[PATCH v1 4/7] nexus: Add ZynqMP SLCR driver
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Mar 8 23:27:07 UTC 2021
Add a System Level Control Register driver for the Xilinx Zynq
Ultrascale+ MPSoC with basic clock control functionality for use with
the Cadence GEM. This also removes the Zynq-7000 clock control weakref
from compilation depending on the BSP in use.
freebsd/sys/arm/xilinx/zy7_slcr.c | 3 +
libbsd.py | 1 +
rtemsbsd/include/bsp/nexus-devices.h | 1 +
.../include/machine/rtems-bsd-nexus-bus.h | 21 ++
rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.c | 233 ++++++++++++++++++
rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.h | 90 +++++++
6 files changed, 349 insertions(+)
create mode 100644 rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.c
create mode 100644 rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.h
diff --git a/freebsd/sys/arm/xilinx/zy7_slcr.c b/freebsd/sys/arm/xilinx/zy7_slcr.c
index 79fccee5..4bbdb626 100644
--- a/freebsd/sys/arm/xilinx/zy7_slcr.c
+++ b/freebsd/sys/arm/xilinx/zy7_slcr.c
@@ -45,6 +45,7 @@ __FBSDID("$FreeBSD$");
#include <sys/systm.h>
#ifdef __rtems__
#include <sys/bus.h>
+#include <bsp.h>
#endif /* __rtems__ */
#include <sys/conf.h>
#include <sys/kernel.h>
@@ -217,6 +218,7 @@ zy7_slcr_postload_pl(int en_level_shifters)
ZSLCR_UNLOCK(sc);
+#if defined(LIBBSP_ARM_XILINX_ZYNQ_BSP_H)
/* Override cgem_set_refclk() in gigabit ethernet driver
* (sys/dev/cadence/if_cgem.c). This function is called to
* request a change in the gem's reference clock speed.
@@ -264,6 +266,7 @@ cgem_set_ref_clk(int unit, int frequency)
return (0);
+#endif /* LIBBSP_ARM_XILINX_ZYNQ_BSP_H */
* PL clocks management function
diff --git a/libbsd.py b/libbsd.py
index 28617d21..16e81565 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -1423,6 +1423,7 @@ class dev_net(builder.Module):
self.addRTEMSKernelSourceFiles(
'sys/dev/mii/ksz8091rnb_50MHz.c',
+ 'sys/arm64/xilinx/zynqmp_slcr.c',
mm.generator['source']()
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 7cdd5428..ea8fa7d7 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -107,6 +107,7 @@ RTEMS_BSD_DRIVER_MMC;
#include <bsp/irq.h>
+RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SLCR;
/* Qemu only applies user-mode networking to the first interface by default, so
* all 4 CGEM instances must be configured in the Qemu arguments using
* "-nic user,model=cadence_gem" for each nic.
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index 5c95d2c3..bb5546a6 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -38,6 +38,7 @@
* Devices:
* RTEMS_BSD_DRIVER_XILINX_ZYNQ_SLCR
+ * RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SLCR
* RTEMS_BSD_DRIVER_LPC32XX_PWR
* RTEMS_BSD_DRIVER_LPC32XX_TSC
@@ -117,6 +118,26 @@ extern "C" {
&zy7_slcr_res[0])
#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQ_SLCR */
+ * Xilinx ZynqMP System Level Control Registers (SLCR).
+#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SLCR)
+ * Hard IP part of the ZynqMP so a fixed address.
+ #define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SLCR \
+ static const rtems_bsd_device_resource zynqmp_slcr_res[] = { \
+ .type = RTEMS_BSD_RES_MEMORY, \
+ .start_request = 0, \
+ .start_actual = 0xf0000000 \
+ RTEMS_BSD_DEFINE_NEXUS_DEVICE(zynqmp_slcr, 0, \
+ RTEMS_ARRAY_SIZE(zynqmp_slcr_res), \
+ &zynqmp_slcr_res[0])
+#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SLCR */
* Xilinx Zynq Arasan SDIO Driver.
diff --git a/rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.c b/rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.c
new file mode 100644
index 00000000..ac52d234
--- /dev/null
+++ b/rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.c
@@ -0,0 +1,233 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2021 Kinsey Moore
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+ * Zynq Ultrascale+ MPSoC SLCR driver. Provides hook for CGEM clocks.
+ * Reference: Zynq Ultrascale+ MPSoC Technical Reference Manual.
+ * (v2.2) December 4, 2020. Xilinx doc UG1085.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <bsp.h>
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/conf.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/lock.h>
+#include <sys/mutex.h>
+#include <rtems/bsd/sys/resource.h>
+#include <sys/sysctl.h>
+#include <sys/rman.h>
+#include <machine/bus.h>
+#include <machine/resource.h>
+#include <machine/stdarg.h>
+#include <arm64/xilinx/zynqmp_slcr.h>
+struct zynqmp_slcr_softc {
+ device_t dev;
+ struct mtx sc_mtx;
+ struct resource *mem_res;
+static struct zynqmp_slcr_softc *zynqmp_slcr_softc_p;
+#define RD4(sc, off) (bus_read_4((sc)->mem_res, (off)))
+#define WR4(sc, off, val) (bus_write_4((sc)->mem_res, (off), (val)))
+SYSCTL_NODE(_hw, OID_AUTO, zynqmp, CTLFLAG_RD, 0, "Xilinx Zynq Ultrascale+ MPSoC");
+#if defined(LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_H)
+/* Override cgem_set_refclk() in gigabit ethernet driver
+ * (sys/dev/cadence/if_cgem.c). This function is called to
+ * request a change in the gem's reference clock speed.
+int
+cgem_set_ref_clk(int unit, int frequency)
+ struct zynqmp_slcr_softc *sc = zynqmp_slcr_softc_p;
+ int div0, div1;
+ uint64_t clk_ctrl, pll_ctrl;
+ uint32_t clk_ctrl_val, pll_ctrl_val, pll_freq, pll_bypass;
+ if (!sc)
+ return (-1);
+ switch (unit) {
+ case 0:
+ clk_ctrl = ZYNQMP_SLCR_GEM0_CLK_CTRL;
+ break;
+ case 1:
+ clk_ctrl = ZYNQMP_SLCR_GEM1_CLK_CTRL;
+ break;
+ case 2:
+ clk_ctrl = ZYNQMP_SLCR_GEM2_CLK_CTRL;
+ break;
+ case 3:
+ clk_ctrl = ZYNQMP_SLCR_GEM3_CLK_CTRL;
+ break;
+ default:
+ return (-1);
+ clk_ctrl_val = RD4(sc, clk_ctrl);
+ switch (clk_ctrl_val & ZYNQMP_SLCR_GEM_CLK_CTRL_SRCSEL_MASK) {
+ case 0:
+ pll_ctrl = ZYNQMP_SLCR_IO_PLL_CTRL;
+ break;
+ case 2:
+ pll_ctrl = ZYNQMP_SLCR_R_PLL_CTRL;
+ break;
+ case 3:
+ pll_ctrl = ZYNQMP_SLCR_D_PLL_CTRL;
+ break;
+ default:
+ return (-1);
+ /* Get PLL frequency */
+ pll_ctrl_val = RD4(sc, pll_ctrl);
+ pll_bypass = pll_ctrl_val & ZYNQMP_SLCR_PLL_CTRL_BYPASS;
+ if ((pll_ctrl_val & ZYNQMP_SLCR_PLL_CTRL_RESET) && !pll_bypass) {
+ return 0;
+ pll_freq = ZYNQMP_DEFAULT_PS_CLK_FREQUENCY;
+ if (!pll_bypass) {
+ pll_freq *= (pll_ctrl_val & ZYNQMP_SLCR_PLL_CTRL_FBDIV_MASK) >> ZYNQMP_SLCR_PLL_CTRL_FBDIV_SHIFT;
+ /* Divide by 2 if necessary */
+ pll_freq >>= !!(pll_ctrl_val & ZYNQMP_SLCR_PLL_CTRL_DIV2);
+ /* Find suitable divisor pairs. Round result to nearest khz
+ * to test for match.
+ for (div1 = 1; div1 <= ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR1_MAX; div1++) {
+ div0 = (pll_freq + div1 * frequency / 2) /
+ div1 / frequency;
+ if (div0 > 0 && div0 <= ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR0_MAX &&
+ ((pll_freq / div0 / div1) + 500) / 1000 ==
+ (frequency + 500) / 1000)
+ break;
+ if (div1 > ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR1_MAX)
+ return (-1);
+ /* Modify GEM reference clock. */
+ clk_ctrl_val &= ~ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR1_MASK;
+ clk_ctrl_val &= ~ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR0_MASK;
+ clk_ctrl_val |= div1 << ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR1_SHIFT;
+ clk_ctrl_val |= div0 << ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR0_SHIFT;
+ WR4(sc, clk_ctrl, clk_ctrl_val);
+ return (0);
+#endif
+static int
+zynqmp_slcr_probe(device_t dev)
+ device_set_desc(dev, "Zynq Ultrascale+ MPSoC SLCR block");
+ return (0);
+static int
+zynqmp_slcr_attach(device_t dev)
+ struct zynqmp_slcr_softc *sc = device_get_softc(dev);
+ int rid;
+ /* Allow only one attach. */
+ if (zynqmp_slcr_softc_p != NULL)
+ return (ENXIO);
+ sc->dev = dev;
+ /* Get memory resource. */
+ rid = 0;
+ sc->mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+ RF_ACTIVE);
+ if (sc->mem_res == NULL) {
+ device_printf(dev, "could not allocate memory resources.\n");
+ return (ENOMEM);
+ /* For use with CGEM clock setting */
+ zynqmp_slcr_softc_p = sc;
+ return (0);
+static int
+zynqmp_slcr_detach(device_t dev)
+ bus_generic_detach(dev);
+ /* Release memory resource. */
+ if (sc->mem_res != NULL)
+ bus_release_resource(dev, SYS_RES_MEMORY,
+ rman_get_rid(sc->mem_res), sc->mem_res);
+ zynqmp_slcr_softc_p = NULL;
+ return (0);
+static device_method_t zynqmp_slcr_methods[] = {
+ /* device_if */
+ DEVMETHOD(device_probe, zynqmp_slcr_probe),
+ DEVMETHOD(device_attach, zynqmp_slcr_attach),
+ DEVMETHOD(device_detach, zynqmp_slcr_detach),
+ DEVMETHOD_END
+static driver_t zynqmp_slcr_driver = {
+ "zynqmp_slcr",
+ zynqmp_slcr_methods,
+ sizeof(struct zynqmp_slcr_softc),
+static devclass_t zynqmp_slcr_devclass;
+DRIVER_MODULE(zynqmp_slcr, nexus, zynqmp_slcr_driver, zynqmp_slcr_devclass, 0, 0);
+MODULE_VERSION(zynqmp_slcr, 1);
diff --git a/rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.h b/rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.h
index 00000000..d5c7f38e
--- /dev/null
+++ b/rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.h
@@ -0,0 +1,90 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+ * Defines for Zynq Ultrascale+ MPSoC SLCR registers.
+ * Additional Reference: Zynq Ultrascale+ MPSoC Register Reference.
+ * (v1.7) February 8, 2019. Xilinx doc UG1087.
+#ifndef _ZYNQMP_SLCR_H_
+#define _ZYNQMP_SLCR_H_
+#define ZYNQMP_SLCR_CRF_OFFSET 0x0d1a0000
+#define ZYNQMP_SLCR_CRL_OFFSET 0x0f5e0000
+/* PLL controls. */
+#define ZYNQMP_SLCR_IO_PLL_CTRL (ZYNQMP_SLCR_CRL_OFFSET + 0x20)
+#define ZYNQMP_SLCR_R_PLL_CTRL (ZYNQMP_SLCR_CRL_OFFSET + 0x30)
+#define ZYNQMP_SLCR_D_PLL_CTRL (ZYNQMP_SLCR_CRF_OFFSET + 0x2c)
+#define ZYNQMP_SLCR_PLL_CTRL_RESET (1<<0)
+#define ZYNQMP_SLCR_PLL_CTRL_BYPASS (1<<3)
+#define ZYNQMP_SLCR_PLL_CTRL_FBDIV_SHIFT 8
+#define ZYNQMP_SLCR_PLL_CTRL_FBDIV_MASK (0x7f<<8)
+#define ZYNQMP_SLCR_PLL_CTRL_FBDIV_MAX 0x7f
+#define ZYNQMP_SLCR_PLL_CTRL_DIV2 (1<<16)
+#define ZYNQMP_SLCR_PLL_CTRL_PRE_SRC_SHIFT 20
+#define ZYNQMP_SLCR_PLL_CTRL_PRE_SRC_MASK (0x7<<20)
+#define ZYNQMP_SLCR_PLL_CTRL_POST_SRC_SHIFT 24
+#define ZYNQMP_SLCR_PLL_CTRL_POST_SRC_MASK (0x7<<24)
+#define ZYNQMP_SLCR_PLL_CTRL_SRC_PS 0x0
+#define ZYNQMP_SLCR_PLL_CTRL_SRC_VIDEO 0x4
+#define ZYNQMP_SLCR_PLL_CTRL_SRC_ALT 0x5
+#define ZYNQMP_SLCR_PLL_CTRL_SRC_AUX 0x6
+#define ZYNQMP_SLCR_PLL_CTRL_SRC_GT 0x7
+/* Clock controls. */
+#define ZYNQMP_SLCR_GEM0_CLK_CTRL (ZYNQMP_SLCR_CRL_OFFSET + 0x50)
+#define ZYNQMP_SLCR_GEM1_CLK_CTRL (ZYNQMP_SLCR_CRL_OFFSET + 0x54)
+#define ZYNQMP_SLCR_GEM2_CLK_CTRL (ZYNQMP_SLCR_CRL_OFFSET + 0x58)
+#define ZYNQMP_SLCR_GEM3_CLK_CTRL (ZYNQMP_SLCR_CRL_OFFSET + 0x5c)
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_RX_CLKACT (1<<26)
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_CLKACT (1<<25)
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR1_MASK (0x3f<<16)
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR1_SHIFT 16
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR1_MAX 0x3f
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR0_MASK (0x3f<<8)
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR0_SHIFT 8
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_DIVISOR0_MAX 0x3f
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_SRCSEL_MASK (7<<0)
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_SRCSEL_IO_PLL (0<<0)
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_SRCSEL_R_PLL (2<<0)
+#define ZYNQMP_SLCR_GEM_CLK_CTRL_SRCSEL_D_PLL (3<<0)
+#define ZYNQMP_DEFAULT_PS_CLK_FREQUENCY 33333333
+#ifdef _KERNEL
+extern int cgem_set_ref_clk(int unit, int frequency);
+#endif
+#endif /* _ZYNQMP_SLCR_H_ */
2.20.1
