[PATCH v2 1/1] bsps/shared: Allow setting baud rate for zynq uart
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Fri Mar 5 17:29:38 UTC 2021
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Friday, March 5, 2021 4:36 PM
> To: Sommer, Jan <Jan.Sommer at dlr.de>
> Cc: devel at rtems.org
> Subject: Re: [PATCH v2 1/1] bsps/shared: Allow setting baud rate for zynq
> uart
> On Mon, Feb 22, 2021 at 9:23 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> >  bsps/shared/dev/serial/zynq-uart.c | 14 +++++++++++---
> >  1 file changed, 11 insertions(+), 3 deletions(-)
> > diff --git a/bsps/shared/dev/serial/zynq-uart.c
> > b/bsps/shared/dev/serial/zynq-uart.c
> > index 8f17d3ca65..dd5a6e1cb8 100644
> > --- a/bsps/shared/dev/serial/zynq-uart.c
> > +++ b/bsps/shared/dev/serial/zynq-uart.c
> > @@ -144,14 +144,22 @@ static bool zynq_uart_set_attributes(  {
> >    zynq_uart_context *ctx = (zynq_uart_context *) context;
> >    volatile zynq_uart *regs = ctx->regs;
> > +  int32_t baud;
> >    uint32_t brgr = 0;
> >    uint32_t bauddiv = 0;
> >    uint32_t mode = 0;
> >    int rc;
> > -  rc = zynq_cal_baud_rate(115200, &brgr, &bauddiv, regs->mode);
> > -  if (rc != 0)
> > -    return rc;
> > +   * Determine the baud rate
> > +  baud = rtems_termios_baud_to_number(term->c_ospeed);
> > +  if (baud > 0) {
> > +    rc = zynq_cal_baud_rate(baud, &brgr, &bauddiv, regs->mode);
> > +    if (rc != 0)
> > +      return rc;
> What happens if baud == 0?
Ah, you are right. My initial goal was to leave it unchanged (because there are no modem control lines to deassert), but forgot that the baud rate registers are set below with then 0. That is not what it should be.
I will prepare a new patch with a condition.
Thanks.
> >     * Configure the mode register
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
