[PATCH RSB v2] Add recipe for building rtems-net-legacy
Chris Johns
chrisj at rtems.org
Wed Mar 10 17:59:25 UTC 2021
Thanks, this looks good and is OK to push.
On 10/3/21 5:33 am, Vijay Kumar Banerjee wrote:
> rtems/config/6/rtems-net-legacy.bset | 4 +
> rtems/config/tools/rtems-net-legacy-6.cfg | 12 +++
> .../config/tools/rtems-net-legacy-common.cfg | 78 +++++++++++++++++++
> 3 files changed, 94 insertions(+)
> create mode 100644 rtems/config/6/rtems-net-legacy.bset
> create mode 100644 rtems/config/tools/rtems-net-legacy-6.cfg
> create mode 100644 rtems/config/tools/rtems-net-legacy-common.cfg
> diff --git a/rtems/config/6/rtems-net-legacy.bset b/rtems/config/6/rtems-net-legacy.bset
> new file mode 100644
> index 0000000..424091c
> --- /dev/null
> +++ b/rtems/config/6/rtems-net-legacy.bset
> @@ -0,0 +1,4 @@
> +# Legacy networking stack
> +tools/rtems-net-legacy-6
> diff --git a/rtems/config/tools/rtems-net-legacy-6.cfg b/rtems/config/tools/rtems-net-legacy-6.cfg
> index 0000000..fbc7ab8
> --- /dev/null
> +++ b/rtems/config/tools/rtems-net-legacy-6.cfg
> @@ -0,0 +1,12 @@
> +# RTEMS Legacy networking stack
> +# branch: main
> +%define rtems_net_version 5713f7027984012ea17cdd582e6d0258ee7aa58a
> +%hash sha512 rtems-net-legacy-%{rtems_net_version}.tar.bz2 \
> + 0dwnqZP+j9b2IZ7rqiEBndVkqIsURal4L/47pSI4pe0rz48hmWa78DE0915Gf+/+nvsCMB2I/sFAMj+P6AjeeA==
> +%define rtems_waf_version 1a118bbcd52138dbdc3236e64bc23fd430a064b1
> +%hash sha512 rtems-waf-%{rtems_waf_version}.tar.bz2 \
> + wHiMBCaJjnNd8EEnbl5A9qyGwcQ5E+BcG9Q5SwJmlbarcrQ4U6//Q2ni2XNyXtWQzzy959o6YSg8PvVjgEi0vg==
> +%include tools/rtems-net-legacy-common.cfg
> diff --git a/rtems/config/tools/rtems-net-legacy-common.cfg b/rtems/config/tools/rtems-net-legacy-common.cfg
> index 0000000..a58e152
> --- /dev/null
> +++ b/rtems/config/tools/rtems-net-legacy-common.cfg
> @@ -0,0 +1,78 @@
> +# This configuration file configure's, build's and install's linetworking.a.
> +%if %{release} == %{nil}
> +%define release 1
> +%endif
> +Name: rtems-net-legacy-%{rtems_net_version}-%{_host}-%{release}
> +Summary: RTEMS net legacy provides legacy networking stack from RTEMS 5 and earlier
> +Version: %{rtems_net_version}
> +Release: %{release}
> +URL: https://git.rtems.org/rtems-net-legacy.git/
> +%if %{rsb_released}
> + %define rtems_net_version %{rsb_version}
> + %define rtems_net_ext xz
> +%else
> + %define rtems_net_ext bz2
> +%endif
> +# RTEMS BSP support.
> +%include rtems-bsp.cfg
> +# Net legacy Source from github.
> +%source set rtems_net_legacy \
> + https://git.rtems.org/rtems-net-legacy/snapshot/rtems-net-legacy-%{rtems_net_version}.tar.%{rtems_net_ext}
> +%if !%{rsb_released}
> + %source set rtems_waf \
> + https://git.rtems.org/rtems_waf/snapshot/rtems_waf-%{rtems_waf_version}.tar.%{rtems_net_ext}
> +%endif
> +# Prepare the source code.
> +%prep
> + build_top=$(pwd)
> + source_dir_net_legacy="rtems-net-legacy-%{rtems_net_version}"
> + %source setup rtems_net_legacy -q -n rtems-net-legacy-%{rtems_net_version}
> + %source setup rtems_waf -q -s 1 -c -a -n rtems-net-legacy-%{rtems_net_version}/rtems_waf
> + cd ${build_top}
> +# Build the source code.
> +%build
> + build_top=$(pwd)
> + %{host_build_flags}
> + cd ${source_dir_net_legacy}
> + ./waf distclean configure \
> + --prefix=%{_prefix} \
> + %{rtems_waf_tools} \
> + %{rtems_waf_rtems} \
> + --rtems-bsp=%{rtems_bsp_arch_bsp}
> + ./waf
> + cd ${build_top}
> +%install
> + build_top=$(pwd)
> + %{__rmdir} ${SB_BUILD_ROOT}
> + ./waf --destdir=$SB_BUILD_ROOT%{rtems_waf_build_root_suffix} install
> + cd ${build_top}
