[PATCH 1/3] tester: Update to support new build system
Alex White
alex.white at oarcorp.com
Wed Mar 10 18:56:10 UTC 2021
The tester configurations had not been updated to match the paths and
conventions used by the new build system. These have been updated,
and a few more libraries have been enabled in symbol-sets.ini.
tester/rtems/testing/coverage/symbol-sets.ini | 91 ++++++++++---------
1 file changed, 46 insertions(+), 45 deletions(-)
diff --git a/tester/rtems/testing/coverage/symbol-sets.ini b/tester/rtems/testing/coverage/symbol-sets.ini
index 8f85533..9617dd8 100644
--- a/tester/rtems/testing/coverage/symbol-sets.ini
+++ b/tester/rtems/testing/coverage/symbol-sets.ini
@@ -29,50 +29,51 @@
[symbol-sets]
-sets = score,rtems,sapi,libdl,posix,librfs,libdosfs,libdevfs,libimfs,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
+sets = score,rtems,sapi,posix,librfs,libpipe,libdosfs,libimfs,libjffs2,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libuntar,libblock,libcrypt,libmd,libstdthreads
[libraries]
-score = @BUILD-TARGET@/c/@BSP@/cpukit/score/src
-rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/src
-sapi = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/src
-libdl = @BUILD-TARGET@/c/@BSP@/cpukit/libdl
-posix = @BUILD-TARGET@/c/@BSP@/cpukit/posix/src
-librfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/rfs
-libdosfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/dosfs
-libdevfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/devfs
-libimfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/imfs
-#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs
-#libjffs2 = @BUILD-TARGET@/c/@BSP@/cpukit/libfs
-#dtc = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt
-#libdrvmgr = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr
-#libi2c = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c
-#libcsupport = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/src
-libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/bspcmdline
-libcpuuse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/cpuuse
-libstackchk = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stackchk
-libfsmount = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/fsmount
-libstringto = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stringto
-libdevnull = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/devnull
-libdumpbuf = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/dumpbuf
-#libcapture = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libdummy = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libmonitor = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libmouse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libmw-fb = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#librtemsfdt = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libserdbg = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libshell = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libuntar = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libutf8proc = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libuuid = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-#libxz = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
-libblock = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/src
-#libpci = @BUILD-TARGET@/c/@BSP@/cpukit/libpci
-#librpc = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
-#libxdr = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
-#libcrypt = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt
-#libmd = @BUILD-TARGET@/c/@BSP@/cpukit/libmd
-#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/libstdthreads
-#zlib = @BUILD-TARGET@/c/@BSP@/cpukit/zlib
+score = @BUILD-TARGET@/@BSP@/cpukit/score/src
+rtems = @BUILD-TARGET@/@BSP@/cpukit/rtems/src
+sapi = @BUILD-TARGET@/@BSP@/cpukit/sapi/src
+libdl = @BUILD-TARGET@/@BSP@/cpukit/libdl
+posix = @BUILD-TARGET@/@BSP@/cpukit/posix/src
+librfs = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/rfs
+libpipe = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/pipe
+libdosfs = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/dosfs
+#libdevfs = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/devfs
+libimfs = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/imfs
+#libdefaultsfs = @BUiLD-TARGET@/@BSP@/cpukit/libfs
+libjffs2 = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/jffs2/src
+#dtc = @BUILD-TARGET@/@BSP@/cpukit/libfdt
+#libdrvmgr = @BUILD-TARGET@/@BSP@/cpukit/libdrvmgr
+#libi2c = @BUILD-TARGET@/@BSP@/cpukit/libi2c
+libcsupport = @BUILD-TARGET@/@BSP@/cpukit/libcsupport/src
+libbspcmdline = @BUILD-TARGET@/@BSP@/cpukit/libmisc/bspcmdline
+libcpuuse = @BUILD-TARGET@/@BSP@/cpukit/libmisc/cpuuse
+libstackchk = @BUILD-TARGET@/@BSP@/cpukit/libmisc/stackchk
+libfsmount = @BUILD-TARGET@/@BSP@/cpukit/libmisc/fsmount
+libstringto = @BUILD-TARGET@/@BSP@/cpukit/libmisc/stringto
+libdevnull = @BUILD-TARGET@/@BSP@/cpukit/libmisc/devnull
+libdumpbuf = @BUILD-TARGET@/@BSP@/cpukit/libmisc/dumpbuf
+#libcapture = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libdummy = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libmonitor = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libmouse = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libmw-fb = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libredirector = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#librtemsfdt = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libserdbg = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libshell = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libtestsupport= @BUILD-TARGET@/@BSP@/cpukit/libmisc
+libuntar = @BUILD-TARGET@/@BSP@/cpukit/libmisc/untar
+#libutf8proc = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libuuid = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+#libxz = @BUILD-TARGET@/@BSP@/cpukit/libmisc
+libblock = @BUILD-TARGET@/@BSP@/cpukit/libblock/src
+#libpci = @BUILD-TARGET@/@BSP@/cpukit/libpci
+#librpc = @BUILD-TARGET@/@BSP@/cpukit/librpc
+#libxdr = @BUILD-TARGET@/@BSP@/cpukit/librpc
+libcrypt = @BUILD-TARGET@/@BSP@/cpukit/libcrypt
+libmd = @BUILD-TARGET@/@BSP@/cpukit/libmd
+libstdthreads = @BUILD-TARGET@/@BSP@/cpukit/libstdthreads
+#zlib = @BUILD-TARGET@/@BSP@/cpukit/zlib
2.27.0
