[PATCH RSB v2] Add recipe for building rtems-net-legacy
Vijay Kumar Banerjee vijay at rtems.org
Wed Mar 10 18:24:40 UTC 2021
On Wed, Mar 10, 2021 at 10:59 AM Chris Johns <chrisj at rtems.org> wrote:
> Thanks, this looks good and is OK to push.
Pushed!
Thanks,
Vijay
> Chris
> On 10/3/21 5:33 am, Vijay Kumar Banerjee wrote:
> >  rtems/config/6/rtems-net-legacy.bset          |  4 +
> >  rtems/config/tools/rtems-net-legacy-6.cfg     | 12 +++
> >  .../config/tools/rtems-net-legacy-common.cfg  | 78 +++++++++++++++++++
> >  3 files changed, 94 insertions(+)
> >  create mode 100644 rtems/config/6/rtems-net-legacy.bset
> >  create mode 100644 rtems/config/tools/rtems-net-legacy-6.cfg
> >  create mode 100644 rtems/config/tools/rtems-net-legacy-common.cfg
> > diff --git a/rtems/config/6/rtems-net-legacy.bset b/rtems/config/6/rtems-net-legacy.bset
> > new file mode 100644
> > index 0000000..424091c
> > --- /dev/null
> > +++ b/rtems/config/6/rtems-net-legacy.bset
> > @@ -0,0 +1,4 @@
> > +# Legacy networking stack
> > +tools/rtems-net-legacy-6
> > diff --git a/rtems/config/tools/rtems-net-legacy-6.cfg b/rtems/config/tools/rtems-net-legacy-6.cfg
> > index 0000000..fbc7ab8
> > --- /dev/null
> > +++ b/rtems/config/tools/rtems-net-legacy-6.cfg
> > @@ -0,0 +1,12 @@
> > +# RTEMS Legacy networking stack
> > +#  branch: main
> > +%define rtems_net_version 5713f7027984012ea17cdd582e6d0258ee7aa58a
> > +%hash sha512 rtems-net-legacy-%{rtems_net_version}.tar.bz2 \
> > +             0dwnqZP+j9b2IZ7rqiEBndVkqIsURal4L/47pSI4pe0rz48hmWa78DE0915Gf+/+nvsCMB2I/sFAMj+P6AjeeA==
> > +%define rtems_waf_version 1a118bbcd52138dbdc3236e64bc23fd430a064b1
> > +%hash sha512 rtems-waf-%{rtems_waf_version}.tar.bz2 \
> > +             wHiMBCaJjnNd8EEnbl5A9qyGwcQ5E+BcG9Q5SwJmlbarcrQ4U6//Q2ni2XNyXtWQzzy959o6YSg8PvVjgEi0vg==
> > +%include tools/rtems-net-legacy-common.cfg
> > diff --git a/rtems/config/tools/rtems-net-legacy-common.cfg b/rtems/config/tools/rtems-net-legacy-common.cfg
> > index 0000000..a58e152
> > --- /dev/null
> > +++ b/rtems/config/tools/rtems-net-legacy-common.cfg
> > @@ -0,0 +1,78 @@
> > +# This configuration file configure's, build's and install's linetworking.a.
> > +%if %{release} == %{nil}
> > +%define release 1
> > +%endif
> > +Name:      rtems-net-legacy-%{rtems_net_version}-%{_host}-%{release}
> > +Summary:   RTEMS net legacy provides legacy networking stack from RTEMS 5 and earlier
> > +Version:   %{rtems_net_version}
> > +Release:   %{release}
> > +URL:       https://git.rtems.org/rtems-net-legacy.git/
> > +%if %{rsb_released}
> > + %define rtems_net_version %{rsb_version}
> > + %define rtems_net_ext xz
> > +%else
> > + %define rtems_net_ext bz2
> > +%endif
> > +# RTEMS BSP support.
> > +%include rtems-bsp.cfg
> > +# Net legacy Source from github.
> > +%source set rtems_net_legacy \
> > +      https://git.rtems.org/rtems-net-legacy/snapshot/rtems-net-legacy-%{rtems_net_version}.tar.%{rtems_net_ext}
> > +%if !%{rsb_released}
> > + %source set rtems_waf \
> > +       https://git.rtems.org/rtems_waf/snapshot/rtems_waf-%{rtems_waf_version}.tar.%{rtems_net_ext}
> > +%endif
> > +# Prepare the source code.
> > +%prep
> > +  build_top=$(pwd)
> > +  source_dir_net_legacy="rtems-net-legacy-%{rtems_net_version}"
> > +  %source setup rtems_net_legacy -q -n rtems-net-legacy-%{rtems_net_version}
> > +  %source setup rtems_waf -q -s 1 -c -a -n rtems-net-legacy-%{rtems_net_version}/rtems_waf
> > +  cd ${build_top}
> > +# Build the source code.
> > +%build
> > +  build_top=$(pwd)
> > +  %{host_build_flags}
> > +  cd ${source_dir_net_legacy}
> > +  ./waf distclean configure \
> > +    --prefix=%{_prefix} \
> > +    %{rtems_waf_tools} \
> > +    %{rtems_waf_rtems} \
> > +    --rtems-bsp=%{rtems_bsp_arch_bsp}
> > +  ./waf
> > +  cd ${build_top}
> > +%install
> > +  build_top=$(pwd)
> > +  %{__rmdir} ${SB_BUILD_ROOT}
> > +  ./waf --destdir=$SB_BUILD_ROOT%{rtems_waf_build_root_suffix} install
> > +  cd ${build_top}
