RSB build issue with rtems-libbsd
Chris Johns
chrisj at rtems.org
Mon Mar 8 22:02:05 UTC 2021
On 6/3/21 2:24 pm, Vijay Kumar Banerjee wrote:
> Hello,
> I'm getting the following error when trying to build rtems-libbsd from
> RSB. Is there anything that I'm missing?
> ../source-builder/sb-set-builder --prefix=$RTEMS6_PREFIX
> 6/rtems-libbsd --host=powerpc-rtems6 --with-rtems-bsp=beatnik
> RTEMS Source Builder - Set Builder, 6 (102cb1e6450f)
> warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
> Build Set: 6/rtems-libbsd
> config: tools/rtems-libbsd-6.cfg
> error: rtems-bsp.cfg:155: invalid %if operator: -mcpu=7400
> -I/home/vijay/development/rtems/6/powerpc-rtems6/beatnik/lib/include
This looks like a bug. Please raise a ticket.
> Build FAILED
> Build Set: Time 0:00:00.046141
> Build FAILED
> Commenting these checks from rtems-bsp.cfg gets it building.
Unfortunately the checks are needed and this is not the answer.
I wonder how Jennifer has been building libbsd. She is working on this BSP and
libbsd.
