RSB build issue with rtems-libbsd
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 9 04:53:43 UTC 2021
On Mon, Mar 8, 2021 at 7:57 PM Chris Johns <chrisj at rtems.org> wrote:
> On 9/3/21 1:44 pm, Vijay Kumar Banerjee wrote:
> > On Mon, Mar 8, 2021 at 3:14 PM Joel Sherrill <joel at rtems.org> wrote:
> >> On Mon, Mar 8, 2021, 4:02 PM Chris Johns <chrisj at rtems.org> wrote:
> >>> On 6/3/21 2:24 pm, Vijay Kumar Banerjee wrote:
> >>>> Hello,
> >>>> I'm getting the following error when trying to build rtems-libbsd from
> >>>> RSB. Is there anything that I'm missing?
> >>>> ../source-builder/sb-set-builder --prefix=$RTEMS6_PREFIX
> >>>> 6/rtems-libbsd --host=powerpc-rtems6 --with-rtems-bsp=beatnik
> >>>> RTEMS Source Builder - Set Builder, 6 (102cb1e6450f)
> >>>> warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
> >>>> Build Set: 6/rtems-libbsd
> >>>> config: tools/rtems-libbsd-6.cfg
> >>>> error: rtems-bsp.cfg:155: invalid %if operator:  -mcpu=7400
> >>>> -I/home/vijay/development/rtems/6/powerpc-rtems6/beatnik/lib/include
> >>> This looks like a bug. Please raise a ticket.
> >>>> Build FAILED
> >>>> Build Set: Time 0:00:00.046141
> >>>> Build FAILED
> >>>> Commenting these checks from rtems-bsp.cfg gets it building.
> >>> Unfortunately the checks are needed and this is not the answer.
> >>> I wonder how Jennifer has been building libbsd. She is working on this BSP and
> >>> libbsd.
> > This issue is happening with other bsps as well.
> Great and thanks for checking. I asked this question in the ticket. :)
> > This error is also being a blocker to building rtems-net-legacy with
> > the new patch. I can have a look at it, do you have any hints on what
> > might be going wrong?
> Yes in the ticket :) (in short for the thread run with --trace and compare with
> libbsd).
Hi,
I think I found it! :
diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
index cd0bf94..d3ba6cd 100644
--- a/source-builder/sb/config.py
+++ b/source-builder/sb/config.py
@@ -989,7 +989,7 @@ class file:
                     else:
                         self._error('invalid if bool operator: ' +
reduce(add, ls, ''))
             else:
-                if len(ifls) > 3:
+                if len(ifls) >= 3:
                     for op in ['==', '!=', '>=', '=>', '=<', '<=', '>', '<']:
                         ops = s.split(op)
                         if len(ops) == 2:
> Chris
