[PATCH v2] user/bsps: Mention fixed console baud rate for zynq
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Mon Mar 15 12:55:23 UTC 2021
Could someone please have a look at this patch?
> -----Original Message-----
> From: Sommer, Jan
> Sent: Friday, March 5, 2021 7:04 PM
> To: devel at rtems.org
> Cc: Sommer, Jan <Jan.Sommer at dlr.de>
> Subject: [PATCH v2] user/bsps: Mention fixed console baud rate for zynq
>  user/bsps/arm/xilinx-zynq.rst | 12 ++++++++++++
>  1 file changed, 12 insertions(+)
> diff --git a/user/bsps/arm/xilinx-zynq.rst b/user/bsps/arm/xilinx-zynq.rst
> index 365c336..29f9cb0 100644
> --- a/user/bsps/arm/xilinx-zynq.rst
> +++ b/user/bsps/arm/xilinx-zynq.rst
> @@ -37,6 +37,18 @@ to return the peripheral clock. Normally this is half the
> CPU  clock. This function is declared ``weak`` so you can override the  default
> behaviour by providing it in your application.
> +Console
> +The console driver for the UARTs will always be initialized to a baud
> +rate of 115200 with 8 bit characters, 1 stop bit and no parity bits
> +during start up.
> +Previous configurations programmed into the hardware by the Xilinx
> +tools or a bootloader will be overwritten.
> +The settings for the console driver can be changed by the user
> +application through the termios API afterwards.
>  Debugging with xilinx_zynq_a9_qemu
> 2.17.1
