[PATCH v3 1/1] bsps/shared: Allow setting baud rate for zynq uart
Fri Mar 5 17:47:40 UTC 2021
Looks good to me.
On Fri, Mar 5, 2021 at 10:42 AM Jan Sommer <jan.sommer at dlr.de> wrote:
>  bsps/shared/dev/serial/zynq-uart.c | 21 ++++++++++++++++-----
>  1 file changed, 16 insertions(+), 5 deletions(-)
> diff --git a/bsps/shared/dev/serial/zynq-uart.c b/bsps/shared/dev/serial/zynq-uart.c
> index 8f17d3ca65..cd0d0e7584 100644
> --- a/bsps/shared/dev/serial/zynq-uart.c
> +++ b/bsps/shared/dev/serial/zynq-uart.c
> @@ -144,14 +144,22 @@ static bool zynq_uart_set_attributes(
>    zynq_uart_context *ctx = (zynq_uart_context *) context;
>    volatile zynq_uart *regs = ctx->regs;
> +  int32_t baud;
>    uint32_t brgr = 0;
>    uint32_t bauddiv = 0;
>    uint32_t mode = 0;
>    int rc;
> -  rc = zynq_cal_baud_rate(115200, &brgr, &bauddiv, regs->mode);
> -  if (rc != 0)
> -    return rc;
> +   * Determine the baud rate
> +  baud = rtems_termios_baud_to_number(term->c_ospeed);
> +  if (baud > 0) {
> +    rc = zynq_cal_baud_rate(baud, &brgr, &bauddiv, regs->mode);
> +    if (rc != 0)
> +      return rc;
>     * Configure the mode register
> @@ -202,8 +210,11 @@ static bool zynq_uart_set_attributes(
>    regs->control &= ~(ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN);
>    regs->mode = mode;
> -  regs->baud_rate_gen = ZYNQ_UART_BAUD_RATE_GEN_CD(brgr);
> -  regs->baud_rate_div = ZYNQ_UART_BAUD_RATE_DIV_BDIV(bauddiv);
> +  /* Ignore baud rate of B0. There are no modem control lines to de-assert */
> +  if (baud > 0) {
> +    regs->baud_rate_gen = ZYNQ_UART_BAUD_RATE_GEN_CD(brgr);
> +    regs->baud_rate_div = ZYNQ_UART_BAUD_RATE_DIV_BDIV(bauddiv);
>    regs->control |= ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN;
>    return true;
> 2.17.1
> devel mailing list
> devel at rtems.org
