[5 PATCH 0/2] Backport fixes to zynq uart to RTEMS5
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Tue Mar 9 08:34:23 UTC 2021
> -----Original Message-----
> From: Chris Johns <chrisj at rtems.org>
> Sent: Tuesday, March 9, 2021 3:20 AM
> To: Sommer, Jan <Jan.Sommer at dlr.de>; devel at rtems.org
> Subject: Re: [5 PATCH 0/2] Backport fixes to zynq uart to RTEMS5
> OK for 5.
Thanks. Pushed to 5.
> On 6/3/21 5:58 am, Jan Sommer wrote:
> > This patchset backports the commits of Kinsey Moore and myself, which
> > fix the stdin behavior for the zynq-uart based console driver.
> > I checked the behavior on hardware with the termios.exe application.
> > Before, the scanf and similar functions do not wait for user input and
> > return immediately. With the patches the application behaves as expected.
> > A corresponding ticket can be found here:
> > https://devel.rtems.org/ticket/4236
> > Small side note:
> > I noticed that the ARM BSP docs for RTEMS5 list mostly TODO.
> > Should I create a patchset backporting the BSP documentation or do you
> > want to do that in one go as part of the 5.2 release preparation?
> > Best regards,
> >     Jan
> > Jan Sommer (1):
> >   bsps/shared: Allow setting baud rate for zynq uart
> > Kinsey Moore (1):
> >   zynq-uart: Fix set_attributes implementation
> >  bsps/arm/include/bsp/zynq-uart.h          |  7 +++
> >  bsps/arm/shared/serial/zynq-uart-polled.c |  2 +-
> >  bsps/arm/shared/serial/zynq-uart.c        | 77 ++++++++++++++++++++---
> >  3 files changed, 75 insertions(+), 11 deletions(-)
