[PATCH RSB] Add recipe for building rtems-net-legacy
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 9 02:31:30 UTC 2021
 rtems/config/6/rtems-net-legacy.bset          |  4 ++
 rtems/config/tools/rtems-net-legacy-6.cfg     | 12 ++++
 .../config/tools/rtems-net-legacy-common.cfg  | 65 +++++++++++++++++++
 3 files changed, 81 insertions(+)
 create mode 100644 rtems/config/6/rtems-net-legacy.bset
 create mode 100644 rtems/config/tools/rtems-net-legacy-6.cfg
 create mode 100644 rtems/config/tools/rtems-net-legacy-common.cfg
diff --git a/rtems/config/6/rtems-net-legacy.bset b/rtems/config/6/rtems-net-legacy.bset
new file mode 100644
index 0000000..424091c
--- /dev/null
+++ b/rtems/config/6/rtems-net-legacy.bset
@@ -0,0 +1,4 @@
+# Legacy networking stack
+tools/rtems-net-legacy-6
diff --git a/rtems/config/tools/rtems-net-legacy-6.cfg b/rtems/config/tools/rtems-net-legacy-6.cfg
index 0000000..9480269
--- /dev/null
+++ b/rtems/config/tools/rtems-net-legacy-6.cfg
@@ -0,0 +1,12 @@
+# RTEMS Legacy networking stack
+#  branch: main
+%define rtems_net_version d8888e058bbbb5e271701d5683e5ab332db72230
+%hash sha512 rtems-net-legacy-%{rtems_net_version}.tar.gz \
+               Kmznx8/DsHLf8MX5wL8b65R7AqJVTmGcwB7I4M8ETB27u666Wi1T5M8SQMLHsZMo9aZ44umWyxdCg6l2OpWr2w==
+%define rtems_waf_version 1a118bbcd52138dbdc3236e64bc23fd430a064b1
+%hash sha512 rtems_waf.tar.gz 9WIROD6rid1M9fsdFWy1Gz/oCsx3l+QGOWoyXnSoGbo/xiyQ+MS+TZU2YoCUNx6/SE18ZeCiq79JYE5H+Yh46Q==
+%include tools/rtems-net-legacy-common.cfg
diff --git a/rtems/config/tools/rtems-net-legacy-common.cfg b/rtems/config/tools/rtems-net-legacy-common.cfg
index 0000000..6ded30f
--- /dev/null
+++ b/rtems/config/tools/rtems-net-legacy-common.cfg
@@ -0,0 +1,65 @@
+# This configuration file configure's, build's and install's linetworking.a.
+%if %{release} == %{nil}
+%define release 1
+%endif
+Name:      rtems-net-letgacy-%{rtems_net_version}-%{_host}-%{release}
+Summary:   RTEMS net legacy provides legacy networking stack from RTEMS 5 and earlier
+Version:   %{rtems_net_version}
+Release:   %{release}
+URL:       https://git.rtems.org/rtems-net-legacy.git/
+# RTEMS BSP support.
+%include rtems-bsp.cfg
+# Net legacy Source from github.
+%source set rtems_net_legacy \
+      --rsb-file=rtems-net-legacy-%{rtems_net_version}.tar.gz https://github.com/RTEMS/rtems-net-legacy/archive/%{rtems_net_version}.tar.gz
+%source set rtems_waf \
+      --rsb-file=rtems_waf.tar.gz https://github.com/RTEMS/rtems_waf/archive/%{rtems_waf_version}.tar.gz
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_net_legacy="rtems-net-legacy-%{rtems_net_version}"
+  %source setup rtems_net_legacy -q -n rtems-net-legacy-%{rtems_net_version}
+  %source setup rtems_waf -q -s 1 -c -a -n rtems-net-legacy-%{rtems_net_version}/rtems_waf
+  cd ${build_top}
+# Build the source code.
+%build
+  build_top=$(pwd)
+  %{host_build_flags}
+  cd ${source_dir_net_legacy}
+  ./waf distclean configure \
+    --prefix=%{_prefix} \
+    --rtems-bsp=%{rtems_bsp_arch_bsp}
+  ./waf
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  ./waf install
+  cd ${build_top}
2.26.2
