> > * Configure the mode register
> > 2.17.1
> devel mailing list
> devel at rtems.org
