[5 PATCH 0/2] Backport fixes to zynq uart to RTEMS5
Tue Mar 9 05:55:46 UTC 2021
On Fri, Mar 5, 2021 at 11:59 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> This patchset backports the commits of Kinsey Moore and myself, which
> fix the stdin behavior for the zynq-uart based console driver.
> I checked the behavior on hardware with the termios.exe application.
> Before, the scanf and similar functions do not wait for user input and return
> immediately. With the patches the application behaves as expected.
> A corresponding ticket can be found here: https://devel.rtems.org/ticket/4236
> Small side note:
> I noticed that the ARM BSP docs for RTEMS5 list mostly TODO.
> Should I create a patchset backporting the BSP documentation or do you
> want to do that in one go as part of the 5.2 release preparation?
You should do this if you find it valuable. Not many of us take time
to backport to the release docs, and no one will pick those changes up
automatically.
> Best regards,
>     Jan
> Jan Sommer (1):
>   bsps/shared: Allow setting baud rate for zynq uart
> Kinsey Moore (1):
>   zynq-uart: Fix set_attributes implementation
>  bsps/arm/include/bsp/zynq-uart.h          |  7 +++
>  bsps/arm/shared/serial/zynq-uart-polled.c |  2 +-
>  bsps/arm/shared/serial/zynq-uart.c        | 77 ++++++++++++++++++++---
>  3 files changed, 75 insertions(+), 11 deletions(-)
> 2.17.1
> devel mailing list
> devel at rtems.org
