[PATCH v2] user/bsps: Mention fixed console baud rate for zynq
Jan Sommer
jan.sommer at dlr.de
Fri Mar 5 18:04:02 UTC 2021
user/bsps/arm/xilinx-zynq.rst | 12 ++++++++++++
1 file changed, 12 insertions(+)
diff --git a/user/bsps/arm/xilinx-zynq.rst b/user/bsps/arm/xilinx-zynq.rst
index 365c336..29f9cb0 100644
--- a/user/bsps/arm/xilinx-zynq.rst
+++ b/user/bsps/arm/xilinx-zynq.rst
@@ -37,6 +37,18 @@ to return the peripheral clock. Normally this is half the CPU
clock. This function is declared ``weak`` so you can override the
default behaviour by providing it in your application.
+Console
+The console driver for the UARTs will always be initialized to a
+baud rate of 115200 with 8 bit characters, 1 stop bit and no parity
+bits during start up.
+Previous configurations programmed into the hardware by the Xilinx
+tools or a bootloader will be overwritten.
+The settings for the console driver can be changed by the user
+application through the termios API afterwards.
Debugging with xilinx_zynq_a9_qemu
2.17.1
