[PATCH 0/3] tester: Update coverage configs
Alex White alex.white at oarcorp.com
Wed Mar 10 18:56:09 UTC 2021
This patch set updates symbol-sets.ini to work with the paths used by
the new build system, removes the need for "target" in the BSP
configurations that include coverage, and adds a few new
coverage-enabled BSP configurations.
Alex White (3):
  tester: Update to support new build system
  tester: Remove target from BSP coverage configs
  tester: Add coverage variants for a few BSPs
 tester/rt/coverage.py                         |  3 +-
 .../rtems/testing/bsps/a53_lp64_qemu-cov.ini  | 40 ++++++++
 tester/rtems/testing/bsps/griscv-sis-cov.ini  |  1 -
 tester/rtems/testing/bsps/leon3-qemu-cov.ini  |  1 -
 tester/rtems/testing/bsps/leon3-sis-cov.ini   |  1 -
 tester/rtems/testing/bsps/pc-qemu-cov.ini     | 41 +++++++++
 .../testing/bsps/xilinx_zynq_a9_qemu-cov.ini  | 40 ++++++++
 .../bsps/xilinx_zynqmp_lp64_qemu-cov.ini      | 40 ++++++++
 tester/rtems/testing/coverage/symbol-sets.ini | 91 ++++++++++---------
 9 files changed, 209 insertions(+), 49 deletions(-)
 create mode 100644 tester/rtems/testing/bsps/a53_lp64_qemu-cov.ini
 create mode 100644 tester/rtems/testing/bsps/pc-qemu-cov.ini
 create mode 100644 tester/rtems/testing/bsps/xilinx_zynq_a9_qemu-cov.ini
 create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_lp64_qemu-cov.ini
2.27.0
