RSB build issue with rtems-libbsd
Mon Mar 8 22:14:20 UTC 2021
On Mon, Mar 8, 2021, 4:02 PM Chris Johns <chrisj at rtems.org> wrote:
> On 6/3/21 2:24 pm, Vijay Kumar Banerjee wrote:
> > Hello,
> > I'm getting the following error when trying to build rtems-libbsd from
> > RSB. Is there anything that I'm missing?
> > ../source-builder/sb-set-builder --prefix=$RTEMS6_PREFIX
> > 6/rtems-libbsd --host=powerpc-rtems6 --with-rtems-bsp=beatnik
> > RTEMS Source Builder - Set Builder, 6 (102cb1e6450f)
> > warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
> > Build Set: 6/rtems-libbsd
> > config: tools/rtems-libbsd-6.cfg
> > error: rtems-bsp.cfg:155: invalid %if operator:  -mcpu=7400
> > -I/home/vijay/development/rtems/6/powerpc-rtems6/beatnik/lib/include
> This looks like a bug. Please raise a ticket.
> > Build FAILED
> > Build Set: Time 0:00:00.046141
> > Build FAILED
> > Commenting these checks from rtems-bsp.cfg gets it building.
> Unfortunately the checks are needed and this is not the answer.
> I wonder how Jennifer has been building libbsd. She is working on this BSP
> and
> libbsd.
Directly with waf.
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210308/7022f2f7/attachment.html>
