RSB build issue with rtems-libbsd
Chris Johns
chrisj at rtems.org
Tue Mar 9 02:57:04 UTC 2021
On 9/3/21 1:44 pm, Vijay Kumar Banerjee wrote:
> On Mon, Mar 8, 2021 at 3:14 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, Mar 8, 2021, 4:02 PM Chris Johns <chrisj at rtems.org> wrote:
>>> On 6/3/21 2:24 pm, Vijay Kumar Banerjee wrote:
>>>> Hello,
>>>> I'm getting the following error when trying to build rtems-libbsd from
>>>> RSB. Is there anything that I'm missing?
>>>> ../source-builder/sb-set-builder --prefix=$RTEMS6_PREFIX
>>>> 6/rtems-libbsd --host=powerpc-rtems6 --with-rtems-bsp=beatnik
>>>> RTEMS Source Builder - Set Builder, 6 (102cb1e6450f)
>>>> warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
>>>> Build Set: 6/rtems-libbsd
>>>> config: tools/rtems-libbsd-6.cfg
>>>> error: rtems-bsp.cfg:155: invalid %if operator: -mcpu=7400
>>>> -I/home/vijay/development/rtems/6/powerpc-rtems6/beatnik/lib/include
>>> This looks like a bug. Please raise a ticket.
>>>> Build FAILED
>>>> Build Set: Time 0:00:00.046141
>>>> Build FAILED
>>>> Commenting these checks from rtems-bsp.cfg gets it building.
>>> Unfortunately the checks are needed and this is not the answer.
>>> I wonder how Jennifer has been building libbsd. She is working on this BSP and
>>> libbsd.
> This issue is happening with other bsps as well.
Great and thanks for checking. I asked this question in the ticket. :)
> This error is also being a blocker to building rtems-net-legacy with
> the new patch. I can have a look at it, do you have any hints on what
> might be going wrong?
Yes in the ticket :) (in short for the thread run with --trace and compare with
libbsd).
