[PATCH RSB] Add recipe for building rtems-net-legacy
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 9 02:40:23 UTC 2021
Hello,
This patch doesn't build due to an unrelated error in RSB:
https://devel.rtems.org/ticket/4319
With a workaround to bypass the above error, this patch builds and
installs rtems-net-legacy.
Best regards,
Vijay
On Mon, Mar 8, 2021 at 7:31 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>  rtems/config/6/rtems-net-legacy.bset          |  4 ++
>  rtems/config/tools/rtems-net-legacy-6.cfg     | 12 ++++
>  .../config/tools/rtems-net-legacy-common.cfg  | 65 +++++++++++++++++++
>  3 files changed, 81 insertions(+)
>  create mode 100644 rtems/config/6/rtems-net-legacy.bset
>  create mode 100644 rtems/config/tools/rtems-net-legacy-6.cfg
>  create mode 100644 rtems/config/tools/rtems-net-legacy-common.cfg
> diff --git a/rtems/config/6/rtems-net-legacy.bset b/rtems/config/6/rtems-net-legacy.bset
> new file mode 100644
> index 0000000..424091c
> --- /dev/null
> +++ b/rtems/config/6/rtems-net-legacy.bset
> @@ -0,0 +1,4 @@
> +# Legacy networking stack
> +tools/rtems-net-legacy-6
> diff --git a/rtems/config/tools/rtems-net-legacy-6.cfg b/rtems/config/tools/rtems-net-legacy-6.cfg
> index 0000000..9480269
> --- /dev/null
> +++ b/rtems/config/tools/rtems-net-legacy-6.cfg
> @@ -0,0 +1,12 @@
> +# RTEMS Legacy networking stack
> +#  branch: main
> +%define rtems_net_version d8888e058bbbb5e271701d5683e5ab332db72230
> +%hash sha512 rtems-net-legacy-%{rtems_net_version}.tar.gz \
> +               Kmznx8/DsHLf8MX5wL8b65R7AqJVTmGcwB7I4M8ETB27u666Wi1T5M8SQMLHsZMo9aZ44umWyxdCg6l2OpWr2w==
> +%define rtems_waf_version 1a118bbcd52138dbdc3236e64bc23fd430a064b1
> +%hash sha512 rtems_waf.tar.gz 9WIROD6rid1M9fsdFWy1Gz/oCsx3l+QGOWoyXnSoGbo/xiyQ+MS+TZU2YoCUNx6/SE18ZeCiq79JYE5H+Yh46Q==
> +%include tools/rtems-net-legacy-common.cfg
> diff --git a/rtems/config/tools/rtems-net-legacy-common.cfg b/rtems/config/tools/rtems-net-legacy-common.cfg
> index 0000000..6ded30f
> --- /dev/null
> +++ b/rtems/config/tools/rtems-net-legacy-common.cfg
> @@ -0,0 +1,65 @@
> +# This configuration file configure's, build's and install's linetworking.a.
> +%if %{release} == %{nil}
> +%define release 1
> +%endif
> +Name:      rtems-net-letgacy-%{rtems_net_version}-%{_host}-%{release}
> +Summary:   RTEMS net legacy provides legacy networking stack from RTEMS 5 and earlier
> +Version:   %{rtems_net_version}
> +Release:   %{release}
> +URL:       https://git.rtems.org/rtems-net-legacy.git/
> +# RTEMS BSP support.
> +%include rtems-bsp.cfg
> +# Net legacy Source from github.
> +%source set rtems_net_legacy \
> +      --rsb-file=rtems-net-legacy-%{rtems_net_version}.tar.gz https://github.com/RTEMS/rtems-net-legacy/archive/%{rtems_net_version}.tar.gz
> +%source set rtems_waf \
> +      --rsb-file=rtems_waf.tar.gz https://github.com/RTEMS/rtems_waf/archive/%{rtems_waf_version}.tar.gz
> +# Prepare the source code.
> +%prep
> +  build_top=$(pwd)
> +  source_dir_net_legacy="rtems-net-legacy-%{rtems_net_version}"
> +  %source setup rtems_net_legacy -q -n rtems-net-legacy-%{rtems_net_version}
> +  %source setup rtems_waf -q -s 1 -c -a -n rtems-net-legacy-%{rtems_net_version}/rtems_waf
> +  cd ${build_top}
> +# Build the source code.
> +%build
> +  build_top=$(pwd)
> +  %{host_build_flags}
> +  cd ${source_dir_net_legacy}
> +  ./waf distclean configure \
> +    --prefix=%{_prefix} \
> +    --rtems-bsp=%{rtems_bsp_arch_bsp}
> +  ./waf
> +  cd ${build_top}
> +%install
> +  build_top=$(pwd)
> +  ./waf install
> +  cd ${build_top}
> 2.26.2
