[PATCH v1 3/7] nexus: Switch ZynqMP platforms to CGEM3
Kinsey Moore kinsey.moore at oarcorp.com
Mon Mar 8 23:27:06 UTC 2021
Similar to the UARTs, ZynqMP hardware platforms use the highest
memory-mapped CGEM peripheral as the primary instance of that
peripheral. This change allows operation on hardware as well as QEMU.
 rtemsbsd/include/bsp/nexus-devices.h | 9 ++++++++-
 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index c3c43dc9..7cdd5428 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -107,7 +107,14 @@ RTEMS_BSD_DRIVER_MMC;
 #include <bsp/irq.h>
-RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM0(ZYNQMP_IRQ_ETHERNET_0);
+/* Qemu only applies user-mode networking to the first interface by default, so
+ * all 4 CGEM instances must be configured in the Qemu arguments using
+ * "-nic user,model=cadence_gem" for each nic.
+ * CGEM3 is used for LibBSD because all Zynq Ultrascale+ MPSoC dev boards treat
+ * the highest-mapped CGEM as the primary interface.
+RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3(ZYNQMP_IRQ_ETHERNET_3);
 RTEMS_BSD_DRIVER_E1000PHY;
 #elif defined(LIBBSP_ARM_ATSAM_BSP_H)
2.20.1
