[5 PATCH 0/2] Backport fixes to zynq uart to RTEMS5
Chris Johns
chrisj at rtems.org
Tue Mar 9 02:20:16 UTC 2021
OK for 5.
On 6/3/21 5:58 am, Jan Sommer wrote:
> This patchset backports the commits of Kinsey Moore and myself, which
> fix the stdin behavior for the zynq-uart based console driver.
> I checked the behavior on hardware with the termios.exe application.
> Before, the scanf and similar functions do not wait for user input and return
> immediately. With the patches the application behaves as expected.
> A corresponding ticket can be found here: https://devel.rtems.org/ticket/4236
> Small side note:
> I noticed that the ARM BSP docs for RTEMS5 list mostly TODO.
> Should I create a patchset backporting the BSP documentation or do you
> want to do that in one go as part of the 5.2 release preparation?
> Best regards,
> Jan
> Jan Sommer (1):
> bsps/shared: Allow setting baud rate for zynq uart
> Kinsey Moore (1):
> zynq-uart: Fix set_attributes implementation
> bsps/arm/include/bsp/zynq-uart.h | 7 +++
> bsps/arm/shared/serial/zynq-uart-polled.c | 2 +-
> bsps/arm/shared/serial/zynq-uart.c | 77 ++++++++++++++++++++---
> 3 files changed, 75 insertions(+), 11 deletions(-)
